1999 Pontiac Montana Logo
Posted on Feb 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pontiac mini van 1998 transport, V6, 3.5L I left lights on and when I came back found my car battery died, I get boosted, since then my prostart two way 3 in 1 remote starter never work. Last winter I changed my battery and this procedure worked for me, but this not really. I was told this procedure, first open the hoot and press the antenna twice and put the key and turn on but not ignite the engine and then press lock or unlock button 3seconds, then after that push the brake pedal.
Leon Robinson
Level 3:
Master:
  • Master 747 Answers
  • Posted on Feb 13, 2011
Leon Robinson
Master
Level 3:
Master:
Answers
747
Questions
0
Helped
111661
Points
2000
You will have to unhook your prostarter or get someone to replace its burnt from charge then after pro start is unhooked then put battery back in the turn key over.
1998 pontiac transport Van will not shift to 2nd gear but will drive on 1st gear 30mph...what can be problem
Could be a dirty oil filter in the transmission with out proper oil flow the pump has difficulty providing the right amount of pressure to allow the up shift. Check to fluid level if it's low add what your owners manual tell's you. Not always but sometimes a back washing the transmission can remove deposits left behind by clutch material's from the valve body intricate maze of travel. This can only be done by a transmission shop that offers this type of service. Most automatic Transmissions failures are caused by neglect long before high millage cause's trouble. A rebuilt transmission may be needed how ever that my over ride the value of the vehicle. I hope you can get your van back up & running as it should.
I have a gmc safari van, I boost my car with the van running and van will not start unless I have it boost, I replaced the battery two times and it still wont start after battery runs down, just wondering...
You don't jump a running vehicle
You shouldn't jumping any of todays
vehicles,always charge the battery
You did whatever to it
Now you need professional help
2helpful
MY BATTERY KEEPS DYING
Either you have a dead cell in the battery, or something draining the power in the van.
A mechanic would take the battery out and have it tested, then check each circuit in the van for a power drain.
My van won't start all lights indoor complete died nothing work due i left it for a month and tried to boost charger won't do anything.
either the overhead light kill switch may have been pressed by accident, or since your battery died for an extended time, you may have to reprogram how you want the lights to work. Should be in your owners manual how to program interior lights section.
I have a 97 transport van. Is the fuel pump
1997 model just work with the 1997 fuel pump; the same situation with the 1998 model and 1996 model.
For other years, they can interchangeable, as Transport 1990-1995.
Hope helps (remember rated this).
1helpful
1998 Pontiac transport van wont start:
Well you hit all the major ones, could be crank position sensor, ignition module, a bad coil pack (it should have 3), you need to check that you have spark to each plug while the engine is turning over (!!!be careful as this will hurt if you get shocked!!!), this will rule out coil packs. if you have no spark to any plug your looking at a bad ingnition module (which is what the coil packs bolt to). Hope this gets you on the right track!
13helpful
1998 windstar van: charging system light goes
It could mean the alternator has gone bad already... with the car off, the battery leads should read 11-12V.. with the car on, the battery should read 13-14V.. if it's lower then it's not charging your battery and if it's higher, it's damaging your battery....
My 1997 pontiac transport van will not start
CHECK FOR FUEL AND SPARK FIRST.
CHECK ALL THE CONNECTORS ON EVERYTHING, ESPECIALLY THE IGNITION MODULE CONNECTIONS. THE CRANK SENSOR OFF THE BACK OF THE ENGINE COMES UP ALONG THE FUEL LINES AND CONNECTS TO THE IGNITION MODULE.
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
