For some reason, your door lock isn't unlocking properly. You can manually override it, but this won't fix the root problem. Here's how...
1. Unplug the machine
2. Remove the 3 screws from the back edge of the top and pull it off rearward
3. Using a flashlight, look down along the RH inside of the machine (facing the machine). About half way down, you'll see the door lock mechanism which has a manual pull that will unlock it. Pull up on this to unlock the door.
4. You could take your chances and put the machine back together, plug it in and see if the lock acts up again. If it does, you'll have to replace the door lock, if not- it's your lucky day.
Good luck.
