Question about HP Officejet Pro L7680 All-In-One Printer
Carriage jam error
Open print carriage access door, clear jam and then press ok.
I thought I did this but where is the print carriage access door?
  • 2 more comments
  • Anonymous Aug 10, 2008
    paperjam cleared, but machine continues to advise that print head access door is open.
  • Anonymous Sep 04, 2008
    clear print cartrage door
  • mghelich Dec 14, 2008
    For me is not jam because of a piece of paper....when the carriage istrying to move to all the way to the right (where you can replace the cartridge heads) it get's stuck.
  • Anonymous Mar 22, 2014
    all doors are closed but print carriage access door indicator on
    Novelist:
  • 106 Answers
Here is the document that i want you to follow exactly in order to resolve your issue.
CLICK HERE TO VIEW THE DOCUMENT.==>> DOCUMENT
Please let me know the result after following the document.
Thank you so much. I remain.
adonscott
Posted on Jul 24, 2008
I did everything that the instructions stated and still had the problem. It ended up being a very small piece of paper stuck where the printed document comes out. You could not see it in the slot. I used a small pair of tweezer to slide along the edge and that is how I found the paper. It was very difficult to remove because that section of the machine does not come apart. It took much patience!
Posted on Oct 23, 2008
Lift the printhead latch, ther could be some paper stuck in the side , I just did it, now everything is ok!!!!
Posted on Sep 04, 2008
Print head jam
Check the LCD on your printer control panel or the status monitor on your computer for an error message. If there is an error message, follow the instructions to clear it.
If there is no error message, or if the problem continues:
  1. Open the access door.
  2. Disconnect the power adapter from the back of the printer.
  3. CAUTION: Do not use force on the printhead carriage to move it. Gently move the printhead carriage from side to side to see that it moves freely and there are no obstructions.
  4. Remove any obstructions that may prevent the printhead carriage and ink cartridges from moving to the center position.
  5. Close the access door.
  6. Connect the power adapter to the printer.
  7. Remove the ink cartridges from the printhead.
  8. Verify that the labels on the ink cartridges are intact, and that the cartridges are not damaged.
  9. firmly until you hear it click into position.
  10. Insert the color ink cartridge into the printhead, then press down firmly until you hear it click into position.
  11. Close the printer access door.
  12. Press OK to clear the error.
  13. Make a print.
May 06, 2014 | Kodak Office Hero 6.1
Get paper jam message, paper is marked at the begining of the sheet but not jammed. When select copy button ,there is no paper jam problem, only when print command is used to print a document
Please follow this instructions to resolve your issue.
Solution # 1 Power cycle the printer
  1. Turn off the printer
  2. Unplug the power cable at the back of the printer
  3. Wait for at least 1min.
  4. Plug the power cable again
  5. Print test page using the printer itself (press and hold the OK and HELP buttons on the front panel of the printer, until it will prints a test page, then release the buttons.)
If you still having that error message, please proceed to the next step.
Solution #2 Clear any jams on the printer itself
  1. Turn off the printer.
  2. Please make sure that you will not take out any jammed papers in front of the printer, it can cause a mechanical damage on the printer.
  3. At the back of the printer, take out the access door.
  4. Clear any jammed papers, please make sure to clear the rollers.
Solution #3 Please make sure that the carriage will moves freely
  2. Open the cartridge access door
  3. Disconnect the power cable at the back of the printer.
  4. Check for any paper or other object that might restrict the carriage movement.
  5. Reach inside the product through the cartridge access door, and then manually move the carriage.
  6. Remove any paper or objects you find that restrict the movement of the carriage.
  7. Make sure the carriage can move freely across the width of the product. Firmly push the carriage to the left, and then to the right.
  8. Close the cartridge access door.
  9. Reconnect the power cable to the rear of the product.
  10. Press the power button to turn on the printer.
  11. Print test page using the printer itself (press and hold the OK and HELP buttons on the front panel of the printer, until it will prints a test page, then release the buttons.)
If your still having issues with it you need to contact HP to have your printer replace, if your printer is still in warranty you don't need to pay for anything, but if the printer is out of warranty charges may apply. 1800-474-6836
Good luck :)
Feb 17, 2011 | HP Photosmart C5180 All-In-One InkJet...
Copier makes a noise when first turned on and then it tells me to open the door clear carriage jam and press enter. But that does not work. The printer has been sitting for a little...
