FixYa.com
Tags:
Fax Machines
Generic problem for all Fax Machines
Installing a linksys wireless-n gigabit
posted by randolph2008 on Jul 24, 2008
installing a linksys wireless-n gigabit router model#:wrt310n
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 24, 2008
Not Rated (0)
UPSTATEOS
Rank:Guru Guru
Rating: 86%, 43 votes
You should get a disc with the router, Its very simple, install and follow the directions. Also Linksys has the best support I have seen for computer problems. They have site on line that will test yur unit and reconfigure it for you and if that does not work call linksys 800 546 5795. Usually They are plug and play, some routers will work by just plugging in and trying, some have to have the software installed. Good Luck
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: HP 1010 Plain Paper Inkjet Fax HP HP 640 Inkjet Fax Machine HP 1220 Plain Paper Inkjet Fax HP 1220xi Plain Paper Inkjet Fax Panasonic KX-FHD331 Plain Paper Thermal transfer Fax Panasonic KXFP145E Plain Paper Thermal transfer Fax Panasonic Panafax UF-333 Plain Paper Inkjet Fax
Can you Help with these Fax Machines problems?
Brother IntelliFAX 4100 Plain Paper Laser Fax
Brother Intellifax 4100
Hi - I too am getting about a... Answer This...
Fax Machines
CANNOT COLOR PRINT PHOTOS. NEAR
cannot color print photos. near... Answer This...
Fax Machines
shredder will not shut off
shredder will not shut off Answer This...
Panasonic Panafax UF-490 Plain Paper Laser...
Phone off hook message
We're getting a Phone Off Hook... Answer This...
Fax Machines
Sharp AR-M207 error code F9-00
Sharp AR-M207 error code F9-00 Answer This...
Repair Service
Find Fax Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
