My samsung monitor is starting to have really bold and a bit blurry type showing up on the screen. Is it possibly going out? Not all of the type is this way just the far right side?
  • 161 Answers
Bro your monitor is broken, and is on the verge of breaking down. I had a similar problem and had it repaired at the shop I bought it at. Problem was fixed, then broke down and nothing would appear on the screen. I bought a new one. Maybe you should do the same bro.
Posted on Jul 24, 2008
How do i unlock my blackberry 9700 bold
  • Turn on the phone (with or without a simcard)
  • Go to options / settings
  • Go to advanced option
  • Go to Sim card
  • Type mepd (nothing will show while you type)
  • Type mep+alt+4 (you will press m+e+p then press alt then press 4.. once again nothing will show on the screen while you type)
  • A prompt will show on your screen asking you to enter the code
  • Enter the Code supplied to you by your unlock code provider
  • If you follow the steps correctly you should get a message saying "Code Accepted"
Aug 02, 2010 | RIM BlackBerry Bold 9000 Smartphone
Icons are blurry
Did it happen all of a sudden? In other words, was it OK before?
Try going to screen preferences, settings, and look at the resolution slider - is it set to the native resolution of your monitor (1280x1024)? If not, correct and accept changes.
If the resolution is set OK, then multiple other things might have happened, but not knowing a bit more about the situation it's hard to advise anything...
Nov 08, 2009 | Samsung SyncMaster 931B 19" LCD Monitor
My computer doesn't start up and when it does my screen has dotted lines and sometimes it starts but when it does only in a matter of time because after a few hours the screen of my computer will become...
Sounds like a monitor issue at this point (blurry screen). Try switching monitors to see if same problem or test your monitor on another system.
If not the monitor, could be video card or driver. It possible that you have spyware or malware, also. If not the monitor, when the computer does start, go into Safe Mode (F8). If Safe Mode loads OK, select a System Restore point from a date when all was OK. Hope this helps.
Jul 09, 2009 | Microsoft Windows XP Home Edition with...
I bought second hand monitor samsung syncmaster750s..when i plug it the icons become blurry and become large and i cannot set my resolution...i use the vga mode because when i start it normally..it au
Normally if you go in VGA mode the screen will be installed and when rebooting in normal mode it will set itself.
In VGA mode the resolution is 640x480 and you can't set the resolution higher, so what you are experiencing is normal.
From what you are saying it seems that the driver installed from windows is the wrong one, you can try to run windows update to see if there is a driver for it or go on samsung website.
You can get the driver from samsung here :
Samsung 750s driver
If after that it doesn't work check on the internet for compatibility issues with your graphic card, since some of the newer cards can have compatibility issues with the older CRT screens.
Jun 01, 2009 | Samsung Computers & Internet
How can I make fonts look good in an LCD monitor ?
The VGA connection should be fine; I have DVI and when I switched from analog, the difference was pretty minimal, to my eyes.
Is it just the fonts that are blurry, or everything? If fonts only, then this almost certainly suggests that running the ClearType tuner again would solve the problem. But this applies to all displays, so if one is good and the other is not, then this isn't it.
If everything is a little blurry, then this suggests one of two problems -- the first, you report trying, which is that the display adapter is set to a different resolution than the native resolution of the LCD monitor itself. Your display adapter should probably be able to drive 2 monitors (the built-in laptop monitor and the external monitor) at once. You should be able to set their resolutions separately.
Assuming Windows XP: Start > Control Panel > Display > Settings > at which point, you should see two monitors listed in a dropdown. Set them to their native resolutions there (using the slider bar, usually all the way to the right), and save.
If you do have the display resolutions set to their native resolutions for both monitors, then it's possible that your external monitor is messed up. A quick test would be to run the on-screen settings, usually from a button on the monitor itself. If what is displayed there is sharp and what is displayed from Windows is not, then this points to a problem with the display driver. If everything, even the on-screen display is blurry, then perhaps the monitor settings are messed up -- usually there's an option to restore to factory settings -- try that.
If that doesn't work, I'm probably out of ideas, unless you have further information.
Mar 08, 2009 | LG Flatron L1750S 17" LCD Monitor
Samsung syncmaster 2253BW blurry/out of focus HELP!
cables wont make a difference, are you sure your display settings are set to 1680 x 1050? i have had problems when it is set to 1600 x 1000 and i had to reinstall the video card drivers.
Dec 28, 2008 | Samsung SyncMaster 2253BW LCD Monitor
Contrast
replace EHT
May 08, 2008 | Computers & Internet
Screen not smooth in the sides and corners
hi there, i've done a bit of research about your monitor apparently this model is not very reliable and has all sorts of common problems including yours here's what some people said about it: Bad Points Extremely unreliable. Over a 2 year period I have had to replace 6 out of 20 monitors Main problem, the image degrades to the point where any text in the centre of the screen is difficult to read. this monitor has a blurry corner right bottom corner and a bit of a whole right section.. and its out of focus constrast is like not on full and correct and identical to the left side.. left side is crisp and perfect.. also it takes bit of time to correct the display in the screen position and pincusion, the convergence isnt impressive at all.. anyways this is what you get from cheap monitors and BTW this is made in Indonesia, i am not flaming on the country, i am just saying this monitor isnt tested or not in quality as samsung flat monitors or sony. i am disappointed on LG for the first time, well if you really consider buying this monitor, you must check the monitor screen or something if it is correct. so you dont have to cry after you came all the way back home with it.. looks like a lot of people are not happy with this monitor. just replace it they are not expensive nowadays regards
Aug 19, 2007 | LG Flatron 775FT 17" CRT Monitor
Computers & Internet Logo
David Payne
David Payne