Check the following steps for fixing Hp Carriage Jam Error :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Nov 29, 2010 | HP PSC 1600 InkJet Printer
I have paper jammed in my HP DESKJET PRINTER D2260. Tried to pull it out but paper ripped off and can still see other end still in there. Been advised to open back door and clear it but cant see how back...
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
Nov 18, 2010 | Office Equipment & Supplies
Paper Jammed. Have appeared to remove all paper. But I keep getting "Carriage Jam, open door, clear carriage jam then pres OK" message. Message on my computer screen says "The print cartridge carriage is...
HP support has extensive documentation for both paper and carriage jams for your model:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00304007&lc=en&dlc=en&cc=us&lang=en&product=391182
I hope this helps!
Dec 10, 2009 | HP OfficeJet 7310 All-In-One InkJet...
My printer made a weird noise and now says "Open door Clear carriage jam and then press Enter". How do I clear a carriage jam? I have opened the top cover and usually the print cartridges move to the...
Issue The error ' Open Door, Clear Carriage Jam, and then Press Enter ' displays on the product. The following symptoms might also accompany this error:
* The product will not print. * Printing stops unexpectedly. * The carriage does not move.
Try the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting. Solution one: Turn the All-in-One off and on again
1. Press the Power button ( ) to turn off the product. 2. Press the Power button ( ) to turn the product on again.
* If these steps resolved the issue , you do not need to continue troubleshooting. * If the issue persists , continue to the next solution.
Solution two: Clear any paper jam A carriage jam might follow a paper jam. Follow these steps to check for and remove any jammed paper. Step one: Check for and remove any loose paper from the input tray Remove any loose paper from the input tray, the output tray, and the automatic document feeder (ADF). CAUTION: Do not remove jammed paper at this stage. Step two: Clear a paper jam from the rear access door WARNING: Always clear paper jams through the back door if possible. To avoid tearing the paper and damaging the print mechanism, pull paper from the printer slowly and gently. Avoid touching the internal components of the printer.
1. Disconnect the power cord from the back of the printer. 2. Remove the back door and remove as much jammed paper as possible.
3.Replace the back door and open the carriage access door. If there is paper visible that cannot be removed through the back door, gently pull it out from the front.
4. Reconnect the power cord and close the printer.
Solution three: Make sure that the carriage moves freely
1. With the product turned on, open the cartridge access door. The carriage might try to move into the access area. If so, allow it to move to that position. 2. Without turning off the product, unplug the power cord from the back of the product. WARNING: You must disconnect the power cord to move parts by hand without the risk of an electrical shock. 3. Look in through either the cartridge access door or the output paper tray to make sure that the cartridges are secure in the carriage and not loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving. 4. Make sure the carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found. You might have to reach through the output paper tray to access the carriage. 5. Close the cartridge access door and reconnect the power cord to the product. 6. Press the Power button ( ) to turn on the product.
Solution four: Remove and reinsert the print cartridges Incorrect installation of the print cartridges can cause the product to show a false carriage jam. Follow these steps to remove, and then reinstall the print cartridges. Step one: Remove the print cartridges
1. Press the Power button ( ) to turn off the product. 2. Open the front of the product to access the carriage. The carriage moves to the center of the product.
3. Unlatch the two print cartridge latches, and then raise the latches. 4. Remove the print cartridges.
Step two: Reinsert the print cartridges
1. One at a time, hold a print cartridge with the printed label up, and then slide the print cartridge into its slot. Repeat this step for the other print cartridge.
# NOTE: Insert the black print cartridge into the slot with the gray latch, and insert the color cartridge into the slot with the blue latch. # Grasp the end of the latch on the cartridge slot with your thumb, and then pull the end of the latch toward you. While holding the latch, press down on the top of the latch until it stops, and then release the end of the latch so that it catches under the tabs. CAUTION: To avoid damaging the product, do not force the latches into place.
3. Close the product cover. A message displays on the control panel to align the print cartridges. 4. Press the Enter button to begin the cartridge alignment. Two pages print. Follow the instructions printed on the second page to complete the alignment. 5. Try the print job again.
Jul 08, 2009 | HP PSC 2175 All-In-One InkJet Printer
Print cartridge carriage is stalled
There are a few steps to follow to check the Printer.
