Question about Epson Stylus Pro 4800 InkJet Printer
Stykus 4800 I am getting lines printing across my paper. Have done 2 power cleans on it but it actually got worse. Ideas?
  • Epson Master
  • 691 Answers
If you take my advice, you will NOT use JackBoy's syringe affair. As an Epson eng I can tell you that you stand a real change of wrecking the print head using forced feeding methods such as Jacks (Sorry Jack)
I assume you are using replacement inks instead of Epson ones. This is usually when running the head cleaning via the printer itself, makes the output worse.
Follow the details in my previous posts about under head cleaning and replace the refilled carts with genuine ones to get the head clean. If you are going to continue to use the cheap head wrecking inks, at least consider using a genuine set every 2nd or 3rd set.
This will help to keep the head clean with the solvent used in the genuine inks. I use genuine ink in all my printers and with one exception (when my child moved the head away from home by hand) I have never had run head cleaning routines more than one every now and then.
Posted on Jul 25, 2008
    Genius:
  • 2,985 Answers
Ypou could try a head clean with a device That I made from a refil syringe and some tube.
It works and saves on the ink too.
[IMG]http://i37.tinypic.com/10o1wys.jpg[/IMG]
Printing horizontal solid lines across paper - have done all diagnostic testing but still solid lines across paper.
Hi
Well it is possible that the nozzles are clogged. You did good in troubleshooting the issue, normally head cleaning cycle will resolve that, but if it fails and out of warranty. Best suggestion is to get a new one since head cleaning cycle from printer settings will consume a lot of ink and not a guarantee to work in printers behaving like what you are getting when printing.
Thanks for using Fixya!
Apr 02, 2010 | Epson Stylus photo C87 InkJet Printer
Lexmark x1270 wont print color even though the cartridge is full.
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Next, try this printer self-test by following the steps given below:
1. Power the printer off.
2. Press and hold the "Paper Feed" button.
3. While still holding the "Paper Feed" button, press and release the "Power" button. Continue holding the "Paper Feed" button.
4. When the printer starts pulling paper, release the "Paper Feed" button. It should print a test page at this point.
5. Power the printer off, as this test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know.
Oct 19, 2009 | Lexmark X1270 All-In-One InkJet Printer
Lines across the page from side to side about 2 inches apart as the paper comes out of the printer. Charge wire problem? If so where would I find it to clean it? A new cartridge only made the problem...
could be a fuser problem. interrupt a print and look if the lines are on the page before it enters the fuser (when you still can wipe the toner off the paper).
Oct 16, 2009 | HP LaserJet 1012 Printer
Printing coloured lines on paper across the page
Try to clean the area around the head output (sprayer). I think it's caused by the waste ink around the head.
May 29, 2009 | HP Office Equipment & Supplies
Bold lines on Fax and Scan
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.  2. Select "Clean and Fix Horizontal streaks."  Click on "Print". This will produce a printed page.
1. Please open the "Solution center" again and go to the "Maintenance" Tab.  2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.  3. Get a damp paper towel.  4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.  5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.  6. Next dab the cartridge on the towel to make sure that the ink is flowing.  7. Snap the cartridges back into the printer.  8. On your computer, select "Old Cartridge install."  9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
May 26, 2009 | Lexmark X7550 InkJet Printer
I have a HP Photosmart C5180 printer. It is not printing purple-instead what comes out is blue. I have done a print test report and it showed the Light magenta and magenta with missing bars and streaks. I...
If your color improved slightly when running the printhead option then doing more should help get better results. Sometime the printheads get really dirty/clogged and running the cleaning option more then once is needed.
If you get a slight line running across the page (from left to right) usually the indicates dust build up on the printhead or ink carriage. The dust acts as a paint brush being dragged across your paper as the carriage moves across the page during printing. You can clean the bottom of the carriage with a Q-tip or purchase some cleaning paper for your printer.
Apr 16, 2009 | HP Photosmart C3180 All-In-One InkJet...
Lines across printed page on photos
Change the paper type and paper size and that should resolve the issue.
Regrads,  raj_p5983
Jan 05, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Printing solid black lines 1/2 high where the actualy print should be
the printhead resistor are done , you will need to replace the whole printhead
Jan 21, 2008 | Apple Epson Stylus Color 740i InkJet...
Epson Stylus Pro 4800 InkJet Printer Logo
70 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
