Question about Raymarine St 4000 Wheel Drive E12093
Hey
my wheel pilot on my raymarine very loose moving up and down with no resistance. I assume the locking mechanism on the inside of the wheel has broken. Anyone deal with this before? I've called Raymarine and they have said that it should be sent in. In the interest of time and money I would like to effect a repair myself.
  • lostexan2 Aug 10, 2008
    I have the same problem with my st 4000 series, and I have found that the roll pins are sheared in the ingage shaft. I am trying to find these roll pins, To make this repair it will require the removal of the handle by removing this roll pin, then install the roller cam with two new pins, then install the cam and shaft, then reinstall the handle. I would like to find a parts list for this unit. Wayne on the LOST TEXAN
  • vlad19_2000 Feb 04, 2009
    How can I fix a sleeping in my st4000 autopilot wheel?
    Problem Solver:
  • 5 Answers
I had face with similar trouble
I went to RayMarine Web site and got an ecopy of the manual. Inside there is a 3D Blow up of the inner workings of the Auto Pilot. There are a couple of shear pins inside on the clutch lever. It shows you how to disassemble the auto and replace the shear pins. Total cost was $0.20. It works GREAT now. No more problems. I was also was able to give the inner working a good cleaning and lube. I have a soft copy of the manual if you need it
Posted on Jul 24, 2008
Find raymarine st4000+ wheel replacement
Ray marine has an extensive library on-line. I have usually been able to find what I need there. May take some digging though.
Apr 28, 2014 | Raymarine St 4000 Wheel Drive E12093
Raymarine St 4000 Wheel Drive E12093 malfunction
This is a good device. Ray marine has an extensive library on-line. I have usually been able to find what I need there. May take some digging though.
Apr 25, 2014 | Raymarine St 4000 Wheel Drive E12093
How to install
Try this pdf manual. Its for the latest model but I also have an ST4000 and the instalation looks pretty much the same. http://www.raymarine.com/ProductDetail.aspx?SITE=1&SECTION=2&PAGE=88&PRODUCT=4176
Feb 08, 2011 | Raymarine St 4000 Wheel Drive E12093
Motor only steers too one side. I have reversed the polarity and it still drives the same side.
what type of pilot?
Is there a rudder reference unit installed? if yes check rudder ref unit.
Does it does this only in auto?
Set standby and check if +10 and -10 pilot is turning in correct direction.If not See manual for installation drws and setup instructions.
Sep 18, 2010 | Raymarine St 4000 Wheel Drive E12093
Remote on my Raymarine ST 4000 stopped working - how do i troubleshoot problem?
If the remote is the wire type ,check continuity of the wires in the cable ,specially at the bending places where the cable comes out of the connector and the control unit.,Cut away internally broken part of the cable,and solder again respecting the coulours ,or change the whole cable respecting the connections.
Jun 06, 2010 | Raymarine St 4000 Wheel Drive E12093
Can the 12093 operate without something else. just need something to hold a preset direction ..dont need to know direction, just hold course
The wheeldrive is only a mechanical actuator ,it will not pilot ,it will only drive the wheel ,you need a control unit ,several 4000 or 3000 units are suitable ,
some have an internal compass others need an external compass
May 23, 2010 | Raymarine St 4000 Wheel Drive E12093
Autohelm 4000 ST fails to drive
CHECK INSIDE
BELT CONDITION
RUNNER BROKEN OFF
CHECK OUTSIDE
CLUTCH LEVER PIN BROKEN ,CLUCH LEVER OUT OF POSITION
BELT TENSION ADJUSTMENT WRONG (REMOVE SMALL COVER PLATE (+- 10mm Dia)ON REAR OF BACKPLATE ,LOOSE SPECIAL NUT ADJUST WITH ALLEN ,TORQUE NUT,PUT COVER BACK
Feb 19, 2010 | Raymarine St 4000 Wheel Drive E12093
RayMarine wheel 4000
You would need to supply more info to pin point problem. 1) Do you have hydaulic steering?If so do you have a rudder feed back sensor. 2) Is this a new install or did the pilot work properly before 3) Do you have a smart pilot course computer in the system or is the wheel drive run straight from the head unit. 4)What was the deveation reading on your auto pilot compass when it was swang. 5)Was the pilot comissioned by a qualified person. I know there is a lot of questions here but there could be many things that are causing the S.Once the above questions are resolved I should be able to narrow it down to one or two things. Regards Robert
Aug 13, 2008 | Raymarine St 4000 Wheel Drive E12093
Raymarine St 4000 Wheel Drive E12093 Logo
898 people viewed this question
Top Raymarine Boating Experts
Steve
Steve
David Burbee
David Burbee
Are you a Raymarine Boating Expert? Answer questions, earn points and help others
