Question about Marantz SR-7200 Receiver
Marantz sr-7200 no OSD
I have made several attempts to bring up the on screen display remotely or from the unit with no results. What am I doing wrong!!!
  • Anonymous Oct 18, 2008
    OSD display does not show up after an HDMI connection been used on the SR 7200
    Problem Solver:
  • 6 Answers
Press AMP then OK on your remote. If the menue does not appear press 9 on the remote. You must have your monitor connected through composit Monitor Out or S-VHS.
Also check your multiroom settings. Maybe your OSD signal is diverted through to other room. I do not have SR-7200 any more, unfortunately.
Posted on Aug 01, 2008
Marantz SR-7200 volume -29dB blinking
Check Speaker connections at BOTH ends and double check to see that they are on the right terminals.
If you need a manual . the Marantz site will have one . PLus they may have FAQ notes for that receiver
Cheers
Mar 01, 2014 | Marantz SR-7200 Receiver
Tip
Marantz SR-7200 reset
This was documented on the Marantz website briefly a year ago and is no longer available. My SR-7200 develops "click/pop" problems and a reset cures it of these issues.
While powered "off," on the front panel, press: A/D + FP +Dimmer (3 buttons) and power the unit on.
This reverts to original (out of box) settings. You then must reprogram input sources, speaker setup, levels and radio stations.
on Oct 03, 2011 | Marantz SR-7200 Receiver
Osd won't come on screen
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Marantz-SR7200-Receivers-manual/id/511dj782/t/2/
Simply run a composite video (RCA) cable to the TV.
Feb 21, 2011 | Marantz SR-7200 Receiver
UK, I have a sr7200 but no remote! Are there any compatable ones out there? I have been quoted £250.00 for a replacement
I bought a RC3200 programmable remote after my dog chewed the origional unit. £30 off ebay, works a great. It comes preprogrammed for all Marantz units. Only problem is that it is a bit hard on batteries.
Nov 02, 2010 | Marantz SR-7200 Receiver
On the Marantz SR-18 amp how do I switch the DSS setting from Dig 2 to Dig 3? Our sound is coming in on Dig 3 and somehow the setting got changed, probaly an errant command on the remote
You have to assign the digital inputs on the setup menu from the remote control while you have the On screen display on a monitor or TV screen.
Feb 10, 2009 | Marantz SR-18EX Receiver
OSD control from receiver
I had the same problem on my 7200 until I realized that the display comes up on the television screen. I carefully followed the set up required from the manual. I got the Manual online at Marantz.com. I have a cable hook up so I connected the video cable out from the box to the Video in source on the 7200 and monitor out to my Television. I then pressed the Amp button to get the remote to Amp mode. I then pressed the OK button that is in the center of the four direction buttons and the menu displayed itself on the screen . I hope this helps. ercble
Nov 28, 2008 | Marantz SR-7200 Receiver
My OSD does not come on
Try plugging a video rca cable into the "monitor" on the back of the mixer (second down or something like that) and then to your tv. This pumps the osd signal to the tv where you can manipulate the menu options.
Think this analogy:
remote = keyboard
receiver = computer
tv = monitor
You need a connection ultimately to the tv for the osd to work.
Aug 12, 2008 | Marantz SR-7200 Receiver
On screen display menu
I scratched my head over this for an hour. The manual says you can access the OSD from the unit, but I see no way to do this. From the remote, you have to select the "AMP" setting at the top of the input list. Then hit the OSD button. Assuming your monitor is set up correctly, this will bring up the On Screen Display. Then hit the "Menu" button also on the remote, and you can make your adjustments. Good luck!
Mar 06, 2007 | Marantz SR-7200 Receiver
Marantz SR-7200 Receiver Logo
676 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
