Question about Avanti Art Deco 4-Cup Espresso Machine
Avanti Art Deco 6-cup Espresso...replacement parts
Where can I buy a replacement lower chamber for my Avanti Art Deco 6-cup Espresso coffee maker?
2 Suggested Answers
SOURCE: I recently bought an Avanti Art Deco 10 cup
When the water boils in the bottom chamber the steam creates pressure and pushes the water through the grounds and into the top chamber. It's hard to imagine that the water going through the grounds is not close to boiling temperature unless you are using the coffee maker at high altitude where the temperature of boiling water would be lower.
Posted on Feb 28, 2010
Coffee grounds on top of k cup
Lower chamber is clogged. Clean as per manual page 18
Jul 31, 2012 | Keurig Ultra In Home Single Cup Brewer...
Howdy, I have a six-cup Mocha Express. Lately when I've been making my morning brew, it makes a high pitched whistle (like a tea kettle boiling) towards the end of the coffee brewing. I have a...
Stove top coffee espresso brewers; have three compartments, the lower is a sealed water tank that once heated will push boiling hot water and steam through the coffee grounds and over flow into the 3d chamber at the top of the pot. It is finished once all the water has boiled out of the lower chamber.
* Naturally when you boil water in a sealed chamber it's going to pressurize to the point where something will give. In this case it's the coffee grounds. But what if the grounds plugs up the filter and pressurizes it beyond what the chamber can safely contain? This is where the safety valve will sense the over pressure and release the excess steam. You will see and hear a loud hiss and steam exiting from the side where this valve is.
* The safety valve is not adjustable. Pre-mature blow out (of steam) can be caused by too fine a grind on the coffee, Turkish grind is finer than espresso. This tiny grind will clog all the filter holes. Use the standard espresso grind which is 1 size up from Turkish grind.
* The safety valve may blow if too high a heat is applied to the pot. Turn down the stove to a lower setting to give the hot water and steam time to flow through the coffee. If you observe the coffee as it oozes out of the center post. It should be a steady flow (like lava) with a gush of steam near the end of the brew when the top pot is full.
* The safety valve can get clogged which needs to be cleaned and checked PRIOR to filling and using.
* when in doubt. change out the safety valve. You could check with your vendor or MFR for replacements. Also check Amazon.com for the part.
Aloha, ukeboy57
PS; There a numerous videos on how to clean and maintain these pots. (I do NOT recommend Descaling). Here is one that looks safe:
https://www.bing.com/videos/search?q=stovetop+coffee+cleaning&&view=detail&mid=8AF60938A0B50A2D65528AF60938A0B50A2D6552&&FORM=VRDGAR
Feb 11, 2018 | Bialetti Moka Express 6-Cup Coffee Maker
My Mr Coffee ISX43 gurgles upon start up and takes 45 minutes to brew a 6 cup srving. What part needs to be replaced?
The main burner needs replaced, and its cheaper to just buy a new maker...also the parts are not readily available to the consumer.
Jul 01, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Avanti stove top coffee maker 6 cup. Need to replace seal in lid. Can I buy separately
Take the rubber gasket out of the top of the pot and take it to a local kitchen shop or Department store. If not measure the internal diameter (the hole size) and the external diameter (size of the seal) and google stove top coffee and locate a supplier in your country. Email them with the measurements and make (Avanti) and ask for a price price and shipping cost. Look at the bottom of this page as an example if you are in the US http://www.fantes.com/espresso-stovetop.html
Nov 22, 2009 | Coffee Makers & Espresso Machines
I recently bought an Avanti Art Deco 10 cup espresso machine and am disappointed that I cannot make HOT coffee with it. What can you suggest?
Oct 26, 2009 | Avanti Art Deco 4-Cup Espresso Machine
Barely any coffee rises to upper chamber after cooking
It's the gasket!!!!! Store the pot with the two parts screwed TIGHTLY together for about a week. Tighten it up as the new gasket compresses. Problem solved in two weeks or less. Also cook on medium to low heat. High flame seems to make the problem worse.
Jun 28, 2009 | Bialetti Moka Express 6-Cup Coffee Maker
Avanti stovetop exploded while on the stove
Could this happen if you fill the bottom chamber over the pressure release valve so that the steam pressure built up and couldn't be released. Or perhaps the pressure release valve got blocked. Not sure. But it is important to take it off the stove promptly when you hear it make that gurgled hissing sound that indicates the top chamber is full and now steam is coming through rather than water.
Jan 10, 2009 | Avanti Art Deco 4-Cup Espresso Machine
Where can I buy a replacement espresso pot
Update: Salton replacement parts and owners manuals can be ordered at 800-233-9054 or by emailing consumer_relations@toastmaster.com
Jan 30, 2008 | Bodum Chambord Style (8 euro/ 4 usa cup)...
Avanti Art Deco 4-Cup Espresso Machine Logo
64 people viewed this question
Top Avanti Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you an Avanti Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
