Toshiba Portege M405-S8003 Tablet PC Logo
A
Anonymous Posted on Feb 13, 2011
I did a Google update and installed avast software and now my computer hangs up while booting windows XP.
Anonymous
Level 3:
Brigadier General:
  • Master 8,909 Answers
  • Posted on Feb 13, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
8909
Questions
Helped
1541423
Points
28391
If you are lucky, there will be a restore point you can go back to on your computer. I expect Google update is unhappy with XP as it is an OS that is no longer supported.
How to load Firefox on Polaroid P9 Android Tablet
Hi Arthur.
Install Firefox on your phone or tablet Install through your device's marketplace
  • Install from Mozilla's download server
  • Install through your device's marketplace Install Firefox through your device's official marketplace to ensure that you get the best version of Firefox for your device. Most marketplaces will also automatically keep Firefox up to date.
    Tip: Use Sync to share your bookmarks, passwords and site preferences on all your devices.
    Install from Mozilla's download server Installation of the latest Firefox for Android version from Mozilla's download server is not currently available but may be offered in the future (bug 1663735).
    Advanced users: Available Firefox for Android APK downloads can be found on the fenix project releases page at https://github.com/mozilla-mobile/fenix/releases and will be linked from the "Assets" drop-down list. Starting with fenix version 82, APK releases are automatically uploaded to Github.
    Firefox will need to be updated manually if you install it using this method. See Update to the latest version.or try this link.https://www.google.com/search?client=avast-a-1&q=How+to+load+Firefox+on+Polaroid+P9+Android+Tablet&oq=How+to+load+Firefox+on+Polaroid+P9+Android+Tablet&aqs=avast..69i57.3837j0j9&ie=UTF-8
    2answers
    Error message unfortunately the process com.google.process.gapps has stopped
    Good tutorial to fix your problem http://www.androidpit.com/process-com-google-process-gapps-has-stopped-fix
    2answers
    Error message unfortunately process.com process gapps has stopped working
    Follow the directions here: http://www.androidpit.com/process-com-google-process-gapps-has-stopped-fix
    1helpful
    2answers
    Unfortunately the process with google.process.gapps has stopped
    FIXED ! Well almost... This problem is appening with the 'old' Android devices; Software if changing every day and most of the updates are barely tested on all devices and Android versions. The spyware, malaware, adware, are then becoming day after day more aggresive and sophisticated. So, the clean solution if format/clean/reinstall Original software, no updates.
    Another helpful hint is clean all software cache, saved data, for each application , one by one, and then...
    install Avast antivirus free and block behaviours, "APP LOCKING" option, at least of "Play Store" and "Downloads".
    You won't see anymore the annoying message, and device will work like a charm.
    Thank you, Bye. FIXED !
    When booting, the system hangs at Windows XP logo. It does the same when booting (or trying to boot) into safe mode. What could be the problem and how do I resolve it? I tried to use the Windows XP CD to...
    You can access the BIOS usually by pressing "esc", "F1", "F8", or "F12". One of those buttons
    should work.
    As for the hang up at the logo, it sounds like your hard drive might have crashed. The same thing
    happened to me on my Vaio.
    Hi, 1. How to transfer/copy bootable XP files onto SD card and then boot up Toshiba Portege M205 from the SD card? 2. Is it possible to made an image of my Windows XP CD on SD card? Regards Tad
    Requirements
    • PC running Windows XP/2000 with a CD/DVD burner.
    • USB Flashdrive (Or some way to transfer files to the 3epc once Windows is installed)
    • SD Card, a fast SDHC is recommended of at least 2GB.
    • XP3eSD Utility
    • Hitachi Microdrive Filter Drivers
    • Partedmagic (or another bootable CD with disk cloning software)
    • Windows XP CD (SP2 Only Tested, may work with others)
    • Asus Eee PC (Of course!!)
