Question about RCA DRC8052N DVD Recorder
Recording Length Not As Indicated
In "3 Hour" mode disc fills up after 2 hrs 47 mins, in "8 Hour" mode disc fills up after 7 hrs 6 mins. Obviously the recording bit rate is too high.
Any chance of a software update ?.
RCA's solution (after 15 mins on hold) "unplug the unit for 5 mins"
Uh huh.
  • walterb-sfo Sep 29, 2008
    My unit doesn't have a hard drive.
    This is happening with DVD-R and DVD+R discs
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 106 Answers
Hi. Yeah, RCA soutions are worthless. What happens is that the hard disk loses recording time while in use. Like a hard disk losing clusters on a computer and making them unusable. To get that recording time back, you will need to reset the unit. To do this, go to the main menu, press and hold the play and open buttons on the front pannel for about 7 seconds. This will reformat your hard disk. Keep in mind that reformating will erase all data. I have looked up and down for some type of firmware/software update and RCA support told me to disconnect the unit..press the power button 10 times and connect again!!???!?!? How silly. Hope this helps :)
Posted on Sep 29, 2008
I cannot find my manual what is the speed to record on the vcr for 8 hours
Unfortunately, most VCR recorders/tapes don't have an 8 hour option. It is 2 hours on SP (standard), LP for 4 hours or EP (SLP, depending on the unit) for 6 hours. (The slower recording speed usually gives poorer video quality.)
You would need a non-standard VCR cassette to get 8 hour recording. If you do have a tape that would hold 3 hours at SP, then use an EP setting to get 8 hours of recording on your VCR. I don't think I've seen any tapes that do that recording length even when VCRs were popular.
I wish that I had better news.
Jan 28, 2012 | Sansui COM311AD 13 in. Combo
EVERYTHING YOU NEED IS IN MY LETTER BELOW.
1. On your remote, find the record mode button; it is near the bottom on the left side. This button sets
the recording speed for the DVR. Faster recording speeds provide higher quality recordings.
2. Look at the display on the front of the machine: it should say XP ( records 1 hour on the disc,)
SP ( 2 hours, ) LP ( 4 hours, ) or EP ( 6 hours. ) You can also set it to record 8 hours on a disc,
but the quality of the recording will be poor.
3 Press the record mode button until the screen displays the recording speed that you want.
4 Note: if the powers fails or the Machine is unplugged, the machine will automatically reset itself to
SP mode.
Apr 29, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
I'm trying to copy old family videos from VCR to DVD. I'm using the correct disc type (DVD-R) and there's no copy protection. I've tried both Sony and HP discs. Each time, it seems to be working but...
First, try to refinalize the disc if it failed the first time by going into the edit menu. Sometimes finalization just fails the first time.
If you are recording on 2-hr mode, and the length of your recording is an 1hr 50 min or more, there will not be enough space left on the disc to finalize. Going forward, your best solution would be to record in 3- or 4-hour mode for every 2 hrs worth of recording (6-hour mode for 3-5 hours of recording, etc.). Just to quickly decipher recording modes: 2-hr mode (sometimes called SP Mode, depending on DVD player) will record about 2 hours worth of material on a standard blank DVD (but some extra space would be required for finalization); 4-hour mode would record 4 hours worth of material on a standard DVD; 6-hour mode would record 6 hours, etc.
As far as salvaging the recordings you have already made - load the burned, yet unfinalized DVD's into your computer. Copy the files onto the desktop or some easy-to-find location on your computer. Then use a program, free or otherwise (I personally reccomend Nero or Roxio), to re-burn the discs. The newer version of Nero automatically finalizes the disc, but some software requires you to select an option that allows you to "close disc" or "finalize" the disc. (In computer lingo, "closing" means the same thing as "finalizing").
-Tha Mp3 Doctor
Mar 04, 2009 | GoVideo Go Video VR3840 DVD Recorder/VCR
Recording from VHS to DVD
First, you will need to know if the program was recorded in XP mode, SP mode, LP mode, or EP mode. To find out how much room there is left, put the dvd in the tray and press the Disc Menu/List button on the JVC remote. This will display the title and how long it is - write that number down. It will also say either "XP,SP, LP, or EP" - write down that mode. In XP mode, a DVD will hold 1 hr and 20 mins worth of prgramming - MAXIMUM. SP mode = 2 hours. LP mode = 4 hours. EP = 6 hours. So, if your program is one hour, and you recorded in LP mode, you have 4 - 1 = 3 hours of space left for recording on that disc.
If you finalize a disc, you will no longer be able to add more programs to that disc, unless the disc is a + or - RW disc. Also note that finalization requires some disc space, so if you recorded a program that is exactly 1hr and 20 mins long, and you recorded it in XP mode, then the disc will probably not finalize correctly.
That being said, the finalization directions are on p. 23 of your manaul: Title --> Finalize --> => --> find finalize --> Enter --> OK --> Enter
Now it will play on other players.
Here is a link to the user manual:
http://resources.jvc.com/Resources/00/00/93/LPT1133-001A.pdf
-Tha Mp3 Doctor
Dec 31, 2008 | JVC DR-MV7 DVD Recorder/VCR
I am recording fron VHS to DVD. When I am finished and push the stop button, How can I tell how much space is on the DVD to record something else and how do I finish the dik so it can't be recordered over
JVC DVD Recorder – Finalizing and disc space
-Tha Mp3 Doctor
Disc playback
are u sure about the media type tat is supported in ur cam.
Jun 16, 2008 | Samsung VP-DC161 DVD Camcorder
DVD copying
There are double layer DVD's that they make which usually have about 2x the memory. check to see if your DVD recorder supports these types of DVD's. You could also just divide your media on to two sides of a double sided DVD (each side has the mirror look and you can record onto both sides)(still the same disc) or you could record on to multiple DVD's (may be inconvenient but is still an option). Also, you could reduce the recording quality just a bit so that it is not noticable when you watch it but it still uses less space on the disk. I would tell you how to do these things but I have no experience with the individual model that you have.
Mar 22, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Using FRec to record on DVD-which mode does it record in?
You seem to have fixed your own problem. Yes, the Flexible recording function only works on scheduled recordings. However, you should be able to do direct recording with FR - but when you press the F.Rec button for a direct recording a notification should come up on-screen asking you the amount of time to record. This is on page 16 in the manual. If you started the recording without being on the correct input for the DVD recorder on the TV, you would not have seen this message and the unit would default to EP 6 or 8hr. (based on settings).
Obviously the FR swaps between bit-rates to fill the disc completely, so you would see the recording tracks had almost completely filled the disc when done.
Also, some older DVD players, even if the disc type is compatible and finalized, do not read VBR recorded DVDs - so that my be another issue.
Hope this helps.
Feb 21, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Lg rh266 recorder
When you put your disc in and its ready for copying over through Dubbing - when you see the quality ie xp - just press right or left til the FAST sign comes up. it maynot always come up if the recording time is any longer than an hour or less than 30 mins.
pg 47 of your manual
Regards Chris
chrisbradley80@gmail.com
Dec 20, 2007 | LG RH266 Recorder
How long can I record using a DVD-RAM disc?
• Extra Fine mode (3-9Mbps record speed): Approx. 20 min. minimum per side. • Fine mode (6Mbps record speed): Approx. 30 min. per side (1 hour total). • Standard mode (3Mbps record speed): Approx. 1 hr. per side (2 hours total).
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
RCA DRC8052N DVD Recorder Logo
71 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
