Question about Fisher Paykel EcoSmart GWL15
Fischer Paykell 7.5kg Smart Drive top load washer
Hi My FP 7.5 kg washing machine will not commence to wash. When the power button is depressed the lights come on the display panel but will not start to wash when I press start. What can I do to get it to start? I have tried turning off power Regartds Barry
  • barryreid2 Jul 24, 2008
    Hi I can not find a switch in the lid of the machine. Where is the switch under the motor controller and the motor controller located at ?? Thanks for your help Barry
  • ryleyzachwil Feb 11, 2009
    machine comes on lits up but then the water doesn't start in cme in. If I forward it to spin etc nothing happens either!!!!
    Mine is a smart drive Excellence 7.5
Have you checked the lid micro switch under the motor controller which activates when you close the lid to start the machine?
Posted on Jul 24, 2008
  • alf8 Jul 27, 2008
    Open the lid so its vertical and lift it of,you should see a little plunger which the lid activates when it is closed,you can activate it with your finger,and test the machine.
I only have a hose attached to the cold water tap and inlet valve of my Fischer & Paykel top loader washing machine as I only do cold washes, this hadn't been a problem until recently, when th
it could be that the water level got to high and came out of the valve you could try putting a cap on the valve and see if that works and if it does not then it might be a bigger issue.
Dec 23, 2012 | Fisher and Paykel GWL11 Top Load Washer
Ficher and pykel top loader smart drive 9 model mw059nz - won't spin or drain but have emptied by hand tilted back and check for all blockages, coild it be the spin motor?
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
Sep 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
LG washing machine fuzzy logic 8.5 kg not agitating
The reason to this problem can be due to any one
of these reasons.
Lid Switch
Motor Coupler
Drive Motor
Drive Pulleys
Sep 06, 2009 | LG WFT1071TP Top Load Washer
After power outtage my f/p washer is dead -no lights nothing
Only reset is to unplug it. Are you sure you have power at the outlet? If you have 120V at the outlet the power surge may have blown the controller, not a cheap fix :(
Apr 12, 2009 | Fisher and Paykel Fisher & Paykel Washer
Smart drive washing machine not filling properly?
sounds like you do have a solenoid problem undo hoses from back of machine check the filters are not blocked also check at the tap end to see if filter are cleare if all filters are clear most likely you will have to replace you inlet valves assuming there is no problem with pcb board.
Mar 29, 2009 | Fisher and Paykel GWL11 Top Load Washer
Smart drive 5.5 washing machine lights show power on but no go
OK Problem located (without Diagnostics) , the problem was a faulty START/PAUSE button. I took the display board apart and fiddled with the button (whilst the power was UNPLUGGED) Starts almost every time, when it does`nt fiddle some more.
Dec 15, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fischer and paykell dish washer tablet doesnt melt
if that is a drawer dishwasher ck manual i believe it it says powder only the fp drawer dishwasher doesn't use much water so desn't have a lot of spray force to dissolve tablets
Dec 13, 2008 | Washing Machines
White-Westinghouse model la450mxw1 top load capacity in Kg.
I called Frigidaire technical support, they informed me that the capacity is 2.7 c/feet.
Nov 26, 2008 | Westinghouse WWS833ES Super Capacity Top...
Fisher Paykel EcoSmart GWL15 Logo
332 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
