Question about Intel Motherboard
Computer box problem
My car is drowned by the flood after that the engine ca not be started. the mechanics said the problem is the computer box.
  • 5,568 Answers
In case you are still looking for an answer here; Remove the box from the car, bathe it in slightly warm water with a drop of dishwashing detergent, just enough to spoil the surface tension of the water. Finally, rinse it is warmed DISTILLED water since tap water or mineralized water can be conductive.
Allow to dry for days if possible before reinstalling it.
Good luck; the beasties are expensive to replace but you may have other problems to deal with such as air filters being soaked and the entire ignition system having water in all the wrong places.
Posted on Sep 27, 2008
    Guru:
  • 859 Answers
Repost this as a new question, selecting for product: Cars, and then you Make,and then your model and you'll get some help soon enough.
Regards,
Worldvet
Posted on Jul 24, 2008
Will not start when engine is warm sounds like it is flooded cold engine OK
Bad coolant temp sensor--makes ECU think engine is still cold so sends too long injector pulse flooding engine. Very common, and easy fix.
Apr 02, 2016 | Cars & Trucks
Have a 2004 nissan altima plugs getting wet with gas take them out and dry car starts but same problem after 5 6 hrs won't start again what's the problem
Your engine is flooding with fuel which is why you have wet plugs and why you are having problems starting the car. A flooded engine will not start.
It sounds like a recurring flooding problem rather than a one off and the injectors may be leaking. One way or another too much fuel is being delivered by the injectors.
Get the car into Nissan Service and have them check it over and identify the cause.
Here is some information on the flooding problem prepared by a professional master mechanic.
Flooded Engine
Jan 25, 2016 | Nissan Cars & Trucks
Flood engine
You get liquid fuel drowning the spark plugs, so no spark. There is usually a strong smell of fuel. It is rare for this to happen with fuel injected engines. Depending on the type you may be able to start by flooring the throttle pedal and keeping it there while you crank, but with some modern engines this won't work either! You could take out the spark plugs and dry them, or just wait 20-30 minutes.
Jan 09, 2014 | Cars & Trucks
Motor se apaga cuando lo hacelero o y despues como que si se ahoga toyota camry 1998
google translator
Motor shuts off when hacelero oy then as if toyota camry 1998 drowning
ok , the engine stalls. by flooding, (gross excess fuel)
ever do a tune up, do the 60k, mile critical service points.
Dec 13, 2013 | 1998 Toyota Camry
Will start, but floods out and won't run
wow, great post, (no location stated sadly,you in Nunavut?)
floods, a clear hard piece of evidence. bravo, and helps...
fuel soaked spark plugs.
if tuned up and , compression is 150,psi not 90 x4.
and spark is strong, then and only then is it a fueling problem.
ill assume you read the op guide and used the unflood method/
stated in glove box manual?
no, then use WOT TO START THE ENGINES.
wot, wide open throttle, (yes, right foot to floor)
this act cuts all fuel injections. and must start
if not , no spark.
if the egr is leaking , it will be hard to start, do the 50k service on it.
if the ISC is stuck closed, it will be hard to start and flood (no air)
so use just 10% throttle , acting as sort of a human ISC
start now?
that is just the tip of ice berg.
here is more flooding.
all ways, i think are here
http://www.fixkick.com/flooding.html
Oct 13, 2013 | 1995 Geo Tracker
Jeep cherokee power seats
check power at motor if no power check the switch on the seat
Oct 13, 2013 | Cars & Trucks
Engine seems to be flooding out. I have spark but if you take the plug out it is soaked with gas.
if it's flooding out try starting it without using the choke. if it still floods then the float in the carb is stuck open and you will need to remove and rebuild the carb. they sell complete carb kits for all makes of engines..good luck
Mar 20, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Computer box for Nissan Sentra 2008 GX
possibly. have you changed all your filters? check air filter and throttle body. may be ruined from the water. the throttle body can be cleaned with a fuel injection spray. does your check engine light come on?
Oct 15, 2009 | 2008 Nissan Sentra
I have a problem with my truck starting, chevy 1990 throttle body type 2 top injectors. It takes several cranks to start if it even starts at all without flooding the engine. _ having this problem before I...
I had the same problem with my 1990 chevy 1500 (350) replaced the plugs and wires no luck. I replaced the fuel pressure regulator, still no luck. So i called my mechanic he said it would either be the map sensore or the coolant temp sensor. I didnt figure the coolant temp sensor would cause my truck to flood but it was a 17 dollar part so i gave it a shot, took 10 seconds to switch it out with a 19mil deep socket. Truck fired up and ran like a top no more flooding. =)
Jun 23, 2009 | 1990 Chevrolet C1500
Intel Motherboard Logo
26 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
