Well, I met this kind of problem before. There might be quite a lot of reasons that may cause this kind of format error problem saying memory card not formatted. Check out this article how to fix memory card not formatted error and learn how to fix it step by step.
The easiest way to format your memory card is by using a PC. You will need the following
1. Memory card reader which is compatible with your card.
2. The memory card that needs to be formatted.
When you will insert the memeory card into the reader and attach it to the PC by using any of the free USB ports, A new drive will be displayed in the My Computer window. You will just need to right click this new drive and select format. You can select quick format if you like it will be faster. Be absolutely sure that you select the correct drive, other wise you can lose all your data in the drive if you accidently format the wrong one.
After the card has been formatted you can use it in you mobile.
Hope this solves your problem
