Question about HP Photosmart C4150 All-In-One InkJet Printer
Is it ok to refill the ink cartridge with
One of those refill bottles? I wanted to know it that is a good idea or not. If so which one do I buy? Thank you!
  • maggiemae13 Jul 26, 2008
    Thanks so much for the great advice GOD BLESS!!!
    Sergeant:
    Champion:
  • 210 Answers
it is not at all recommended to use refill ink cartridges. first of all u wont get the exact quality of the prints. then if anythig happens to ur printer, ur warranty would be void
thanks and regards
agnel
Posted on Jul 25, 2008
My Hp printer does not want to accept refilled ink cartridges
HP printers might work and might not work with refilled cartrdiges. You can use it but will create a problem in future and quality of printing will not be good. If still you wish to use refilled cartridge then please tell the name of the printer. If your printer hardware gets damaged because of using refilled cartridges then even if your printer is in warranty hp will not replace it.
Feb 25, 2011 | HP Office Equipment & Supplies
Canon PIXMA MP 500 ink refills stop working
you have to reset the ink cartridge.. you have to use a ink refill reseter which come along when you buy a refill kit..
thank you.
May 03, 2008 | Canon Pixma MP500 All-In-One InkJet...
How to refile the cartridge of canon pixma ip1300 printer
Instructions :
  1. Remove the old ink jet cartridge from the printer following the manufacturer instructions. Close the lid on the printer to keep it free from dust and debris while you are refilling the Canon ink cartridge.
  2. Locate the ink tank on the cartridge. Put a 3mm drill bit in a drill. Drill a hole in the top of the ink tank on the cartridge.
  3. Gently insert the needle on the bottle of ink into the hole you just drilled in the ink cartridge. Avoid squeezing the bottle until the needle is completely inserted in the ink tank.
  4. Squeeze the ink bottle gently to refill the cartridge. Fill the tank with a little at a time until the cartridge is full.
  5. Remove the needle from the ink tank. Wipe the top of the Canon ink cartridge off with a paper towel. Place a small piece of duct tape over the drilled hole. Rub the tape to remove air bubbles and to make sure it adheres to the cartridge.
  6. Put the refilled ink cartridge back into the printer. Clean the head of the printer by running the printer software and following the instructions for head cleaning.
Good Luck!
Aug 28, 2010 | Canon PIXMA iP1300 Printer
Why can't I print black and white, without colored ink?
I have the same problem & have been searching for weeks for a replacement printer that will print B & W with one or more colors empty. I haven't had any luck yet - I did run across a post that said: For black and white images and photos, a blend of colors called "composite black" may be used to achieve significantly better image quality and smoother gray tones than can be accomplished with black inks alone. I'm still searching...
Jul 28, 2010 | Epson Stylus CX5000 InkJet Photo Printer
I am wanting to refill one of my inks and want to know how to do it? I have a refill kit, but my printer is not on the list of printers to be filled by this company. Can I still use their ink or will it...
bad news, your cartridges are one single life, I recommend you buy a kit of refillable cartridges, comes with autoreset chips and yes, you will can use your ink with them, look on ebay there are the refillables even one kit with CISS (Continuos Ink Supply System)
Jul 29, 2009 | HP Photosmart C6180 All-In-One InkJet...
Lexmark 2300 series
yes you can refill the cartridge.
Each kit includes 3 bottles of photo ink (1 bottle each of photo black-photo cyan-photo magenta) plus all refill-tools and instructions needed to successfully refill your Lexmark 18C0031 cartridge.
The trick to extending it's life is to know how to add Ink, and to only use Ink which matches the ink which originally came with your cartridge. Each cartridge is manufactured to work with a specific type of Ink, and will not work correctly with anything different.
Apr 10, 2009 | Office Equipment & Supplies
Refilled my Dell Ink Cartridge
yes, it's safe, and if you are dissatisfied with the cartridge, take it up with the cartridge re-filler...better yet, spend about $100 on a black & white laser printer (HP), and get 2000 pages per cartridge, and reduce cost per page by 20 times or more! And If you buy compatibles for this (which are more reliable) -save even more.
*please rate me
Mar 24, 2009 | Dell 948 All-In-One InkJet Printer
It's never going to recognize a product that is not original even if it's refilled in the Dell cartridge. That's happened to me--you get used to it. Dell just wants you to get it from THEM and not from any where else. I have a 922 All-in-One....It's been good for the past 3 years.
Aug 09, 2008 | Dell 922 All-In-One InkJet Printer
Flashing ink refill light
Sometimes refilling them over and over doesn't work well. Once ok...but i suggest that you buy a new cartridge. I know that they are expensive but it will help. Also take some Rubbing alchohol and a q-tip...clean inside where the cartridge sits..that will help...this is for sure a bad ink cartridge
Feb 28, 2007 | HP DeskJet 810c InkJet Printer
HP Photosmart C4150 All-In-One InkJet Printer Logo
104 people viewed this question
Seeker5211
Seeker5211
