HP Compaq dc7600 Small Form Factor PC Desktop Logo
Anonymous Posted on Feb 13, 2011
Hp dc5100 sff. pass ps botton green led will come on let go of botton led goes out computer still dead. green led light on motherboard and tried power drain.
Anonymous
Level 3:
  • Master 731 Answers
  • Posted on Feb 13, 2011
Anonymous
Master
Level 3:
Answers
731
Questions
0
Helped
321153
Points
2181
Some power supply's loose the -5 volt part of the supply. Try a different power supply.
  • Anonymous Mar 26, 2011
    This is the symptoms of bad CPU chip Did the fan on the CPU chip slow down or stop while in operation try another CPU if you have one for spare.
Hp 8000 Solid Red light
desktop small form factor, SFF, (not silly fat frog)
no statement as to where lamp is, I'll guess, FRONT.
just the light bothers you, only..?
why not RTM read the manual to learn what it means.?
so where is said LED lamp, ? front of case on the SSF case?
HP calls it, and searches only work with this.
HP Compaq 8000 Elite Small Form Factor PC./
im reading your manual now for you at HP.com
my guess is lamp 5, (pwr) is not green now but is red
green means power ok, red means, not ok.,
page 2:
if flashing , the flashes are codes, what is your flash code if flashing
if not this LED then say which one?
green on 5 means ok. power ok, no errors. red bad.
sff-s5z5x1uvxsiidstn2afwkml2-3-0.jpg http://h10032.www1.hp.com/ctg/Manual/c01957825
the flash codes are here. page 47 ,
http://h10032.www1.hp.com/ctg/Manual/c01960471
you stumped me, the service manual shows no steady red.
why not ask at Hp.com
more manuals here
https://support.hp.com/us-en/product/hp-compaq-8000-elite-small-form-factor-pc/4065894/manuals
hp forum here.
http://h30434.www3.hp.com/
2answers
How do i repair green blinking light in motherboard and not powering up?
Why would you want to try to repair a working green LED?
But you need a manual, to check what the blinking light means. See how it flashes, because the board is trying to tell you what is wrong with these flashes. Like perhaps bad voltage, or bad RAM or ROM? or lost all settings.
Trying get the top of my hp compaq off
It slides right back and off. Make there is no security screw or tab in the back.
Where the hell can i get driver for hp compaq dc5100 sff without using hp down load link?
to get a driver for HP Compaq dc5100, try to this link to download the drivers; http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=447291&prodTypeId=12454&prodSeriesId=447279&swLang=25&taskId=135&swEnvOID=2094
Hello all, My Problem: Tonight I went to turn on my PC and the machine was "dead" so to speak. No fans/drives attempting to boot up or anything, even momentarily, just a completely dead...
Most motherboards come have reset buttons on them, unplug and press the reset botton. Your power supply may be gone. Try replacing the power supply.
I want the software drivers for compac dc5100 sff
You can download the Drivers and Software from the below link:
Select the Operating System installed in the Computer and download the Drivers, Software.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=447291&lang=en&cc=us&taskId=135&prodTypeId=12454&prodSeriesId=447279
Hope this helps.
4helpful
2answers
Replace hp compaq dc5100 sff c mos battery
open the side cover of cpu and you will see inside motherboard ther is one lithium cr2032 battery is there that is cmos battery.
Media PC HP 7350n Starts runs for 10 sec or more then powers down
its definately not the motherboard, actually when a ps is about to spoil it starts giving that problem and also, the memory cards are also able to cause this problem too. but first, plz try changing ur ps and see if it works..
Pc won't start
try to reset BIOS by CMOS battery from motherboard and insert again...if not worked then..ur motherboard needs to be replaced...
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
