SONY - PFM-500A2WE 16:9 42-inch Plasma fault 22-12
When switched on, the display starts to power up ie, the fans start running for about 5 secs and then it shuts down and displays the above error code. How do I know if the panel has failed or just the power supply failure? Please advise, thanks!
12 22 meanseither the Plasma Panel has failed or the Power Supply has failed. 12means "warning decrease of panel high voltage" and 22 means "warning ofdecrease of middle panel voltage".
  • 2 more comments
  • Anonymous Dec 07, 2008
    Same as above...
  • Rob 3 Mar 15, 2009
    Same problem 12/22 error code, but if it is the voltages which ones to look for and what readings should they give. thanks
    same as above 12/22 error code but what voltages to check if it is power related, VRS VA etc... 185VDC 65 VDC??? thanks
  • Anonymous Mar 30, 2009
    i'm having the same problem with my tv. the problem started just after a move. i believe it has something to do with that because it worked perfectly prior to the move.
  • 3 Answers
Hi I have found what goes wrong in this screen!
if you take it apart and email me i will send you a photo of the different things to look at for !
i have spare parts if any of your problems are not the same as mine!
Posted on Jun 11, 2010
I have a Sony PFM-42B1E, I switch it on and it powers up for a couple of seconds with a flash of snow on the screen then power light flashes 3 times, I opened it up and disconnected the ribbon power cable...
ok,..if originally u were having some image problems of a snow like flash on the screen,..then i would advice u to replace that DMD board,..the board u disconnected the ribbon power cable from.
Apr 02, 2010 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Sony PFM 500A2WE 12 22 error code
The error indicates issue with the power supply and the deflection stage, Check first the cable. If you plan on troubleshooting this yourself check first the warranty. Inspect the power supply circuit if there are leaking capacitors. As for the deflection stage I would recommend a technician to have this checked.
Aug 04, 2009 | Sony PFM-500A2W 42 in. Television
The error code tyo which you refer was truncated off of your posting. Could you please enter that code again? That code will assist us in determining the problem circuit.
Feb 09, 2009 | Sony PFM-500A2W 42 in. Television
My sony Sony PFM-42B1 blink 5 times
When a Sony TV flashes five times, that means that there is an AKB circuit fault.
This means that there is something wrong with the video.
Try first unplugging power for few hours, if that does not work, call a technician, as several IC and components must be tested and eventually replaced.
Sep 27, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Sony PFM-42B1
Your PDP panel is duff - Only a replacement will repair.
Jul 16, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
PFM-42b1e LEd flashing 6 times... 1 sec. picture with green stripes... and then it turned to standby
I have a sony tv PFM-42B1 when I turn it on it go to standby an a red light flash I count count 14 time but I heard that it only support to flash 1 to 6 time how do count the flash
May 06, 2008 | Sony PFM-42B1 42 in. HD-Ready Plasma...
Sony Plasma PFM 50 ci black screen
. Check blink of leds
check the 5 v control voltage.
check Ysus and Zsus board.
check Voltage sc, Vs and Voltage a .
Yareth De Matos - Venezuelan -
Mar 28, 2008 | Sony PFM-50C1 50 in. Plasma HDTV
According to the Sony Service Manual for the PFM-500A3WU, 12 22 means either the Plasma Panel has failed or the Power Supply has failed. 12 means "warning decrease of panel high voltage" and 22 means "warning of decrease of middle panel voltage".ve had a look on other forums and someone as narrowed the 12/22 code down to the (ic102) its only outputing 5volts its something to do with the (b+ power supply)
Feb 01, 2008 | Televison & Video
My monitor fails to start and the power pack shows 12-22 repeatedly
Howdy, I guess you're talkin' about a : Sony PFM-500A2W Plasma screen ?? The fault-codes your talkin'about " 12/22 " + continue re-starting " is a common problem with those plasma screens. It gives an " low power " message on the PDP module . We started today a discussion-group at to get a clear picture at the Sony. We allso placed a " fault-code " list , so users can see what those codes are standing for. The main target of the discussion-group is ..... sharing knowlegde and information about the Sony PFM-500A2W. Schematics Problem solving fault finding Where to get any kind of parts. Print layouts etc. etc. The followin' link shows the discussion group. Please give us some time to startup the group. So don't give up any hope ;-) Best regards , EuroNet 2000 The Netherlands
Feb 07, 2007 | Sony PFM-500A2W 42 in. Television
Televison & Video Logo
497 people viewed this question
Top Televison & Video Experts
