Question about Canon Cameras
Canon eos digital camera, display err 2 in window. will not take any photos. The battery is fully charged and istalled correctly.
  • 2,101 Answers
ERR 02 usually indicates a problem with reading the memory card. Remove and reinsert the memory card (check the pins in the camera with a strong light to make sure no pins are bent). If that doesn't work, try another memory card. If it still doesn't work, the camera may need to be serviced.
Posted on Jul 24, 2008
Error reading on screen on 1000e
Hello :
Here is what Canon said according some forums :
To isolate the cause of the issue, we suggest that you do the
following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
camera should be serviced.
I hope this will help .
please don't forget to rate !
Apr 06, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
My camera wont turn on. The battery is freshly charged, it is installed properly and the battery compartment door is shut correctly. At one point the flash would come up, but no display on the lcd and the...
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Mar 25, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Canon 1000D SLR will turn on but has a "busy" message when looking through view finder. Will not take a photo.
I hope that helps.
Feb 11, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Canon Rebel XS displays busy signal after I take a
Is your card nearly full? Is your battery fully charged?
Dec 19, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon 100 d screen is blank seems to be frozen when trying to take a pitcure flash will pop but will get busy sign battery fully charged
I hope that helps.
Oct 10, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon rebel xs Battery and error 99 problems
I hope that helps.
Aug 05, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Err 99 followed by the "Busy" issue in the viewfinder
I hope that helps.
Jul 26, 2009 | Canon Digital Rebel / EOS-300D Digital...
Err 01 on Rebel XSi
shutter struck, if the battery has no enough charge the shutter motor will not rotate fully,charge the battery and try.
Aug 31, 2017 | Canon Digital Rebel XSi Digital Camera
I took my EOS1000D on holiday took two photo's now all I get is ''BUSY'' on the display
I can help you fix the BUSY Error or Error 99 of your Canon EOS 1000D.
Installation of this Canon EOS 1000D firmware version 1.06 update will solve these problems:
I hope that helps.
May 05, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Canon Rebel Xt EOS Err 99
Error 99 is a "catch all" error that has several causes. It could be that your battery is not fully charged, especially if it is a generic, non-Canon battery. Charge for at least over night even if the charger says it's full. If that's not the cause, switches inside the camera will have to be cleaned by a repair shop.
Nov 24, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Cameras Logo
208 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
