Question about E-Machines Computers & Internet
Need #9 cd for system recovery repair on my office computer. Mine is not working.
  • 2,794 Answers
You can order them from E-Machines website at www.emachines.com
Posted on Jul 24, 2008
Solutions for "HP Pavilion dv5
File: \BOOT\BCD Status: 0xc000000F Info: An error occurred while attempting to read the boot configuration data. First try going into Windows safe mode with command line utility enabled. (F8 on bootup). In command console typechkdsk /f /r and enter Y for yes at the prompt. Wait for it to finish, it may take a while and then test the issue. If the problem persists, please continue with the following instructions. Rebuild BCD 1. Put the Windows Vista installation disc in the disc drive, and then start the computer. 2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears. 3. Select a language, a time, a currency, and a keyboard or another input method, and then click Next. 4. Click Repair your computer. 5. (Click the operating system that you want to repair), and then click Next. 6. In the System Recovery Options dialog box, click Command Prompt. 7. Type BOOTREC /FIXMBR, and then press ENTER. 8. Type BOOTREC /FIXBOOT, and then press ENTER. 9. Type BOOTREC /REBUILDBCD, and then press ENTER. Use the Windows Recovery Environment (WinRE) to run System Restore 1. Insert the Windows Vista installation disc into the disc drive, and then start the computer. 2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears. 3. Select a language, a time and currency, and a keyboard or input method, and then click Next. 4. Click Repair your computer. 5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next 6. At the System Recovery Options Dialog Box, click on System Restore. 7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point. 8. Click Finish to restore the system. Startup Repair from the Windows Recovery Environment (WinRE) 1. Insert the Windows Vista installation disc into the disc drive, and then start the computer. 2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears. 3. Select a language, a time and currency, and a keyboard or input method, and then click Next. 4. Click Repair your computer. 5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next. 6. At the System Recovery Options Dialog Box, click on Repair your computer. 7. (Click the operating system that you want to repair), and then click Next. 8. In the System Recovery Options dialog box, click Startup Repair
finaly if you do not have the cd you can use a copy too.
Kronoguy
Jul 04, 2011 | Computers & Internet
My Pc is CI3003X and it has stopped booting. I need a Repair CD. Is there a website I can download the file to burn to a Recovery CD. My email address is rolbri@rlws.com. My name is Cal Briggs. I...
> I received no CD's when I purchased ... would like to build a Recovery CD.
If OFFICE MAX won't supply a CD, or give you any other technical support, as part of the "warranty" that they offered when you purchased the computer, you might be able to telephone the manufacturer of the PC, and order a set of "System Restore" CD/DVD disks.
Or, if your computer still is running Windows, there should a utility program that you can run, in order to "burn" your own set of "System Restore" disks.
> it has stopped booting ...
Totally?
When you first turn it on, do you see any message like "Press <BLAH> to change boot-order" or "Press <BLAH> to run System Recovery" ? If so, then press the <BLAH> key, to see if your computer has a "hidden" area that can be used to "restore" your computer to its "factory" settings.
Nov 30, 2010 | Computers & Internet
I have a Toshiba Notebook L300 series. My Window Vista will not load fully. it states I need a file C:/windows\system32\systempropertiesprotection.exe. I have looked on line but found nothing.
Hi the file is missing if you have a recovery disk or the operating system CD you need to use it to repair your computer.Please follow these steps:use recovery disk for the computer if you have one. If you don't do not have a recovery disk for the computer you can use the operating system disk to repair it, please follow these steps: insert the operating system disk into the CD/DVD drive, restart the computer, press F12 and choose boot from CD save and exit. As the computer loading it will ask you to press any key to boot from CD, press any key, a blue screen will appear while its loading, when it get to the first set of options you will press enter to continue. when it get to the second set of options it will ask you to install the operating system or repair it, choose repair and follow the steps from there, once you choose repair, then computer will go through different stages. The next step is to enter the keys for the operating system the the computer will continue until it finish the repairs and this should solve the problem of missing files. But you should backup your files before doing this even though no file will be lost but its better to backup just in case something goes wrong. Backing up the file is always an important part of having a computer, you should also create a recovery CD and this can be done during the process of backing up your computer files. The back up files should be store on one or more DVDs and this along with the recovery CD should be store in a safe place and dry place. The purpose of the recovery CD is to repair damage or missing files from the computer and each computer require its own back up and recovery disk to repair the problem.
Jul 13, 2010 | Toshiba Computers & Internet
NTLDR MSSING, how can i solve this?
NTLDR is short for NT loader – a program loaded from the hard drive boot sector that displays the Microsoft Windows NT startup menu and helps Microsoft Windows NT load. So when it goes missing for some reason, your windows cannot load.
