Question about Indesit Washing Machines
Smell inside washer. Even after wash - Indesit Washing Machines
    Novelist:
    Champion:
  • 244 Answers
Check your doorseal m8 lift the flap that u look at as soon as u open the door check to see if there is mould on it if there is then u casn clean it off if it still smells after u have cleaned it then the seal will need replacing what u can do aswell is put some bleach in the soap drawer were the powder goes now put it on a whites wash which will heat the water to 95 degrees after it has finished u will have to put it on again to clear all the bleach out of the system thids should help also m8
Posted on Jul 25, 2008
My washer smells horrible. The clothes after being washed smell horrible. I have left the door open. I have run bleach thru there 2 or 3 times in a row...didn't help. Have also run baking soda thru...
Despite washers remain with some residual water in the pump and wet components it should no be so critical as you are indicating especially if you cleaned it as you stated. You are not describing the smell but try to isolate the source, like the washer drainage point (odors coming from sewage), behind the washer, and inside or under the washer where the mechanical components are. It wouldn't be surprising to find a dead rat, lizard or pests in there. Sometimes even wet laundry falling behind the appliances stinks strongly. Be safe moving and reaching on difficult places. Good luck.
Dec 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Bad smell inside washing machine
I have found that the best solution to clearing smells for your style of machine is to fill unit with hot water wash & put in 3/4 to 1 cup of baking soda. You should repeat this 2 times. I am assuming that the underneath & behind machine have been checked and that the smell is from the machine internally & not externally. Good luck! Regards
Jul 26, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer smells even after cleaning cycle
It sounds like an air vent is either missing or clogged. That gurgling usually indicates some sy phoning action going on which is drawing water out of a gas trap. Hence you are getting sewer smell into the washer.
Thank you !!
Jun 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
LG washing machine has AWFUL mildew smell
Don't know if this is the same as your problem, but I had a Kenmore washer, (made by Whirlpool) that did the same thing. It was a high efficiency model without an agitator. I finally found out that this type of washer never drains completely but always has some water left in it. This water is somewhere internal that cannot be seen unless the machine is taken apart. That water goes bad and stinks. Everything smelled like mildew and for some while my husband thought I was was washing clothes and leaving them in until they dried. I ended up having to just buy a new machine and when the stinky washer was taken away, just tilting it caused all this foul water to come out everywhere. Also I found this on the internet http://www.consumeraffairs.com/homeowners/lg_washing_machine.html
scroll down and see how other people feel about this machine. I decided that instead of buying the newest, latest, greatest, with all the bells and whistles appliances, from now on I will buy the time tested, plain jane models.
Jun 02, 2009 | LG WM-2277HW Front Load Washer
have you tryed a boil wash with nothing in the washer to soften and expel any caked powder in the drum?i know this does help
May 27, 2009 | LG WM-2277HW Front Load Washer
Clothes have a musty smell if left in the washer
Make shure to do a cleaning cycle. As well, wipe out the inside, the rubber gasket and the door when done washing for the day. We also have found that
leaving the door "Open" for several hours, when finnished, eliminates any future
smells.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
Laundry smells like mildew after washing
Front load washers retain water that you cant see or get to. There are cleaners for washing machines available. I clean mine every month with alot of bleach , try pouring a half gallon of bleach in the soap insert on a normal wash cycle and an extra rinse would not hurt no clothes of course.
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
Smelly wash tub, in washer.
Model nums are fine in the store, if it is an oasis or calypso make sure drain hose is not in drain more than 5 inches. If not your pump might be going out or is clogged. A great cleaner developed is called washer magic and it will help the smell with some elbow grease. If not and is a traditional top load check motor and gearcase or even the timer for wear in a old machine.
Aug 23, 2008 | Kenmore 22422 Top Load Washer
Kenmore washer/top load
Try Washer Magic, you can buy it at your local Menards, Ace Hardware or look at line. I have never used it.
Let me know how it works for you.
May 27, 2008 | Kenmore 24032\24036 Top Load Washer
Musty smell, but can't tell from where
I have the same problem with a 3 month old ge front loading washer.after 1 month it started off smelling musty..I thought it was my imagination, now at 3 months old our clothes smell so bad I think we might just have to buy new clothes! everytime I wash a load the clothes smell worse and now you can even smell it just walking into our closet 2 floors up. A new washing washing machine should NOT be doing this! so far leaving the door open in between washes has helped a little but I plan on tipping it back and finding the hidden filter today. Isn't it lovely that they don't mention a filter that needs monthly cleaning or it's location in the manuals?!
Apr 25, 2008 | GE WBVH6240F Front Load Washer
Washing Machines Logo
43 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