    Instructions:
    1. Copy all files from your XP Install CD to a folder on your Hard Drive
    2. Download the XP3eSD utility and run it to create a new install CD capable of installing Windows to boot off the SD card reader
    3. Boot your 3epc from the CD made in step 2
    4. Install Windows onto a FAT partition, deleting all the existing partitions
    5. When windows boots for the first time turn off the swap file, system restore, and the screensaver.
    6. Then stick your USB thumb drive into the EEE with the Hitachi Microdrive Filter.
    7. Next copy the files from your thumb drive to the desktop and then properly remove the thumb drive.
    8. Unzip the microdrive files to a folder on the desktop. And Insert your SDHC Card into the EEE.
    9. You need to then Hit Start go to run, and type regedit. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\USBSTOR\
      Inside that you should find a directory called something like Disk&Ven_USB2.0&Prod_CardReader_SD0&Rev_0100. Open it. Inside that you should find another directory wich is just a bunch of numbers. Open it. In the right pane you should see a key called "Hardware ID" Right click on it, and select modify. It should list about 7 lines of text. Copy ONLY the first line to the clipboard. Hit cancel, close regedit.
    10. Open cfadisk.inf in the directory you unzipped the microdrive filter to. Edit the section called [cfadisk_device] so that rather than containing 11 lines, just have one line. The line begins with: %MicroDrive_devdesc% = cfadisk_install,
      After the comma, hit ctrl V to paste what you coppied from the registry into the file then save the file.
    11. Go to Device manager. Under disk drives, you should see SiliconMotion and USB2.0 Card Reader. Right click on the card reader and click update driver. Direct the driver updater window to the Hitachi driver you just edited. It won't detect the driver automatically, you have to specifty that your supplying the disk for the hardware and force it to use the driver.
    12. Reboot using the Partedmagic CD or USB Flashdrive, Download it here
    13. Create a FAT32 partition on the SD card, same size as the one on the SSD in your 3epc
    14. Use 'fdisk -l' to find out the partition names of your SSD and SD.
    15. Type this command into a prompt: 'dd if=/dev/sda1 of=/dev/sdb1' When it finishes (it will take some time) type this command: 'dd if=/dev/sda of=/dev/sdb bs=512 count=1' (Note: If fdisk reported your SSD and SD as different than sda and sdb respectively, you must change that in the dd commands, if unsure ask in the support forums)
    16. When it finishes the task is complete, reboot and select to boot from the card reader
    17. Re-image the SSD of your 3epc with your restore DVD or USB.
    Installing Windows XP OS from CD
    I have been installing XP on Portege M200 laptops.
    I use a usb floppy to install the latest bios update from Toshiba's support site.
    After the update the laptop will boot from a USB Cd/DVD drive.
    be patient the first part of the up date goes extreamly slowly but it seems to keep working and the install will work.
    1helpful
    2answers
    How to boot notebook (no cd drive)?
    maybe you can borrow an external cd drive from someone. someone else told me they were able to boot from a thumb drive and install windows. just found this real quick. see if you can use this
    4helpful
    Startup problem
    If you are getting a Blue screen repeatedly and you can't start up to windows in any custom setting ( from f8 start up menu ) one way to solve the problem is to Use the restore disc or windows installation cd or dvd to install windows into the computer or perform a repair installation if a windows already exists on the computer and the setup can find it.
    how to perform a repair installation
    this is for xp, but its similar on 2000 and on vista.
    insert your Windows XP Setup CD, and restart your computer.
    1.When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
    if not then the computer is not set to start up from a cd, you can either enter the setup / bios to change that setting OR right when you power up the computer look at the screen it will say what button to press in order to enter boot menu or bios, it will very likely be button F12 or similar, it should say on the screen when you power on.
    if it doesn't, then you need to go into the bios and change the boot order so that the computer starts from the CD first.
    after that you should be able to start from the cd and install the OS (Operating system, eg.Windows)
    here's some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
    Repeat step 1 when you have changed the boot order.
    2.Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
    3.Do not choose the option to press R to use the Recovery Console.
    4.In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
    5.Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
    6.Follow the instructions on the screen to complete Setup.
    7.Ones windows is working you will need the drivers for your computer, they are at the makers website, for hp and compaq. www.hp.com for acer http://support.acer-euro.com/drivers/downloads.html for all other brands go to google and write Brand drivers. Should get you to the right place. Dell is most likely www.dell.com and so on.
    Top Toshiba Tablets & eReaders Experts
    k24674
    ExpressFiX
    ExpressFiX
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
