Removed the memory cover along with the memory, press down the power button for about 30 seconds, place the memory back along with the cover and try to boot up your computer. If none of this work try the link below:
It will turn GREEN when the battery is fully-charged.
Is there a problem with the battery not accepting a charge?
Remove the battery, to see if the computer will start without it.
> power button lights shift key and 2 function lights
Do these 2 lights just "blink" once, and then go out?
Does a "power" button stay lit?
Have you hired a professional computer technician to trouble-shoot?
**** my friend, I've gone to Toshiba Site for Australia and New Zealand and found many with PSAA but none with KL thouggh close (I think), so I Googled it and a toshiba forum mentions that it is most likely an Asian Version and not European or another....so i checked out toshiba-asai.com website and there it has less i.e just A100 no PSAAKL etc.
I suspect most drivers from around the world for the A100 would be almost identical if not exact with some exceptions.
Any idea where the Laptop was bought? Where it was bought normally helps in deciding which Toshiba site to go to. Also I suspect the KL stands for Kuala Lumpur but I'm probably wrong.
This sounds odd, I know, but I found a solution that worked for me. I had exactly the same problem: picture taking was wonky, menu button, playback button wouldn't work. It would do this immediately upon starting up, every time.
What worked was when I adjusted the "exposure" by holding the +/- button and turning the little dial near the shutter button. It makes absolutely no sense, but somehow it suddenly started working perfectly again. And it hasn't glitched up again yet.
Hope it works for you, too.
here are few laptop troubleshooting guide to troubeshoot ur laptop. it has one post about power problem of laptop. I hope this laptop troubleshooting help to solve ur problem. or chekc ur laptop with another working battry or try to start laptop to without battery. and chekc ur power cable for charging is working or not
I KNOW exactly what is wrong i had the same problem. you put a program like mirage or another application o your program on your calculator. no kids don't want teachers to deleter their games so mirage has a memory blocker. go into mirage then hit alpha then go to like protection options and stuff and turn off memory block. GOOD LUCK
It does not say how in the manual
Press and hold the Tone* button for few seconds to lock and unlock.