Step one: Turn the All-in-One off and on again
  1. Press the On button to turn the product off.
  2. Press the On button again to turn the product on.
If the error message is not resolved, continue to the next step. Step two: Clear any paper jam Follow these instructions to clear a paper jam. CAUTION: All paper jams must be removed from the back of the product through the rear access door. Pulling the paper from the front of the product rotates the paper feed roller in the wrong direction and can damage the product.
  1. Turn off the product and unplug the power cord.
  2. Turn the product around to access the back of the product.
  3. Open the rear access door:
    1. Locate the tab on the left side of the door and press it toward the right. The door will shift slightly to the right.
    2. As the door shifts to the right, pull the door out slightly to release.
    3. When the door is released, gently remove the door by sliding the door out and to the left.
    1. From the rear access opening, gently pull the jammed paper out of the rollers.
    NOTE: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the product. If all the pieces of paper are not removed from the product, more paper jams are likely to occur.
    1. Replace the rear access door:
    2. Insert the two posts on the right of the door into the holes on the right side of the opening.
    3. Press the tab on the left side of the door toward the right. The door will shift slightly to the right.
    4. As the door shifts to the right, push in the left side of the door to lock it into position.
    5. Reconnect the power cord and turn the product on.
    Step three: Make sure that the print carriage can move freely Follow these instructions to make sure the print carriage can move freely.
    1. With the product turned on, open the print cartridge access door. The print carriage might try to move into the access area. If so, allow it to move to that position.
    2. Without turning off the product, unplug the power cord from the back of the product. Unplug the power cord from the power source. The power cord must be unplugged to allow the parts to be moved by hand and to reset the paper feed mechanism, without the risk of an electrical shock.
    3. Looking in through either the print cartridge access door or the output paper tray, make sure the print cartridges are locked into the carriage and have not come loose. Also, make sure that there are no obstructions under or around the carriage to block it from moving.
    4. Make sure the print carriage can move freely across the width of the product by gently pushing the carriage to the left and then to the right. Clear any obstructions found. You may have to reach through the output paper tray to access the print carriage.
    5. Close the print cartridge access door and plug the power cord back to the back of the product. Plug the power cord into the power source.
    6. Press the On button to turn on the product.
    If the error message is not resolved, continue to the next step. Step four: Remove the print cartridges Improper placement or installation of the print cartridges can cause a carriage stall error condition. Follow these instructions to remove the print cartridges.
    1. Make sure the printer is turned on.
    2. Open the print cartridge access door, and then wait until the print carriage is idle and silent.
    Press down lightly on the end of each print cartridge to release it.
    • The tri-color print cartridge is on the left.
    • The black or photo print cartridge is on the right.
    Slide both cartridges out and place them on a clean sheet of paper. CAUTION: Do not touch the ink nozzles or copper-colored contacts. Touching these parts could result in clogs, ink failure, and bad electrical connections. Do not remove the copper strips. They are required electrical contacts.
    1. Disconnect the power cord.
    2. Move the carriage all the way to the left with your hand.
    3. Close the print cartridge access door.
    4. Reconnect the power cord.
    5. Turn the product on, if necessary.
    6. If the error message is resolved, the placement of the print cartridges caused the problem. Complete Step five: Reinstall the print cartridges. There is no need to complete any steps after Step five.
    If the error message is not resolved, complete Step five: Reinstall the print cartridges, and then continue with the subsequent steps. Step five: Reinstall the print cartridges step 6, Partial reset Follow these instructions to perform a partial reset of the product.
    1. Turn the product off by pressing the On button.
    2. Unplug the power cord from the back of the product.
    3. Plug the power cord back into the product.
    4. Turn the product on by pressing the On button
    1. Load letter, A4, or legal unused plain white paper into the paper tray.
    2. Press the Setup button until Print Report appears, and then press the OK button. Self-Test Report appears on the control panel display.
    3. Press the OK button. The product prints a self-test report.
    Hopefully fixing the problem for you
    Regards
    Richard.
    Apr 26, 2009 | HP PSC 1610 All-In-One InkJet Printer
    HP Officejet 5110 - Carriage Jam Message
    I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
    I tried pressing the # & 6 at the same time, but the error message still there.
    Mar 09, 2008 | HP OfficeJet 5110 All-In-One InkJet...
    HP Officejet Pro L7680 All-In-One Printer Logo
    2,336 people viewed this question
    Vinaya Kumar...
    Vinaya Kumar...
    Seeker5211
    Seeker5211
