Question about Electronics - Others
Clarification how to format the memory card
  • 304 Answers
Install the memory card in the device and hook the device up to the computer with the USB cable. Go into my computer and the memory card should show up as a removable storage device. Right click on it with you mouse and select format from the drop down menu. If your computer has a card reader slot on it for your memory card you can just plug it in that slot and repeat the process above. You can also buy an external usb memory card reader for under 10 bucks and also use the same process. Formating the card will prepare it so that you can save files on it. Formating will also erase anything on the card so make sure you save anything you need on it before you format it. If you need more help feel free to cotact me an I will help you more for free but I think I aswered your question as fully as possible with every way you can format a Memory card. Please take the time to rate this fixya. If you need more help geokohler@gmail.com feel free to ask me any questions you have.
George
Ps. I do this because I enjoy helping people and it is a fun hobby I will never charge you for anything I teach you
Posted on Jul 29, 2008
Memory card error card says locked
Hi!
SD cards (or MicroSD, using an adapter) are locked using a mechanical switch on their left side.
Simply, take the SD card (or the SD adapter) and change the switch position.
Usually the UP position is the Unlocked position...
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
B
est regards,
Pelu.
Jan 04, 2011 | Canon PowerShot SD1100 IS Digital Camera
Why my memory card not formatting
Hi!
Your problem might have different causes... As you didn't supply much details I'll try my best to help:
* The memory card itself may be faulty and need to be replaced.
* If connected through a microSD-to-SD adapter and/or SD-to-USB adapter, the adapter(s) might be faulty. Also, try using a different USB port on your computer.
* If you're trying to format it through a camera, the memory card type might not be supported by the camera and therefore it doesn't get formatted. In this case, use a supported card and/or format your card by connecting it to a computer.
Good luck,
Pelu.
Dec 08, 2010 | SanDisk 2GB microSD Memory Card
Bought new Memory cards for Power Shot A530, it won't format
Hi!
I'd guess that the memory card you've bought is a SDHC card and/or a card of more than 2GB, which - unfortunately - is NOT supported by your camera.
Please note that it only supports normal SD or MMC cards in capacity of up to 2GB.
Best regards,
Pelu.
Dec 05, 2010 | Canon PowerShot A530 Digital Camera
My 4gb sandisk memorie card unable to format how to format this card, ithik the driver of card is missing plz solve problem
You don't need any drivers for any USB card. If you can't format it, either the memory card or the USB port is defective. Try to use the card at another computer or try another card on the same USB port.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Nov 26, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Phone says no card when 8gb card is in
have you inserted the card? if yes, open the settings for your phone, look for your memory card and have it formatted through your phone. your card needs to adapt the phone properties first before you can use it.
if that step didn't work, it's better to check your memory card while using friend's phone. consult your phone specifications also for some clarifications, try to check if it can support 8 gb memory cards.
regards.
Feb 28, 2010 | Sony Ericsson Satio Cell Phone
My memory card is unreadable. I insert it into both of my cameras and into my computer and they all say the format is wrong and they won't read it.
plug your memory card into your computer
go to my computer right click on the memory card then click format.
Maybe one of your cameras have a format function on them, go to settings and it might be in advanced or memory then click format.
oops i accidently put this in clarification... dumb computer locked up and changed it...
Sep 27, 2009 | SanDisk Electronics - Others
Format button deleted my memory card???
Format will wipe clean your memory-card like new - Always.
so normally avoid that button.
if you lost some photos using the format then there maybe some chance to get them back.
take out the card and put it in external card reader.
Now get hold of some file recovery software like 'GetDataBack for FAT32' (buy/borrow/steal :) ) install it on your computer, GetDataBack should be able to pull back the data.
Let me know if any more clarifications needed.
May 31, 2009 | Samsung L100 Digital Camera
Phone memory reformat
Hi epoi,
U need to format ur phone memory and MMC(memory card) once.
To format ur phone memory :
1) Turn off the phone.
2) press and hold three buttons (green dial key + * + 3 key) at once and turn on the phone.
3) Hold all those buttons until a formatting screen appears.
4) It automatically works and when it is finished, restart the phone.
5) Now ur phone memory has been formatted
To format ur MMC(memory card):
- Go to memory card option from extras/tools option.
- go to its option and choose format MMC function.
- It formats the MMC.
All these formats erases the files which are uploaded after buying only.
All the built in softwares like camera, mp3 player, messages, etc are not erased.
Dont forget to send me feedback and rate my solution.
Be sure to post clarification request for ur problem after it is solved otherwise it remains showing unsolved here.
Clarification request can be choosen from the " post a ......." box above the empty field where u write ur problems.
May 04, 2008 | Nokia N70 Cellular Phone
Camera not working
HI dude,
I will help u in this problem.
I think the required files/data for camera is erased due to virus in ur cell phone. I recommend u to format ur phone memory and memory card. It also dont erase the phone softwares and apps it came with. It only erases additional datas added later.
1) Make sure ur charge is 75 %. Turn off ur phone.
2) press and hold three buttons ( green dial button + * + 3 key ) and turn on the phone.
3) Hold those buttons until a formatting screen appears.
4) It automatically completes and ur phone asks for restart.
5) Ur phone memory is completely formatted.
To format MMC (memory card):
- Make sure ur charge is 75 % or more.
- Open menu->extras->memory card->format.
- Takes ( 15-20 ) minutes.
- Ur MMC is formatted now.
Please send me a feedback and rate my solution.
Be sure to post a clarification request for ur problem after it is solved.
SAJAN(sajwhat_2003@yahoo.com/sajwhat@hotmail.com)
Apr 12, 2008 | Nokia 3230
How do you open a N70
HI annewighton,
Ur NOkia N70 is crashed due to software error or virus in ur mobile phone. I recommend u to use antivirus software. It wont erase any data.
Another alternate is to format ur phone memory and memory card. It also dont erase the phone softwares and apps it came with. It only erases additional datas added later.
Dec 17, 2007 | Samsung SGH-X495 Cellular Phone
Electronics - Others Logo
82 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