Cause:
1. Computer is booting from a non-bootable source.
2. Computer hard disk drive is not properly setup in BIOS.
3. Corrupt NTLDR and/or NTDETECT.COM file.
4. Misconfiguration with the boot.ini file.
5. Attempting to upgrade from a Windows 95, 98, or ME computer that is using FAT32.
6. New hard disk drive being added.
7. Corrupt boot sector / master boot record.
8. Seriously corrupted version of Windows 2000 or Windows XP.
9. Loose or Faulty IDE/EIDE hard disk drive cable.
if there is attached drive ,remove the drive first before restarting the system if not then if you had access to another computer, copy the NTLDR and NTDETECT.COM which is available from the recovery CD which comes with computer. If you do not have the recovery CD, its available on microsoft site or is available from another computer using the same Operating System (Windows XP ). The location may be C:\i386\ntldr C:\i386\ntdetect.com use a bootable disc to restart the computer (the Win XP bootable CD or Win 98 bootable CD worked). After entering MS DOS mode, copy these 2 files to the C drive in the proper location. After restart, then pressing F10 on start up (used for system recovery ), then start the repair of Windows via system recovery This will reinstalled all Windows drivers and system files, while preserving all data on your computer.
Sep 16, 2009 | Computers & Internet
How to access the recovery console from startup
1. Insert the installation disc.
2. Restart your computer.
Click the Start button , and click Restart.
3. If prompted, press any key to start Windows from the installation disc.
Note:If your computer is not configured to start from a CD or DVD, check the information that came with your computer. Just tap F12 while booting to force boot from cd or You may need to change your computer's BIOS settings to boot from cd. 4. Choose your language settings, and then click Next.
5. Click Repair your computer.
6. Select the operating system you want to repair, and then click Next.
7.
On the System Recovery Options menu, click a tool to open it.
If your computer has preinstalled recovery options:
1. Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer.
2. Do one of the following:
• If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you will need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
• If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to repair, and then press and hold F8.
3. On the Advanced Boot Options screen, use the arrow keys to highlight Repair your computer, and then press ENTER. (If Repair your computer is not listed as an option, then your computer does not include the System Recovery Options menu as a preinstalled recovery option.)
4. Select a keyboard layout, and then click Next.
5. Select a user name and enter the password, and then click OK.
6. On the System Recovery Options menu, click a tool to open it.
Please take time to rate this fixya.
May 11, 2009 | Toshiba Satellite A105 Notebook
My PC need help
one chance is there for you. just do a repair which HDD drive is detecting win32 missing. just follow these steps.
Please read carefully and make sure you followed the warning links before initiating
the Repair Install. You can print a text version for reference. repair.txt
1. Boot the computer using the XP CD. You may need to change the boot order in the
system BIOS so the CD boots before the hard drive. Check your system documentation
for steps to access the BIOS and change the boot order.
2. When you see the "Welcome To Setup" screen, you will see the options below
This portion of the Setup program prepares Microsoft
Windows XP to run on your computer:
To setup Windows XP now, press ENTER.
To repair a Windows XP installation using Recovery Console, press R.
To quit Setup without installing Windows XP, press F3.
3. Press Enter to start the Windows Setup.
do not choose "To repair a Windows XP installation using the Recovery
Console, press R", (you Do Not want to load Recovery Console). I
repeat, do not choose "To repair a Windows XP installation using the
Recovery Console, press R".
4. Accept the License Agreement and Windows will search for existing Windows
installations.
5. Select the XP installation you want to repair from the list and press R to start the
repair. If Repair is not one of the options, END setup. After the reboot read
Warning
6. Setup will copy the necessary files to the hard drive and reboot. Do not press any
key to boot from CD when the message appears. Setup will continue as if it
were doing a clean install, but your applications and settings will remain intact.
Apr 05, 2009 | Computers & Internet
How to do a system recovery when my cd rom drive doesnt work?
got to have a new cd-rom drive mate, most practical approach.
other options are network boot (done in offices with many computers), USB boot (if your BIOS supports it & you need to have a USB device with the bootable image of the system disk), etc.
Jan 26, 2009 | Computers & Internet
I put the computer on and it says tht an error occured while attempting to read boot it and the error code is 0x000000f and it was my daughters christmas box please can u help.
I'm assuming you have vista installed.If not,please reply and I will update this info.
Method 1: Startup Repair from the Windows Recovery Environment (WinRE)
2. Press a key when the message indicating "Press any key to boot from CD or DVD …". appears.
7. Click the operating system that you want to repair, and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
Method 2: Rebuild BCD
5. Click the operating system that you want to repair, and then click Next.
Please rate this solution.
Jan 17, 2009 | Computers & Internet
Windows Programs Won't Work
if u opt for system recovery the syatem settings rolls back to best worked config at that time your registry entries also changes so this problem occurs if you need the keys of microsoft word ill give it to you tell me which version are u using
these keys are for microsoft office 2007
F3DJD-6FFQ4-XQTQF-PGK47-8MDQ8
CM9R7-9X4DV-F43J4-JVC67-GYDQ8
KGFVY-7733B-8WCK9-KTG64-BC7D8
try this it works 100%
Apr 27, 2008 | Microsoft Windows XP Home Edition
Trying to recover various programs (including office)
change your primary boot up,,go to ur bios and change it to cd first boot,,then your laptop will start reading you recovery cd's,,anyway, if ur 1st cd is done, ur computer will also ask for the succeeding cd's..but r u rily sure that the ms office is a package of you computer when u boght it??
Apr 06, 2008 | Acer Aspire 5002WLMi Notebook
Computers & Internet Logo
16 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
