Question about Maytag Washing Machines
My Maytag Model# LSG7806AAE Seriel# 15951872UW washer won't fill with water. I advanced the switch and it goes on when you get to the rinse and spin, but still no water.
After having a repair guy quote me $450 to fix this problem, I took it on myself. I first changed the lid switch as the repair suggested. No luck. Next, I changed the washer timer. Still no luck. Next, I disconnected the water tube and filled the washer with water ( a step I wish I had done first) and turned on the machine. The machine spins, drains, etc but still didn't fill. I changed the water valve. Still no luck. Finally, I changed the 50 cent fuse in the front left corner of the washer unit. Success! The fuse was the problem. The washer now fills correctly.
Posted on Jul 19, 2009
Xixxy, THANK YOU for you above posting. I had the same problem, and YES the fuse was blown. I ran to Wal-Mart picked up a 240v 1.5 amp AGC... sadly this morning the same problem, blown fuse. I replace it with a 2 amp and it blew again.. any thoughts?
Posted on Aug 07, 2009
Maytag Washer won't agitate after filling
Believe you are on right track would try door lock switch first easier to replace and most likely cause.
Aug 04, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Top load maytag performa washer won`t stop flling both on wash and rinse cycles.
The switch the tube connects to shuts the water off. Will it cut off on high medium or low level. You can try blowing on the tube to see if it works. It should cut off when you blow.
Oct 15, 2017 | Maytag Performa PAV2200
Wash doesn't go through full cycle
I have a Maytag model A490 clothes washer. It works fine up to the rinse cycle and then shuts down. When it reaches this point it has become necessary to manually advance the dial a short ways whereupon it will fill with water and complete the rinse and spin cycles. This happens on both the regular and the permanent press cycles. What needs to be done to fix this problem?
Jul 14, 2009 | Maytag Washing Machines
Maytag washer wont start after it fills
Did you replace the pressure switch its a round plastic thing with a plastic tube at the bottom and six electrical connections
Mar 14, 2009 | Maytag Washing Machines
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
There could be several causes for this, but probably a bad timer. One test for this...when it stops...is to turn it off...and turn the timer slightly clockwise...to the middle of the rinse cycle...and turn it back on. Does it run then?? Try advancing it to the spin cycle after the rinse. If it runs okay after you manually advance the knob...the timer is probably defective.
Jan 13, 2008 | GE WNCD2050AWC Top Load Washer
Washing Machines Logo
473 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
