Question about Epson Perfection V500 Flatbed Scanner
My Epson Perfection V500 Photo won't scan any negatives. It scans them as photo's. I've removed the document mat, unlocked the lock, connected the cover cable and adjusted the software settings. I can't use the holder, since the negatives have a different format ( 6x 9 cm ). I've tried different computers and restarting both scanner and computer.
    Habit-Forming:
    New Friend:
  • 177 Answers
I don't know of any regular printer that scans negatives. Check your printer manual to see if it's designed to print negatives. You can get devices that will do that, but I'm not certain any regular printer will. If you don't have a manual you can look up your model online to find out more.
Posted on Oct 22, 2017
SOURCE:
sherlyn c
  • 134 Answers
SOURCE: By using the epson v500 photo I get the following
Possible driver issue. You have to reload the twain driver.
To uninstall the twain driver, please follow the ff instructions:
- Trash epson scan and epson scanner monitor from the harddrive
- Go to the library, then application support. Trash epson scanner module.
- Go to the library again, then image capture. Trash twain data sources.
- Go to the hd. Click on users. Click on the name of your computer. Click on library, then preferences, then epson. Trash epson scan.
Empty the trash and restart your mac.
When your mac is fully back on. Go to http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=88368&prodoid=63070478&BV_UseBVCookie=yes&infoType=Downloads&platform=Macintosh&x=23&y=13 and you are now ready to install the Scanner Driver and EPSON Scan Utility v3.27.
Posted on May 03, 2009
  • 5 Answers
SOURCE: epson v500 not able to scan negatives! When I open
Inaddtion to the above comments, ensure the cable coming from the lid is also plugged in at the back of the scanner, otherwise it won't pass light through the negatives.
Posted on Nov 20, 2009
BearWeb
  • 357 Answers
SOURCE: Need an Epson Perfection V500 Photo Scanner USER
You can download a User Manual from the following location by clicking on the blue underlined link: Download Now
You will have to answer 4 simple questions about your printer and you will be able to download the manual for free!
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Kind regards,
BearWeb
Posted on Feb 06, 2010
rockmeister
  • 2047 Answers
SOURCE: I have an Epson Perfection V500 Photo scanner
When you are sure that the DC cable has no breakages and makes contact with the main switch and yet nothing happens when you connect to the unit. This could only mean that the power unit inside the scanner or part of its components is burnt. If you can get the unit over to an expert to diagnose exactly which of the components if the power unit is spoilt and a replacement part can be ordered.
Hope this solution has been helpful?
Posted on Sep 25, 2010
CreativeTECH
  • 1719 Answers
SOURCE: I need a driver for
Drivers for EPSON Perfection V500
Click the above link, Select the Model of Scanner and download the Drivers for MAC OS
CreativeTECH
Posted on Jan 03, 2011
I'm trying to install my new Epson Perfection V500 Photo Scanner. I followed the instructions. The software installed . When I turned on the switch a loud grinding noise occurred and t I get an...
Its the lock mechanism under the lid , lift the top to the scan bed and look at the lower right hand side of the inside of the lid there is a grey swithch , move it to unlock! Voila , fixed.
Jan 09, 2011 | Epson Perfection V500 Flatbed Scanner
Hi, and thanks for your help. sad little noises on start up
Hello b3toed - sorry you're having problems; let's see what can be done.
First, there is a transportation lock on the scanner. (If you have a manual, it will tell you more about this.) Make sure it is unlocked.
Second, test the connection between the scanner and your computer -- make sure it's snug (well connected).
Third, if you were scanning a transparency just before this happened, make sure you've removed the reflective document mat.
After checking these things, turn it off - pause - then turn it back on. Best wishes for good results! -- ambssdor --
Jan 14, 2010 | Epson Perfection 2450 Photo Flatbed...
How do I scan a slide photo / negitive on my epson perfection V200 scanner?
safemanuals.com/user-guide-instructions-owner-manual/EPSON/PERFECTION%20V200-_E
please go the above link and download the pdf file and you will get a complete pocedure on scanning a photo/negative
Aug 08, 2009 | Epson Perfection V200 Flatbed Scanner
Epson v500 not able to scan negatives! When I open uop the software, they don't even give me the option to scan negatives, just photos!
You probably need to reset (not reload) the scanner software. Start the Epson scan software. Select professional mode from the pull down menu (it lets you choose between auto, home and professional.) On the next screen select at the very bottom select configuration. The next screen should have 4 tabs, select other. The at the bottom (I think) select restore to factory defaults. This will reset your software, now you can use auto mode if you want it to make all your selections or home if you want some control or professional if you want to control everything. Don't forget to use your film holder that came with the unit and remove the white cover that is locked underneath the lid that covers the film illumination bulb.
Jul 07, 2009 | Epson Perfection V500 Flatbed Scanner
EPSON Perfection 4490 - Ireflective media scans, film doesn't
There are two lamps with this model. One in the base for reflective and one in the lid for negatives and slides. If the base one is going out then it will be trying to use the one in the lid. You must remove the white document mat from underneath the lid to expose this lamp so it can scan your negatives.
Jul 01, 2009 | Epson Perfection 4490 Office Flatbed...
Epson Perfection 4180 won't scan my negatives
cant scan film with epson perfection 4180. how can this be fixed?
Jun 10, 2009 | Epson Perfection 4180 Photo Flatbed...
By using the epson v500 photo I get the following massage: "Please remove the document mat and/or close the document cover" Off course I remove the mat and de document cover is close. I send the scanner to...
May 03, 2009 | Epson Perfection V500 Flatbed Scanner
Using epson v500 and can't get it to change the document size under image type in professional mode according to manual. scanning old B&W negatives 2 x 2 in size and it cuts off the image most of the time...
I had the same problem and have found my answer. I don't know if it's the technically correct one but it works.
When you open the scan page and it shows you the mode, setting, original document type, destination, adjustments, and then the preview and scan buttons. Under the Preview button you will see a box check marked for thumbnail. Remove the check and then do a preview scan. You should end up with a complete scan showing the slide (if you only scanned one), the open side and the surrounding blackened area too. Click on the picture in the preview and then draw an outline around the part of the picture that you want to use. Do this just like it you were going to do cropping of the photo. Once you have the box around the part you want click on zoom. Your next preview will be the picture that you want. I haven't figured out how to remove the remaining blackened area with out going into a photo edit program but it must be able to be done. Then you can scan to where ever you save them to and have the whole slide. I hope that this gets you at least some what further along.
Mar 12, 2009 | Epson Perfection V500 Flatbed Scanner
Dull negatives
are you using the a transparency adapter on the negatives?
Oct 16, 2007 | Epson Perfection 3200 Photo Flatbed...
Epson Perfection V500 Flatbed Scanner Logo
233 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
