Hi, I'm Leo from Indonesia, I have prbolem with my camera, if i want get a picture, i must be turn off then turn on the power, and i get one picture, if i want get more, its must be turn off again, so i cannt get continuesly, just one pic, off again, on, one pic, can i get the solution? thanx before
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You may have a weak battery. If the flash doesn't have enough power, it will continue to try to recharge thus preventing you from taking a picture. Turning it off allows the pic to be taken.
Hi dear, you can download the manual from (http://www.retrevo.com/support/Kodak-C330-Digital-Cameras-manual/id/200bh336/t/2/) this site. All you need is inside. Have FUN !
You should have a pic review when the canera is powered on. Some cameras have a review only power switch that allows the screen to view pic s but not turn on the camera. there should be a delete button that once you are reviewing your photos you can delet one at a time or it will say "delete all" click delete all and enter to delete all. if you can find no review or delete buttons they will be in the main menu. Good luck!!
hi , transfer your pic in the movie maker , i know you can retuch them , make it brihter,if you cant, just buy magix movie pro 12 good programme and cheap too yvon chow !!!
Hi,if dont have any very important picture stored in camera you may reformat it all protect picture will erase , the camera sim has no more vacant its full you connot store picture anymore best solution is to reformat it.press menu , press setup,navigate down select format. then okey.
hi Jignesh,
I hope you are enough better technician. If you believe in yourself, go ahead but take care of your camera. Pls follow as under
- Remove the battery.
- Safely remove the back but mind well there is delicate flexible circuit over there, if so, then gently plug out the flexible circuit from the connector.
- locate the play back switch.
- lube with a Philips switching oil.
- aftr 2 min press the playback switch several time with backside of wooden toothpik.
- Take care of high voltage inside.
then fit the camera.
- Goodluck you will do it
