Back to:
Tags:
Phones
Generic problem for all Phones
We have an se445 cordless (by 2 users)
posted by nomad1066 on Jul 24, 2008
We have an se445 cordless phone/answerphone. with answerphone on, the line rings 4 times then stops briefly before continuing to ring instead of cutting onto answerphone. BT line has been checked and gain increased but no joy. Broadband & SKYbox works fine.
Thanks
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by jillbarnard, posted on Aug 21, 2008
I, too, have the same problem with my se445 trio. The phone rings 4 times as I have set it for, then after the the 4th ring, instead of going to the answerphone, it starts another 4 rings, then another, and will continue like this indefinitely. When I first set the phone up, it was working as it should and I did receive a couple of calls which went to answerphone, but after a few days, it got into this loop.
I have unplugged the new phone and plugged the old one back in, but now any telephones that I use, with or without answerphone facilities, just ring and ring. When I pick up, the line is completely dead.
Virgin have checked my line and said it is fine for receiving calls, but I cannot make calls or pick-up calls that come into me. I have an engineer coming to me this Saturday, 23 August, and I hope it is a problem with the telephone line, but would appreciate any information regarding the telephone itself.
Many thanks.
Jill
Solution #1
posted on Aug 26, 2008
Not Rated (0)
jillbarnard
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Regarding the Philips SE445 cordless phone/answerphone. I posted my problem where it rings 4 times then continues to ring without cutting into the answerphone. My phone is now fixed and working as it should which is great. I was unable to make calls because I had no dial tone and although Virgin checked my line and said it was fine, it obviously wasn't. The problem was with the line in the Exchange Box - the big green boxes that are located on the roadside - the line was broken there. Once fixed, I had my dial tone and the SE445 is working perfectly. To nomad1066, I would insist that BT check their Exchange Boxes as this is probably where the problem lies. Check whether you have a dial tone. Hope this helps.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on We have an se445 cordless:
I don't want to Accept this solution
Can you Help with these Phones problems?
Phones
Lg vx8350 Using external antenna port. Phone now refuses...
Phones
ime-358822005637389
Phones
my Compnay has an alcatel-lucent (4039 i think) as our...
Phones
i can not get my phone to play the music that i downloaded...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
