On power on, there are two beeps. Then, almost immediately, "Scanning BIOS Image in Hard Drive" is displayed. That's as far as she goes. Is there any way to recover from this short of a new chio - I don't think this m'bd has a removable one. Any help will be appreciated. lou
    Problem Solver:
  • 11 Answers
I believe that there is some issue with the memory sticks that are in the computer please open the computer and then remove the memory sticks and then try and restart the computer it should not give those beeps in case it does not then please replace the computer with new memory sticks and then try again...
Posted on Jul 24, 2008
Bios update failed! Now i get 8 beeps and no display.. any solutions?
8 beeps is when the PC fails to write to its display memory. But the only change you have made is to update the bios, so I think the bios does not match the graphics card in the PC. Have you changed the graphics card or touched it inside the case? Check its fitted correctly.
I hope you backed up the old bios. If you did restore it. You may have installed a bios that is incompatible with that PC hardware, check its the correct one.
Dec 16, 2013 | HP Pavilion Desktop - 10GB Memory - 1.5TB...
One short beep one long beep continuous and power green led flashes continuos
I would say you have a failed memory (RAM) module. Probably a module in one of the secondary slots since the computer is able to POST and will attempt to boot.
Mar 20, 2012 | HEWLETT-PACKARD Computers & Internet
Ok so my netbook goes to a blue screen where it says " press f2 to run setup, press TAB to display BIOS POST message" and stays there. if i push f2 then it goes to a black screen where at the...
Probably the hard drive is dead. Did you drop it recently? Anyway, it could be just the connector, if your good with hardware you could open it and check. I would suggest you to use the warranty though.
Mar 03, 2011 | ASUS Eee PC 1000HE Netbook
My system is also making a beep sound while booting up?( the time period of beep sound is time take to read beep)i think 1 sec What might be the problem.. Even after scanning entire system and deleting the...
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
the grrr is the sound its not getting enough power
test your PSU power supply unit or replace it if the fan is not working the PSU is faulty
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Feb 01, 2011 | ASUS M2N-MX Motherboard
When i turn my computer it goes automatically in BIOS mode and when i came from BIOS a message display on the top left corner with black background "Turn off power and reinstall the jumper settings...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Nov 15, 2010 | Intel D945GCCR Motherboard
ACCESS A BIOS
I'm not quite sure what it is you exactly want here but if you need to get into the BIOS utility then as the computer is starting up repeatedly tap the Del key or the Esc key.
Regards.
Sep 28, 2009 | Gigabyte GA-945GZM-S2 Motherboard
My computer when i boot a message appered scanning bios image in hard drive..... bios auto-recovering and the computer restart... how to repair this error??
The bios is stored in the CMOS chip on motherboard not on the hard driver, the error message probably means it it scanning to find a hard drive to boot to. You should go into your BIOS and reset to factory defaults and see if this makes a diffrence. you may also have a failed hard drive which may need to be replaced.
Jul 02, 2009 | Gigabyte GeForceĀ® 8500GT, PCI Express...
GA-8s648fx scanning bios image in hard drive
update the bios of motherboard, it seems that the bios file is missing somewhere and now the computer bios is searcing for it ..(on Hard drive)
so reinstall or update the bios it will fix the prob. otherwise if u say that the bios is working ok, then go to the bios and turn them to their Defaults, and restart.
good luck
shafky
Jun 13, 2009 | Gigabyte GA-8S648FX Motherboard
Computer not booting
remove & clean the ram then reinstall it your problem will sloves
Aug 24, 2008 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
