Question about Whirlpool LER5636P Electric Dryer
Whirlpool awz 7303 - drum spins intermittently My Whirlpool Imperial Dryer sounds louder than normal and it starts and stops intermittently. It will click then go off then after five min start back just to shut off again. The blower fan is not obstructed. I removed the rear cover and there is a Yellow Wire With red stripe hanging inside off of something. there is NOTHING in their to plug it into. I cannot for the life of me find where it went or where its supposed to go. It is down by the thermal relays. with no where to plug it into. everything has a wire already connected to it. I I downloaded the manuals from the website, I could not find anything on that wire. MODEL NUMBER LE7800XSw3, Not on the List...
I have a yellow and red wire on my kitchenaid dry that connects behind the ducting. Try takeing the duct off and look in behind.
Posted on Jul 24, 2008
Whirlpool dryer drum won't spin
Sounds like belt is worn and lose, probably needs to be replaced.
May 02, 2014 | Whirlpool Dryers
Whirlpool AWZ 410 washer dryer is not generating any hot air when drying. The dryer drum is tumbling but with cool air only.
Unplug the unit and take the top with the screws holding the lid on. Take a look at all of the wires on the top of the machine. You might notice broken/burnt wires on the safeties that are close to or that directly activate the heating element located in the blower housing located at the top of this washer/dryer condensing unit.
Nov 26, 2013 | Whirlpool LER4634J Electric Dryer
Whirlpool awz 7303 dryer will not heat
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 28, 2010 | Whirlpool Dryers
Whirlpool Imperial gas dryer won't spin
It's a broken belt. Replace the tensioner assy also
Nov 03, 2009 | Whirlpool Dryers
Whirlpool AWZ 7303 tumbling but not drying.
blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Sep 11, 2009 | Dryers
Whirlpool Imperial Electric Dryer won't start
I have a problem with my Whirlpool IMperial electric dryer, not a Duet gas dryer.
Jul 12, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
sounds like the belt is going bad or something is jamming the drum up like a bad roller.
Jun 28, 2008 | Whirlpool Dryers
Whirlpool LER5636P Electric Dryer Logo
170 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
