Question about Nokia 6681 Cellular Phone
Insert sim card
Sir,
i have a mobile of nokia 6681 now it has a problem it doesn't takes sim. it always on offline mode can u pls help me to solve this problem.
  • Anonymous Jul 24, 2008
    i tried all thease things but it of no use? is it any IC problem can u explain that, phone is working good only sim problem sir pls help me.
  • ramaraju Jul 27, 2008
    even i have same problemand i get error message "PHONE STARTUP FAILED.PLEASE CONTACT THE RETAILER.
    Scholar:
  • 135 Answers
Alright, take out your sim card, grab an eraser, erase the gold contacts on your sim card and test it again.
If it fails, take out your battery, grab any small metal that you could stick on to the battery contact points, the gold ones, and scrub it. Just like cleaning the contacts.
Hope this helps...
Posted on Jul 24, 2008
OFFLINE MODE
Offline mode means that your phone aint getting any signal from your mobile service provider's BTS. You need to check it from your mobile service provider if there's an ongoing outage, you need to check as well if the sim card is properly inserted. Try powercycling your phone.
1. Turn off your device.
2. Remove the sim, memory card and battery.
3. Wait for at least 2minutes.
4. Plug back the SIM card, memory card and battery.
5. Turn on mobile phone.
6. Check if you are still getting offline mode.
7. If so, try to insert your SIM card to a different phone.
8. If using a different phone for your SIM displays offline mode still,then its your SIM card which is faulty. If it works fine make sure that you inserted the sim properly or the SIM card slot might be faulty.
Dec 05, 2011 | Nokia E52 Smartphone
I buy new phone which is e72. then when i inserted my sim card one notification asking if i want to continue offline mode.. accidentally i click yes. after that my mobile always offline and cannot detected...
To resolve your problem,you just make a back-up all your files and after doing a back-up,reset your phone into factory default,this will erase all wrong setting.....
Aug 14, 2011 | Nokia N72 Cellular Phone
My 6720 nokia phone has gone into offline mode and can not get it back online can you please help as this is a company phone, i have tried taking sim card out, and memory card out, still does not work
This problem occur when the phone gets dropped on a high place, water damage or setting on your mobile is changed.
Please follow this basic solution :
1. with the sim inserted on your phone, go to profile and select GENERAL. might you accidentally set your profile to offline mode.
2. check the simcard socket if its clean or well align,might corrosion is the problem that's why the sim fails to recognized.
3. Also clean the simcard itself using an pencil eraser.
4. align the battery terminal,might the power supply is not sufficient if the ground (middle terminal) doesn't reach the battery interface. as well as clean the battery connector.
If the above method doesn't work,consult a mobile service center for assistance,maybe the sim IC or some components related to insert sim problem maybe damage.
Good luck...
Jun 22, 2011 | Nokia 6720 Classic Cell Phone
My NokiaN70 is in the offline mode and I cant get to be in the online mode. On start up it asks continue using the phone in offline mode, when I press the No button it does not respond but continues to...
Offline mode means the sim you have inserted was not detected by your phone.Firstly clean the Sim Card slot(case)and check the connector.If the problem still persist contact nearest mobile repairing center.
Good luck
Visit Again...........Fixya.com
Aug 15, 2010 | Nokia N70 Cellular Phone
My Nokia N72 is working only in offline mode. I therefore cannot make or receive calls. When I try to switch to general mode, it says I must insert a sim card whereas the sim card is inserted. Will you...
This problem is called the 'insert sim' problem, there are several possibilities but first of all clean the sim card and the sim card interface on your phone. Next try it with another sim card. If this doesn't solve the problem, you need to go to the mobile repairing shop to get it serviced, or if you have idea in repairing mobile you can refer to this site on how to do jumper tips and tricks for this problem..http://sephonetechnology.blogspot.com/2009/08/nokia-n70-sim-ic-jumper.html Good luck.. and please...-:)
May 04, 2010 | Nokia N72 Cellular Phone
Nokai 6681 isgone to offline mode.
Hey Friend,
  • your SIM ic Damaged
  • Need to replace
  • Or Sim tray Damaged
  • OR sim not Properly inserted..
Is this Helped you.....
Rate me...
Thanks for Using FixYa
Mar 27, 2010 | Nokia 6681 Cellular Phone
My phone nokia 6680 has been in the offline mode.i want remove it
when you insert sim in your phone after using it offline,it should ask you if you want to continue using your phone in offline mode...select NO..Otherwise your phone cannot detect the sim card..clean sim terminals..if problem persists check and reheat sim filter IC..the crystal one, near the sim terminals itself..if all fails then UPP (CPU) or software problem..
Jul 16, 2009 | Nokia 6680 Cellular Phone
Phone in offline mode
'whether you want to continue in offline mode y/n'.,
when it displays this messege
press no
and u r done
Sep 15, 2008 | Nokia N70 Cellular Phone
Insert sim card
dear cheak your simcard if it s ok thne u need to chnage simdriver
Jul 24, 2008 | Nokia 6681 Cellular Phone
Nokia offline
where did you bought your phone? if you bought it from a telecom's promo it means that your phone is locked to a single network provided only. you can ask a technician to have your phone OPENLINE for you to be able to use any kinds of sims.
if it's not the case, check the slot for sim and make sure that the sim is properly placed. restart it without the sim and then restart again but now with the sim.
Sep 23, 2007 | Nokia N70 Cellular Phone
Nokia 6681 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
