Question about Sony PlayStation Portable (PSP) Console
Psp my psp wont play games on my memory stick,whe i open d update that iv download my psp cant open it , it apears in the screen THE GAME COULD NOT BE STARTED (DADADADA),PLS HELP
  • jthro3 Jan 04, 2009
    hi my psp wont play some download games,i get the title screen,click on it and get the white psp screen which then goes black as if its loading then the psp turns off.im running 3.60. cheers
  • janxero85 May 11, 2010
    how can i go directly to the revory menu?pls answer!
  • 50 Answers
First Tell me about your PSP firmware Version. If its a orginal SONY firmware you can't play the games from the memory stick. If you are in custom firmware follow this procedure.
1.press the SELECT button so you will get the M33 VSH MENU
CPU Clock XMB - Default
CPU Clock GAME - Default
USB Device - Memory Stick
UMD ISO MODE - Sony NP9660
ISO VIDEO MOUNT - NONE
Make sure that its showing as per the above values. if not change it to the above values.
If still the problem continues check these too..
Go to the recovery menu.>>> configuration >>> Game folder homebrew (currently: 3.XX or 4.XX kernel)
if its showing 1.50 change it to 3.xx or 4.xx
also
Go to Recovery >> Advanced >> Advanced Configuration
and make sure that both the options are Disabled.....
Posted on Jul 24, 2008
Hi i want to ask how to downgarde psp 6.20 to 5.50 without pandora battery please help me in that...thank you
Hi
You can downgrade your psp without a pandora battery but you will need a Lumines game hack,Follow these steps to do so.
Download the 5.50.pbp file. Rename the 5.50.pbp file to "UPDATE.PBP." Connect your PSP to your computer with the USB cable and select "USB Connection" to place the PSP into USB mode. A window will appear on your computer and you will be able to see the PSP memory stick files.
Download the downgrade pack. Open the "MS_ROOT" folder from the downgrade pack. Right-click the "PSP" folder and click "Copy." Go back to the PSP memory stick and right-click it. Click "Paste" and "Yes" to overwrite the data.
Right-click the UPDATE.PBP file that you downloaded in step one and click "Copy." Open the "PSP" folder on the PSP memory stick and you will see the "GAME" folder. Open this folder to reveal the "UPDATE" folder. Right-click the "UPDATE" folder and click "Paste" to transfer the update file to your PSP memory stick. The downgrade pack and 5.50 update file are on the PSP memory stick. Press the "O" button to safely disconnect the PSP from your computer.
Insert the Lumines PSP game into the PSP drive. Select the game from the PSP menu to start. Press the "Start" button when you get to the Lumines start screen. Your screen will blink red and will turn completely blue. You will be brought back to the PSP screen. It is important to not press any buttons before you get to the Lumines start screen.
Go to the game section of the PSP menu and you will now be able to see the "x.yz update" application. Select it with the "X" button to start it. Press the "X button from the main menu to start the downgrading process. Press "X" again to reboot the PSP when the downgrade has completed. You have now downgraded your PSP to 5.50 firmware.
Jul 31, 2010 | Video Game Consoles & Games
After updating my psp to 5.5 i cant see my cso files my psp can read only videos & mp3s from the memeory stick but cant see the games files thk you in advance
hi you have updated the sony psp firmware to 5.5 so thatz the firmware which will not allow you to play the games using the memory card however you will be able to play using the umd this is done to stop piracy
if you want to play the games using the memory stick then you can download the m33 firmware for psp which allow you to play through memory stick its the same sony software but has been changed a bit so that it can read the game file through memory card
i have been using this m33 driver from past 2 years and it works perfectly u can even update this driver to its latest version
hope this will fix your problem
Jul 21, 2009 | Sony PlayStation Portable (PSP) Console
Can i play eboot.pbp on psp?
yes you can if you have a custom firmware. the psp will not recognize the eboot file itself unless you put the eboot file inside of a folder with the name of the game as the folder name. then you save it to psp/game. iso and cso files are placed in the iso folder of the root.
Feb 27, 2009 | Sony PlayStation Portable (PSP) Console
I cant play games in my psp memory stick after i updated to 5.2
Please check you update. If your update is low, you must upgrade it to 3.52 m33 then download a firmware 3.70 m33 or higher to get the m33 recovery.
As your PSP start press SELECT and you can see a menu then go to "UMD ISO MODE" from "normal" change it to "Sony NP9660" then exit.
Now enjoy playing ISO or CSO game. Happy playing.
Jan 29, 2009 | Sony PlayStation Portable (PSP) Console
I cant play games on my psp v5.01 in its memery stick
u need to find a MP4 game and put it into e folder tt said MP4.. but is hard to find those game.. if u find some.. pls let me noe.. thanks..
Jan 22, 2009 | Sony PlayStation Portable (PSP) Slim...
I cant play games from memory
Hi kalfan
What happened was that when you downgraded your PSP to -play game from your memory stick, that version was loaded onto your PSP for a reason. What you did now is install the latest firmware and that disabled you from playing games from your memory stick. You might have to get your PSP downgraded again with the older firmware version.
Nov 11, 2008 | Sony PlayStation Portable (PSP) Console
Help!!
U NEED TO GET AN NEW MEMORY STICK
Nov 06, 2008 | Sony PlayStation Portable (PSP) Console
How to downgrade psp v5.01 to 3.80
hi your previous psp version is 3.80 m33 if yes your using custom firmware that why you can play game to your memory stick the problem is you upgrade your psp firmware to sony official firmware 5.01 you reinstall your firwmware again using custom firmware like 5.00 m33-3 cfw below with m33 or OE
Nov 02, 2008 | Sony PlayStation Portable (PSP) Console
Psp firmware latest version has updated, after that my game can't to play as before, how to restore back my original psp firmware version as original or any guide to resolved my problem
Try a restore default settings. If you are updated to the latest official firmware and trying to run a game from a memory stick it wont work. As official firmware wont support playing backup games from the memory stick
Jul 23, 2008 | Video Game Consoles & Games
PSP won't play any games
the reason the umd wont load is because someone shut the psp off when the game was loading. so whoever did that just messed up your psp. i know cause someone did it to mine now i have to get it fixed or buy a new one. and to get the psp fixed its not guna be cheap.
Dec 25, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
169 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
