Question about 2wire (1000-400108-001) Router
Router problems with printer
Cannot setup my wireless all in one printer to communicate with my laptop, the internet is working fine,
  • Anonymous Aug 24, 2008
    I have the 2wire router - both wired and wireless, the hP product does not see the printer. I think it is the fire wall but you are not able to turn off the fire wall on private address, I have public address and able to see the printer, but those are static address and only other systems on that same set of static address can see the printer. Want to use the private address for the printer. Help.
    Scholar:
  • 83 Answers
What is the brand and model of the printer and laptop?
Posted on Aug 02, 2008
  • Shaun Harris
    Shaun Harris Aug 02, 2008
    this was not a solution but a request for more info.
  • Dennis Rao
    Dennis Rao Feb 22, 2014
    Laptop is Dell inspiron printer is HP 7520 all in one. Had zone 6519 printers worked. Technician replaced it with 6218 and now not able to print wireless.
Dell V510 printer worked fine wirelessly until we got a new Belkin Router
The printer's IP address most likely needs to be changed.
Check the Belkin's IP address range (it maybe 192.168.2.***) and configure the printer's IP address accordingly.
Jul 14, 2012 | Dell AllinOne Multifunctional (v515w)...
I have bought an Epson Artisan 835 printer & can't get it to connect wirelessly to a Billion Router (BiPAC 7300G).This router is connected wirelessly to my i-Mac. I currently have the printer...
1) Please check your router setup whether it does not allow Wireless devices to ping against each other;
2) If it does not allow to ping (communicate) with each other, please disable it first.
3) Then please check your Epson wireless setup whether the DHCP function is enabled; if not, please enable it;
4) Please also input your network gateway, sub-net mask correctly into the Epson printer, otherwise the wireless communication with your network will not work.
5) Then switch off your printer and turn on again to recognize the new settings; and it should work
Aug 28, 2011 | Epson Stylus Multifunction Inkjet Printer/...
When I route my cable line through router I cnnot get an internet connection. It was working fine until recently. I have had this router for a while and it was working fine but now no connection and no...
sounds like you recently upgraded your Pc or software, maybe even just a driver update? If so it will help figure out your problem.
Always try to reboot your network(router,modem,pc,laptop)for at least 30 sec, usually its a communication error or a firewall issue that blocks router access, and then again it could be a driver or software compatibility problem. email me with more info if you still need help knowitall1979@yahoo.com
Dec 15, 2010 | Linksys WRT54GL Wireless-G 54Mbps...
Toshiba NB 205 connects to router but not internet
The wireless configuration is set differently on routers, eg the SSID, and encryption. You need to configure the wireless LAN card in the laptop to connect/communicate with the different routers.
Some wireless LAN card allow you to setup different profiles/settings for different wireless routers. Eg one setting for the office and one for home, which allows easy connection to the Internet by selecting the appropriate profile/setting.
Aug 17, 2009 | Toshiba Computers & Internet
Belkin N1 Wireless router wont fully connect to laptop
if you connect your xbox and it works than it is not your isp
go to your network setup and try it with fix ip and DNS to you vista laptop wirless card /fixed card ip setup
goodl luck get back if this does not work with more info on your network setup
Jun 12, 2009 | Belkin (F5D8231-4) Wireless Router...
US Robotics Wireless Router problem
Sounds like some settings on the wireless router might be setup wrong...like DNS. While hooked into wireless, try going to a command prompt and type ipconfig /renew. Once it refreshes, type in ipconfig /flushdns. Try the Internet.
If that doesn't work then check the settings on the wireless router and see if the DHCP is setup with a static IP or dynamic one.
Depending on what that says, I can provide next steps.
Apr 11, 2009 | Dell Computers & Internet
Wireless Printer communication problem with laptop
Please check IP, use manual IP for laptop and Printer. may AUTO IP cause this issue.
Apr 12, 2017 | Lexmark Office Equipment & Supplies
I have a sony vaio laptop running xp sp2 connected wirelessly to an HP C4385 printer. I can't get it to print in this wireless mode and I can't get a response from the printer when I put the printers IP...
I suggest you network the printer and access it through the wireless access point.
Also, I do not mean to insult your computer smarts, but if you do not have a driver installed, you will not be able to talk to the printer at all.
Aug 14, 2008 | Computers & Internet
Communication
How many computers do you have? Make sure you can go online first via hardwired. If the internet works fine hardwired, one thing that you can try is change the current channel of the router.
Open the setup page of the router.
1. Launch Internet Explorer, type http://192.168.1.1
2. A username and password box will show up. No username and password is admin
3. Go to WIRELESS tab. Change the channel to 11 and click on Save Settings. Restart your computer and try to connect again.
Jul 01, 2008 | Linksys Wireless-G Broadband Router
Internet connection lost when wireless printer added to network
for reseting the password of ur dlink router u have to press the rest button on the dlink router (genrallyit on the bottom or on the back of the router it is like a hole u have to use a pen or pin to reset the router back to its factory default settings after that password of the router will automatically back to admin or password login to ur router change the settings to static ip in the router so that u can provide the static ip of the other router to ur this router (example if primary router HL 2170 ip address is 192.168.1.1 then u will provide this dlink router the ip address as 192.168.1.5, subnet 255.255.255.0 default gateway 192.168.1.1 primary dns 192.168.1.1 now save the settings in the dlink router now the ethernet cable from ur other router will go directly in to the internetor wan port of this router. now connect wirelessly to any router both will work fine without any problem
Jun 03, 2008 | D-Link AirPlus DI-524 Wireless Router
2wire (1000-400108-001) Router Logo
75 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
