Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Not charging. when we plug continuesly then only we can listen songs. once we un plug charging cable. automatically its switch off. its charging backup problem
  • 8,596 Answers
Probably hardware and needs to be replaced, but:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jan 01, 2009
How do I get started with my Eclipsemp3 player
  1. You take the USB cable and plug the player into either your computer or into a special wall adapter to let it charge. Preferably the computer.
  2. Once it's charged, you can upload downloaded songs from your computer onto the player, or just listen to the songs that come with it. Hope this helps!
Feb 26, 2015 | Eclipse CLD2 MP3 Player
Tip
How to add songs to Ipod
This is a tip explaining exactly how to add songs to your Ipod.
Firstly, you need to have Itunes installed on your computer. You can download Itunes for free from the following Website. It is always best to use the most updated version of this software.
http://www.apple.com/downloads/
Once you have downloaded Itunes, and installed it, we can continue.
Ok, if you already have MP3 files on your computer, and just want to add this songs to your Ipod, we first need to import all these files to Itunes.Here is how we do this.
To import songs in MP3 format which is already on your computer:
  • Open the Itunes software you installed.
  • From the iTunes File Menu click "Add to Library".
  • Now you need to browse to the folder where the music is located and select it.
  • The files will now automatically be imported to Itunes.
After the installation of Itunes, you need to plug you Ipod into your computer USB port using the connector cable which came with your ipod.
This is the how the USB port on your computer looks like.
This is what the connector cable looks like.
When you have plugged in your Ipod to the computer, Itunes will automatically open.
Now you will be able to see your Music Library(On the left), as well as your Ipod(On the right)
Al you need to do now is to drag the songs you want to copy to your Ipod into the ipod window on the right.
Charge your ipod after you have copied the songs, and start listening.
Kind regards
Andrea
on Feb 21, 2010 | Audio Players & Recorders
Where in the manual does it explain how to listen to songs randomly or how to set the device to play songs randomlu
when u said listen the songs you are mean from the tv first is the tv came with diferent streams like pandora radio if is so you must need to have internet cable plug in crate a account from pandora radio once you sing up you can create the folders of youre choice manually from youre tv or computer and also from the ipod tuch.
Sep 08, 2010 | Sylvania Televison & Video
Switches off quickly
the battery or the software, try to restore the the software first and if that dosnt work buy new one these mp3 players are like cheap as hell
May 08, 2010 | Transcend T.sonic 612 MP3 Player
Wont download anything
format it once more then use usb a cable to plug in the mp3 player and u see a removable drive is created in my computer double click the drive and then create a song folder inside it then copy paste the songs which u want to insert into the mp3 player. after the songs are copied safetly remove the mp3 player then listen to the songs which u have transfered....... enjoy mp3 player.....
Sep 05, 2009 | Philips GOGEAR SA6045 MP3 Player
My ipod nano third generation is frozen
You should not plug the ipod to pc while it is playing because it is switches from the playing mode to sync and charging mode you can not play and use the ipod while it is connected with the software without ejecting it from itunes. Do a reset by pressing and holding the center and menu buttons at the same time until the screen goes back and apple logo pops up. This should reset your ipod and fix the problem.
Feb 20, 2009 | Apple iPod nano
Uploading songs onto the Missil flashMP3 player
Hi There,                First you have to charge it up fully by plugging it into the computer with the usb cable it came with. if yo have windows 2000 or higher you don't need to install the software it came with. It takes 4 hours to fully charge. Shut your MP3 missil player off and the plug it back into the computer with the cable it came with. Microsoft window plug and play should automatically indentify the devive as a storage device. All you do from there is drop and drag your mp3 songs iinto the storage folder in your device. Enjoy your new device
Dec 28, 2008 | Aiwa HZ-WS2000 MP3 Player
No power
I am having the exact same problem. I put songs on the MP3 player and it hasn't worked since. I'm not getting any help or support. If you find out what the problem is, please contact me. This is is so disappointing to buy a Xmas present that doesn't work!
itsmesusan@roadrunner.com
Dec 27, 2007 | GPX MW3837 MP3 Player
Problem to my cell
You may have to download music player if you want to have continous music, or else you will have to operate it after every song.
Nov 02, 2007 | Nokia 6230i Cellular Phone
Sansa e250 getting worse since "upgrade"
Format your player and re-transfer your songs. The best way to format the player is by changing the player to MSC, then connect it to your computer and open My Computer and right-click and format the player remove the quick format then click start. :D
Jun 11, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
