I cant get in to my screensaver settings, when i right click my desktop click on personalize then try to click on screensaver nothing happens and then everything sort of freezes i have a toshiba u405-s2820
  • 300 Answers
This is only for XP and 2000. Also, try to change your desktop background before you use this information. The option to change the background is on the same screen as the screensaver settings. The tab says background instead of screensaver.
Download cleandesktop (http://thespykiller.co.uk/downloads/cleandesktop.exe)and save to your desktop. (right click save as)
Double-click on the cleandesktop.exe it will automatically extract to c:\desktopclean
Then it will automatically run the cleandesktop.vbs script.
It will then kill explorer. You will temporarily lose your taskbar and desktop .
It will then repair the registry entries returning your normal desktop and context menu functions.
It will then restart explorer. Your desktop will be shown again once you have performed the cleanup
Each of the other users on the system needs to be signed in to clean up their desktop and regain the right click.
Another vbs is included to do this. It is named "other profiles regfix.vbs".
Have each user sign in and run other profiles regfix.vbs.
Go to start > run and type: c:\desktopclean press enter double click on other profiles regfix.vbs
Explorer will be ended and that user's active desktop registry entries will be repaired.
Explorer will be restarted. To restore the desktop to whatever picture you normally have, right-click on a blank part of your desktop, select properties > desktop tab & select your preferred picture.
Press apply & then ok to exit and then press f5. (to refresh) you will need to do this step for every user account.
Thanks
Posted on Jul 24, 2008
How do you get Windows 10 free update from Windows 8 to operate the screen saver?
How to customize Screensaver in Windows 10
RECOMMENDED: Click here to fix Windows errors and optimize system performance
There were times when computer monitors used to suffer from image burn-in issues caused by showing the same image for a long period of time and people used to install a screen saver to avoid the issue. The computer screens today no longer face the burn-in issues, but people still use the screen saver on their computer systems for fun's sake. Windows 10 comes with a six built-in screensavers. Let us see how you can customize screensavers in Windows 10.
Read: Are Screensavers necessary and still needed.
Screensaver Settings in Windows 10 You can get to your screen saver settings directly by typing 'Screen Saver' in the taskbar search box in the lower left corner of your system. Click on 'Change Screen Saver' and it will take you the Screen Saver settings right away where you can adjust the settings according to your own preferences.
Alternatively, right-click on your Windows 10 desktop, and select Personalize to open Personalization settings. Next click on Lock screen in the left pane.
Scroll down the Lock Screen settings and click on Screen Saver Settings. The following window will open. Here you can adjust the settings according to your preferences.
By default, Windows 10 offers the following six screensavers - 3D Text, Blank, Bubbles, Mystify, Photos and Ribbons - nothing new here. Select the screensaver from the drop-down menu and change its defaults Settings, if any are available.
For instance, the 3D Text screensaver lets you customize the text as well as a few other options.
The Photos screensaver lets you display your favorite photos as a screen saver.
Once you are done, click on save and exit.
Create Screen Saver Settings Shortcut
If you access the screensaver settings frequently, you can create its desktop shortcut as follows: However, it is easy to change the settings but if you change your screen saver often, it would be better to create a Screen Saver Settings shortcut on your desktop.
To create the shortcut, you have to right-click on your desktop and click on New > Shortcut.
Type control desk.cpl,,@screensaver in the location space in the wizard.
Click Next and give a name to your shortcut. Click Next and you are done. Give it a suitable icon of your choice.
Use this shortcut to change or adjust your screen saver settings whenever you want, quickly.
You can also create a shortcut to launch or change Screensaver state for a specific screensaver.
Nov 29, 2015 | Microsoft CompuRegister POS-1000 POS...
I want to turn screensaver OFF
Control Panel\Appearance and Personalization\Personalization
If you're running windows 7 right click your desktop select Personalize In the bottom right corner click the Screensaver icon and set it to none
Sep 20, 2012 | HP Computers & Internet
Does my hp mini capable of screnesaver
Yes; right click on your desktop, and choose personalize; choose it on the screensaver tab.
Mar 06, 2011 | HP Mini 1000 Netbook
How do i set my timer for my screensaver-when my laptop is idle?
The option is under Screen saver options or there is an idle time shut off selection under Power Saver options as well. When you select your screen saver there is are specific options to customize how it shows and how long before it activates. Some screen savers have more options than others.
Oct 29, 2010 | Computers & Internet
How to install themes for windows vista and scrrensavers
  1. Right-click the downloaded Vista screensaver file (with .scr extension) and select "Copy."
  2. Go to the Start menu, click on "Computer," double-click the "C:"drive, then the "Windows" and "System 32" folders.
  3. Right-click anywhere in blank space within the "System 32" folder and select "Paste" to install the file as the screensaver.
  4. Go to your Desktop, right-click anywhere in a blank space and select "Personalize."
  5. Click on the "Screen Saver" tab and click on the drop-down menu in the "Screen Saver Settings" window to see the list of available screen savers, including the one you just installed. Select the new screen saver and then click on "OK" to save the new settings. use the same principle for the theme installation. do remember to leave your comment by saying how helpful this post is
Oct 07, 2010 | Computers & Internet
I dont know how to change the timer for my screen saver, to reset the time.
In Windows Screen saver can be managed from Display Properties window. Follow the steps given below:
When using Windows XP, right click on the open space on the Desktop then click Properties to open the "Display Properties" window.
In the "Display Properties" window, click on the "ScreenSaver" tab to manage it.
When using Windows Vista, right click on the open space on the Desktop then click "Personalize" to open the "Personalization" window.
Next, click on the "Screen Saver" option to open the window where you can manage settings related to screen saver.
Oct 11, 2009 | HP TouchSmart IQ770 PC Desktop
How to set screensaver?
hi
first of all u need to right click on empty space on desktop and then select properties,once u have done that u will get a screen named display property ,,,,,,on the top u will find the tab screen saver.....click on to that and then select the desire screensaver and click apply and close ..........
Aug 31, 2009 | Computers & Internet
Vista Remote logoff problem
the computer most likely goes into screensaver and it is set to logout / lock the computer everytime the screensaver is opened.
right click on your desktop select personalize, look in the screensaver settings. Take the Check out from the box that says, On resume display login screen.
now the computer wont sign you out every time the screensaver comes on.
Jun 16, 2009 | Microsoft Remote Desktop (V3H011652)
Hi, my screensaver acer aspire one doesn't work. can you help ?
To set up your screensaver, right click on your desktop and choose Properties. Choose the Screen Saver tab. In the drop down menu for Screen saver, make sure something is selected instead of (None). Next click the Preview and it will give you a glimpse of what the screensaver you chose will look like. Move the mouse to get out of it and select apply if you like that one or choose a different one.
Jan 14, 2009 | Acer Aspire One PC Notebook
Helphelphelp!about my compaq n610c
right click anywhere in desktop an go to properties,goto screensaver and click power ,check settings.I personally set mine to never but Im on my comp 24/7
Feb 20, 2008 | Compaq Evo N610C Notebook
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
