Question about HP LaserJet 1200 Printer
Sound unexpected when intializing
My printer is hp 12OO series,when i power on the printer it sound like rubbinga rusty gear. but i suspectedthe laser beam sound as it. could it be the problem.?
  • 1 more comment
  • kaiasimmons Aug 29, 2008
    I hear a loud clicking when my printer comes on sounds like something is stuck but there is nothing there.
  • twoh2die Oct 17, 2008
    Out of nothing my hp 1200 printer started making an awful sound like something was jammed. From than every time i switch on the printer i can't print just listening the sound. I have looked for a paper jam there isn't any.
  • twoh2die May 11, 2010
    When you say broken fuser gear, you mean???!
  • 628 Answers
Might be that the toner cartridge is not inserted properly. It may also be a broken fuser gear.
Posted on Oct 20, 2008
Show error 52.00
Note this a not something users can repair themselves. It is a fault with scanning motor. may need motor or whole scanning assembly to be replaced. Only service centre can perform this.
HP LaserJet 4200 and 4300 Series Printers - Numerical Error Messages 52.XY PRINTER ERROR For help press? alternates with 52.XY PRINTER ERROR To continue turn off then on
Description
A temporary printer error has occurred.
X Description 0- Scanner error
1- Scanner startup error
2- Scanner rotation error
Action
  1. Press the (Select) button to continue.
  2. Turn the printer off and then turn the printer power on.
  3. If the message persists, contact HP Customer Support.
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error.
1. Press GO. The page containing the error will automatically be reprinted. 2. Turn the printer off and then on. 3. Reseat cables to the laser/ scanner and engine controller. 4. Replace the laser/scanner. HP LaserJet 4200 and 4300 Series Printers Numerical Error Messages
Apr 16, 2016 | HP LaserJet 4350n Printer
Hp 2420 side wheels are troubling
In this series fuser driving gears (especially 20T gear) are observed warn-out in many cases.. feeling like grinding sound, replace with 20t gear , apply grease for these family gears..
Oct 05, 2011 | HP LaserJet 2420 Printer
No display when i turn printer on.
two things you need to check..1.printer intializing? 2. printer recognising?
Printer intializing & not recognising replace formatter, recognizing,intializing replace control panel,printer not intializing,not recognizing replace DC controller..
Sep 19, 2011 | HP LaserJet M1522n MultiFunction Printer
Operation stop after one use. All you heard is a continuous shutter sounds found on the scanner or photostat copy section. How can isolate this kind of trouble?
This is already a possible hardware issue.
If its making unexpected or noisy sounds while operating gears inside of it is causing the issue.You cannot fix it unless you change gears inside of it which is very mechanical and only the manufacturer can do.
Try calling Hp support 18004746836 because for this type of issues they can enroll you to their loyalty program where you can upgrade your printer to newer version.Take advantage of it!
Hope I help you a bit
Thanks
Mar 28, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Grinding noise in cartridge for hp laserjet 1200 series printer. I replced cartridge and still hear noise sometime worse and then not so loud.
I have the same problem and I know what is causing my problem. It's not in the cartridge. You're laser scanner is going to go bad. I had the problem 3 months ago. I would only make the grinding noise when it powered up. Printing was okay. I don't use the printer that much. Then about a week ago I notice only the bottom diagnostic light was on. I unplug the power and powered it back up. The grinding noise got louder and wouldn't stop. I unplugged the printer an replugged. Same thing.
I was bored (christmas day) and decided to open my printer to see what the root cause problem was. I removed several screws and once I got all the printer naked (removed all the plastic outside). I plugged it in an tried to listen where the problem was. I notice a vibration at the laser scanner (top black piece). I unplugged the printer. I unplugged the power source to the laser scanner. Replugged the power and saw all the gears move with no noise. Powered off. Replugged laser scanner. Powered on. Noise back. Defective laser scanner. The laser scanner has a ribbon cable, and four purple wires going to it, oh yeah there is a big yellow warning label, so you can't miss it. I hope this helps.
Nov 26, 2008 | HP LaserJet 1200 Printer
Whether my printer is a LASER printer
You can call hp tech support toll free number - 1-800-585-2494 and they will give you all information regarding to your printer. for more information you can visit: HP Customer service .
Hope this will help you better.
May 22, 2008 | HP DeskJet F380 All-In-One Printer
No installation disc for a hp 12OO SCANNER/PRINTER
Here you go to download drivers
Download
Rate me as FIXYA if u got help!
Mar 23, 2008 | HP PhotoSmart 1200 Photo Scanner
Printer noise
check here to see if that upgrade is in their service support area yet..
Jan 21, 2008 | Samsung SCX 4521F All-In-One Laser Printer
HP LaserJet 1200 Printer Logo
113 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
