Question about Health & Beauty
Hair straightener not heating up
When connected to the mains supply, the power is there but its not heating up.
  • 304 Answers
It sounds to me like the thermal cutoff switch has blown. Straighteners havethese as a safety device similar to a fuse to protect against fire inthe event it gets too hot. These are not very costly to replace.Here is a link to where you can buy them and what they look like:
http://www.welco.com.cn/?gclid=CJiWv7TN2ZQCFQpzHgodl1LXQQ
Make sure you get one of the exact same cutoff point as the onedesigned for yours. If you put in a higher temp device it will beharder to blow but will make it dangerous as it may cause a fireif it over heats. Some shady repair men will just bypass this and it will work again fine but this is a dangerous practice as itdirectly puts you of danger. If you do have it repaired at a shopdemand for the old thermal cutoff from your unit when you drop it offso the tech will know you know what is wrong with it and that you willcheck to make sure that it has really been changed. This will also notgive him the chance to over charge you when he knows you know it isonly a 1 dollar part and easy to change.
This device is very easyto change, If you can open your unit you could easily do this yourself.The part, as you will see on the site where you buy them, only has 2wires one coming out of each end. You simply cut out the old 1 andreplace it with the new one. You do not even have to worry which endgoes where. It is like a fuse, it works the same either direction. Youhave to buy some wire crimp connector to connect it, you can not justsolder it in due to the heat in the iron. In a pinch you could justsecurely twist the ends of the leads with the leads from the old cutoffif you clip the leads from the old cutoff real close to the device.This will leave you with plenty of wire to get a good twist. I alwaysuse the crimp connectors so it looks more professional.
Anyway, Ihope you found this to be helpful and if you need more help feel freeto ask me. I will stay with you on this until we have it fixed.
George
Posted on Jul 25, 2008
How to fix your curly hair?
shampoo and condition with a hydrating formula. Towel dry, and apply a curl defining cream. Let hair air dry. Apply a few drops of argon oil to ends
Mar 02, 2015 | Sexy Hair Health & Beauty
Tip
How to avoid damage your hair when using a hair straightener
1. Choose a hair flat iron depend on your hair type
The plate of a flat iron can be made by different material, while some materials will straight hair in a single pass, others might require more effort. So, before you go out and buy a straightener, you need to know which plate material suits your needs.
2. Go for Adjustable temperature Controls
No matter what type of material an iron has, it can malfunction. So, always invest your money in a straightener which has low, medium and high temperature settings. Afterward, to give your hair your favorite styles, try to keep the heat as low as possible.
3. Choose Size wisely
If you have short hair, you might want to go for a smaller iron. Conversely, only if you have extremely thick hair than going for a larger iron.
4. Fully Dry Your Hair
Unless you are using a wet iron, it's imperatively you fully dry your hair before ironing them. For, if you have wet hair while ironing, boiling the moisture out of them might do serious damage.
5. Use a heat protectant
Better be safe than be sorry. You don't want your hair to lose too much moisture while ironing. So, you might want to apply a heat protectant which will retain moisture in the face of excessive heat.
6. Don't heat one section for too long
While ironing hair, it is best that you divide them into different parts. Afterward, straighten each part for a specific time period which shouldn't be too long. For example, if you are using a flat or curling iron, it is essential that you never heat a single section of air with it for more than 5 seconds.
Source : http://selectedo.com/best-hair-flat-irons/
on Sep 29, 2017 | Health & Beauty
My Gold N Hot flat iron will not heat up
Suspecct failure of the heating element, use a continuity tester to check the element or the connection to the element as the mains wire is OK. Disconnect the power to test.
Jan 17, 2014 | Gold N Hot Gh2168 Professional Ceramic...
Does anyone have any good tips for straightening hair? I am new to this.
1. Make sure your hair is dry
2. Use oils
3. Prep the flat iron at the right temperature
4. Straighten your hair with your overall style goal in mind
5. Brush don't comb!
6. Add volume
rehost_2016_9_13_0dc297ae-7caf-4215-b998-71d5ca0093eb-fblmica31ak52inb20judn4s-3-0.jpg
Feb 20, 2013 | Health & Beauty
How can I clean my hair straightener?
Heat up your hair straighteners and then turn off. When they are still warm (but not burning hot), try wiping them with a damp cloth. Hopefully the bit of heat will make it easier to clean them.
What types of hair irons are there?
The main types of hair irons are;
Curling irons - they create a curl or wave in the hair
Straightening irons - flatten or straighten the hair
Crimping irons - create a look similar to crimps left after braids are removed.
Jan 10, 2013 | Health & Beauty
Jilbere Titanium Tools hair straightener is not operating correctly. When plugged in and turned on, the red light indicating that the straightener is on lights up, however the plates do not heat up.
I recommend to get a better hair straightener, I bought mine at safrons it's the Karmin G3 Salon Pro with ceramic tourmaline plates to avoid hair damages, it heats up really quick and leave my hair soft, shiny and super straight, hope this helps.
Sep 15, 2011 | Jilbere De Paris Jilbere Titanium Tools...
Broken hair straighteners
my hair straighteners are meant to heat up to 230' but i am lucky to get them to heat up at 160 and stay on ? please help
Apr 04, 2008 | Heating & Cooling
Health & Beauty Logo
1,225 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
