Question about Acer Aspire 5050-3242 Notebook
How to crack /unlock the password set on SATA HDD port 0 in CMOS on Acer Aspire-5050
I set password in BIOS for detection of SATA Hard drive for booting.
I forgot the password.
Can you give me any solution?
Thanks
  • asgrkan98 Jul 24, 2008
    This solution is not resolving the problem.
  • 31 Answers
Cheap solution available at http://www.acersnoop.co.cc
Posted on Jan 26, 2010
  • 813 Answers
U have to do this remove your BIOS battery from the motherboard for few mints then put it back your problem will solves
Posted on Jul 24, 2008
Acer Aspire X3300 not detecting on-board SATA controller
HINT:
1) Try to reflash the BIOS.
2) Look for new firmware Flash update /then reflash BIOS.
3) buy a new bios module equal to yours and seek help on tech to disoldering module to the new one.
Carl
Feb 24, 2016 | Acer New Aspire X1200 X1300 X1301 X1800...
My friend bought a laptop (Acer Aspire 4520) when you turn it on you get a black scre en with a blue box that says Enter Password. I was able to find two bios passwords online that will take you to the...
That's the idea of HDD passwords. You can't access the data on it at all. Either by boot cd or physically removing the hard drive and connecting it to another pc, you still won't be able to access the drive. Two options, replace the hard drive and reload a clean o/s. Or, there is a service available that might remove the password and retain the data. There are also services that will remove the password and wipe the data, as a security measure. But at the cost of either of these services, makes better sense to replace the drive and reload the o/s. You can goole HDD Unlock and find the software easily. You would need to connect the drive to another working pc. Download and run the software on that password protected drive. It will tell you if it is unlockable. To bad it's not a Dell, I may be able to provide you with a p/w to unlock it.
Oct 15, 2013 | Acer Aspire 4520-5582 Notebook
I am having trouble with my acer aspire 5050, that it wouldn`t start because i've forgot the bios password to login to my system device... could you help me, how to reset my bios password...
Use Unlock Acer Bios Recovery Service to get your bios password reset with a bios master password they calculate just like Acer Support. These guys are pros at clearing bios passwords and hard drive password on laptops. Reset your bios password for only $20 and they guarantee it to work.
Sep 16, 2011 | Acer Aspire 5050-3242 Notebook
I got a new SATA 500gb HDD but the motherboard wont detect it.
Access to your Bios Setup & configure the Bios settings.
Features Setup Page : This page sets up some parameters for peripheral devices connected to the system.
CMOS SETUP UTILITY - Copyright (C) 1985-2003, American Megatrends, Inc.
Features Setup
OnBoard Floppy Controller : Enabled
Serial Port1 Address 3F8/IRQ4 : Enabled
OnBoard IR Port : Disabled
Parallel Port Address : 378
Parrllel Port Mode : ECP
ECP Mode DMA Chnnel : DMA3
Parallel Port IRQ : IRQ7
OnBoard PCI IDE Controller : Both
OnBoard SATA-IDE
: Enabled *(Make sure This is enabled)
Audio Device : Enabled
Modem Device : Auto
Ethernet Device : Enabled
If you have got a SATA III HDD, ie if it is a Western Digital Sata III you need to configure the jumpers to work with your older Sata interface port.(Only Sata 1 & 2 ports on your Mainboard Socket 478). As for Seagate Sata III HDD, the configuration is automatic.
If your 500GD HDD is not detected, try updating the BIOS!
A word of caution "Updating the Bios is not for the Novice" Do it at your own risk. Failure in updating the Bios may render your Mainboard useless.
Hope it helps.
May 14, 2011 | PC Chips M955G Motherboard
Bios not recognizing hard drive and cd rom. usb ports work
Hey I have the same problem, may have found a solution to this problem although im not 100% positive but read My post here in a reply to the same exact problem. Keep in touch with Me on this and maybe we can find a permanent solution
Feb 16, 2010 | Acer Aspire 5050-3371 Notebook
Have a acer aspire 5515 notebook laptop it keeps asking for sata port 0 hdd user password how do i get it off there
It sounds like you may need to go into the BIOS and change or disable the password. Alternatively, clear the CMOS.
Dec 12, 2009 | Acer Aspire 5050-3242 Notebook
Hdd primary pasword is lost cannot open hard disk drive showing error codes 06231 and so on cannot boot the computer cause the disk drive is asking for primary hdd pasword and is no taking the password...
Most modern laptop HDD or BIOS passwords are not resettable and don't come with default passwords to unlock them if the password is forgotten.
You will need to contact Acer and find out what kind of warranty coverage your machine has. It's likely that you will have to pay for the services they provide or pay for a new hard drive yourself and re-install Windows.
Aug 10, 2009 | Acer Aspire 5535-5050 Notebook
Asking for password sata port pass
This is a "security" feature, to protect the files on the disk-drive from unauthorized access.
The computer supports "full-disk" encryption of each disk-drive inside your computer.
So, what password did you set when you first initialized this disk-drive?
If you don't know it, there's nothing you can do -- all the files on the disk-drive are _NOT_ accessible to you.
Jun 01, 2009 | Acer Aspire 5050-3242 Notebook
Acer Aspire 5050-3242 Notebook Logo
2,295 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
