Question about Averatec 3500T60 Tablet PC
My tablet will not turn on ?
When plugged in it does not even register a light on the battery indication light as charged or dead and will not com on at all
  • kkcutie1990 Feb 21, 2009
    My problem is that it registers that the adapter is plugged in and "charging" but I can't get it to turn on and I was on it the day prior and there was nothing wrong with it. Plz help!
  • 284 Answers
Time to replace the adapter, you can take it to a best buy or a electronic store to be sure. ask then to test the laptop, with and adapter they might charge a fee, better to be safe than sorry
i figure an adapter last about 1-2 year depends on how you treat them.
If you do not take care of your electronics, your electronics will not take care of YOU!
Posted on Jul 28, 2008
My 11 galileo pro tablet will not power on after charging for 9+hrs.. When plugged in the blue indicator light flashes..What is going on?
The blinking blue indicator may be reassuring you that charging is in progress when, in fact, the battery may be dead or the charger is defective.
Jan 02, 2017 | Tablets & eReaders
My tablet went out and won't cut back on and my battery not dead
Help! My tablet won't turn on! what do I do?! - Asus - Android ...
Oct 17, 2015 - 50 posts - ‎43 authors
I was charging my tablet overnight because it was dead and when I woke up in the ... I plugged the battery back in...snapped the rear cover back on, .... My Samsung Galaxy 3 (7.0) ran out of battery completely - I followed this ... my rca tablet won't turn on I tried charging but it's not ...
Dec 15, 2015
my polaroid tablet won't turn on - Tablets
Jun 20, 2015
My tablet won't turn on! - Battery
Jun 19, 2015
samsung tablet wont turn on - Samsung
Sep 17, 2014
More results from
Dec 21, 2015 | Tablets & eReaders
How do i tell if my zeki tablet has a dead battery
I think you answered your own question. If you get a charging indication when plugged in and it stays on only while plugged in, that mean the internal power supply is accepting the charger power and trying to charge the battery but your battery is toast and will need to be replaced. The same principle would apply for any laptop or smartphone for that matter.
Dec 05, 2014 | Tablets & eReaders
How do I get my tablet to turn on without plugging it in?
Sounds like the battery is dead, what does the Battery Charge indicator show, and will it stay on if you remove the charging lead?
A Factory Reset might cure this if the battery is showing fully charged with the power lead removed.
Nov 23, 2014 | Tablets & eReaders
I have a filla tablet and it will not com on help please
I suppose this is some cheap android tablet. If the power button does not turn the tablet on, try plugging in different chargers and cables. Perhaps the battery is not charged. If the tablet has been dead for awhile it might take awhile to charge the device up enough to turn the screen on. So, try cleaning the charge connector with some alcohol and check it for damage and allow port to dry before plugging in any power. Just experiment by moving the power cord around and perhaps the connector is loose pr something. I suggest leaving the cord plugged in even for days or hours because it can take different devices a long time to charge if they are flat.
Aug 20, 2014 | Tablets & eReaders
Why won't the tablet charge
Lots of variables here, but the most likely suspects are always cable and charger, but charging ports will also sometimes get twisted, bent, or detached from the circuit board. Do you get the charging light (usually a small LED next to the charging port)? If there is not an LED indicator, you can also - if the tablet is on - look at the battery indicator while plugging/unplugging, but give it a couple of seconds to register on screen while you try each option. If you get nothing that way, the cheap way to debug is to borrow a friend's matching cable and charger and see whether either solves the problem. Try all combinations, and be sure to make a firm, straight connection each time you plug in a cable. In my experience, cables are the worst offenders. Don't settle for cheap ones. Not worth the grief.
Jul 17, 2014 | Nextbook Tablets & eReaders
My CyberPad iview's battery is completely dead. How do I recharge it? Blue light is not lit when it's plugged in and there is no lightening bolt appearing.
Is the charger ok?(silly me). Unless the battery is functionally dead, it should work. Sometime plugging into another wall outlet may help.
Jan 16, 2014 | Iview Cyberpad 900TPC 9-Inch Tablet
Tablet won't turn on
When you plug in the tablet to a charger, does the LED come on indicating that it is charging? If not, your tablet's battery is probably dead and you may have a dead charger. Try connecting your tablet to a PC's USB port, with the PC turned on, of course.
Leave the tablet connected and the PC on overnight. That should trickle charge your tablet enough that it will power on. If that doesn't work, your tablet may have a bad battery, a bad charging port, or your charging cable is bad. Try it with a different cable as that is the cheapest solution at that point.
Jan 10, 2014 | Samsung Galaxy Tab Tablet PC
My google nexus 7 wont turn on
Sorry to hear/read this.
First, try get a new charger and plug your Google nexus 7. Suspect a dead battery with no charge left on it.
Otherwise, confirm your charger isn't just lighting up whereas it isn't delivering any charge current to your device.
Next to try if your ac charger is confirmed good is to attempt replacing the battery; at the store, have them insert a compatible/similar battery and then try power on your device.
New batteries at the point of purchase have some charge on them; sufficient to power on your device.
Device not power on, DON'T PURCHASE NEW BATTERY. Obviously, you don't have a power/battery problem.
Device power on, then you either have a battery that has failed or that your device's charging port needs to be serviced or repaired.
Please post update/feedback asap. Thanks
Oct 10, 2017 | ASUS Google Nexus 7 Tablet
I just purchase Pandigital multimedia novel 7"
It sounds like your in sleep mode. Hold the power button till the display says power off and tap the power off on the display, the charging light will come on and the charging light will change color when it is fully charged. Here is the link to the pdf quick start guide:
Hope this helps thanks for using FixYa
May 13, 2011 | PANDIGITAL Digital Book 843967071153...
Averatec 3500T60 Tablet PC Logo
182 people viewed this question
Top Averatec Tablets & eReaders Experts
Are you an Averatec Tablet and eReader Expert? Answer questions, earn points and help others
