I have a Linksys router. it is hooked up to my modem and used to work good. Lately,my wireless notebook cannot get a signal and even on my dekstop it's not working. I called my ISP, Comcast and was told that I have good signal coming from them. So i connected my modem directly to my cpu, instead if running throug my router. Please help.
  • 68 Answers
Is your router is configure???
Posted on Jul 24, 2008
Connected wireless to router, excellent signal, but unable to connect to internet.
connected to wireless router with excellent signal may not means you are connected to internet. make sure your modem provided by internet service provider has signal! connect your computer to modem directly bypassing router. If you are online that means your internet is functional. Then connect modem to your Linksys router and use your wireless to log on to internet.
Your router wireless signal active and excellent means you are connected to router not necessarily the internet. The modem supplied by your internet service provider with active internet should be connected to you router on WAN port!
good luck!!
Oct 07, 2011 | Linksys Wireless-G WRT54G Router
My laptop and my iphone indicate that my wireless-g broadband router is putting out a wireless signal; but neither accessory works on the network, even though the bars are entirely full on the devices.
The bars on your laptop or iPhone means that you are connected to the router! Not necessarily to internet. Your internet depends on ISP Internet service provider and modem which connected to your router. To check if you have active internet connection connect your laptop directly to modem provided by your ISP with ethernet cable and try to open a internet browser IE or Safari or Chrome or Firefox and open a webpage! If you are able to connect internet by this mean you have internet connection active. Now disconnect your lap top from modem and connect modem to your Linksys router using WAN port of LINKSYS! Its good to power off and power on (power cycle) once on modem and router to make it work!
good luck!
Sep 14, 2011 | Linksys Wireless-G Broadband Router
We moved and when everything was hooked up i cant get a connection from my linksys wireless router to my laptop
Ok - hook the power to the Linksys - then RESET - the folded out paper clip will work. Once RESET - hook it up to your ISP provided MODEM [ You must have this service to get on the web] now unplug the Modem provided by your ISP or provider - and unplug the router.
15 seconds - then
hook up the MODEM from the provider - then hook up the router - then restart the laptop - if wired it will need to be plugged in - if wireless - run your 'search for a wireless signal and you should have it.
Gary @ Fix Ya
Sep 06, 2010 | Linksys WRT160N Wireless Router
The roouter is one year old. Lately I start receiving weak signal and coverage.Even mu E90 can't detect the signal in the house unless I am in the same room where it is installed.
You may have intereference from a neighbor's wireless network. If you change the channel from the default to some other channel, you can avoid this problem. Also, if your router is right next to another electrical device, even a cable modem, it can disrupt the radio waves and render your router useless. Give it a couple of feet of space.
Aug 05, 2009 | Linksys Wireless-N WRT150N Router
Drop connection on my wrt300n V1 router
if you have a cable modem it could be a signal problem coming from your cable provider causing upstream problems you can try unplugging your router to reset it but could be a cable signal problem
Apr 06, 2009 | Linksys WRT300N Wireless Router
Linksys WRT300N router issue
you have to power down all three items , turn on the computer then the modem then the route if this fails hit the reset button on the modem this shoul work for ya
Dec 25, 2008 | Linksys WRT300N Wireless Router
Wireless connection
Check the Linksys web site for the manual. Follow the directions. Linksys routers have very easy set up routines and are designed for the novice.
Oct 31, 2008 | Linksys Wireless-G Broadband Router
After successful instn of my linksys wireless router i cannot access to wireless online connection
Whenever you connect a different device to the cable/DSL modem the modem itself must be reset. Dont even waste a phone call to linksys. Its useless.
If you are using DSL depending on your ISP you may have to enter your account info into the router's PPoE section
Cable users should have the router set to "Obtain IP aadress automatically"
Use the reset button on the back of the router and start from scratch.
Unplug the cable/DSL modem power
Hook up your router WAN/Internet to the Cable/DSL modem Ethernet/LAN jack
Power on the Cable/DSL Modem first, wait about a minute, then power on the router.
Sep 25, 2008 | Linksys Wireless-G WRT54G Router
Linksys router
unplug your DSL modem. Wait 30 seconds and plug it back in.
Make sure the router is connected to a DSL modem. Lately I have seen DSL modems connected to offices that are really routers. If thats the case it may not be talking because the DSL is address the gateway with the same address as the router.
The best way to test this is to see what happens when you disconnect your linksys router and type in
in internet explorer.
If the DSL modem screen appears, it's configured as a router.
Then you will have to take the linksys router and turn it into a switch with a wireless access point. I
Jul 14, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
David Payne
David Payne
