Hoover premier 710 washing machine out of balance
  • john727 Jul 24, 2008
    There is a regular thump when the spray commences starts during the spray rinse cycle and during the spray spin cycle.
    There is no thump during the spin cycle.
    Recently the cold water inlet valve was replaced.
    The washing maching is of the Whirlpool top loading type.
    Thank you.
    I will take the back off in a few days and let you know what I find.
    Thanks again,
    John
    Brigadier General:
  • 6,966 Answers
It would appear that a Hoover Premier 710 is a basic 4kg top loading washing machine. Often top load washing machines would have 3 or more suspension (spring) system/shock absorber that are responsible for maintaining the upright balance of the outer tub. If the washer has been in operation for some time, it is likely that these support/suspension/spring may have developed a fault. In some other instances, it could be the mounting points of these suspension/spring that may require looking over. It would be necessary to open the back and inspect all components of the suspension system. Additionally, if one is found defective, it may be to your advantage to replace all so as to impose an equal tension/support to the tub.
Alternately, in some versions/models, it could simply be the balance sensor switch that is false triggering. Again, this would require opening the unit and determining if this switch/sensor is defective.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 24, 2008
  • 2,071 Answers
WHAT IS WRONG WITH YOUR WASHING MACHINE?
hoover premier 710 washing machine - small_11_21.jpg For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Stylhoover premier 710 washing machine - redarrow.gifimg src="http://i.fixya.net/uploads/images/redarrow.gif" alt="redarrow.gif" class="h_mi" /> Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gifFront Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
  • LORETO LACARON
    LORETO LACARON Jul 24, 2008
    Check the drive block the spin basket rides on, it could be wallowed
    out, making this noise....the thumping on stop would be the basket
    riding over the two tabs of the spin tube, the whinning would be the
    plastic filter on the bottom of the basket rubbing on the bottom of the
    fiberglass tub because the basket has dropped down too low into the
    tub.....
I need the lid for hoover premier 710 4 kg.washing machine. model A6578, serial no. 091383
only from hoover agent spares , machines at the dump or washing machine repair shops who may have some as spares
Mar 28, 2017 | Hoover Washing Machines
My washing machine (hoover VHF 710 front load) does not take up fabric softner from the compartment. thanks
Could have something clogging the port. You're 110% sure you're following the directions EXACTLY as you're supposed to?
Reason I ask is because it can sometimes look as though it should go in one spot, only to read the instructions and find that it actually goes in another.
Sep 02, 2012 | Hoover Washing Machines
How to use hoover premier 750?
what are hoover use for and how to use it
Nov 15, 2008 | Hoover Washing Machines
Hoover 710 top loader washing machine
turn it to one side,look the bottom,the belt may broken,it look like a car fan belt.
Nov 09, 2008 | Hoover HTC243 Top Load Washer
Hoover Premier 710 - always fills to capacity (can't adjust water level).
my one the same, I just adjust the water level switch to 60% then it work on full level, but no flood,I hope this help :)
Apr 30, 2008 | Hoover HTC243 Top Load Washer
Washing Machines Logo
492 people viewed this question
Top Washing Machines Experts
