I get horizontal lines on the screen that last from a few seconds to 15 minutes. Lots of little lines that take over the screen, you can't even use the menu. Best Buy says that there is no problem but I say there is. How can I fix this problem?
  • 304 Answers
These intermitant lines are caused by a failing capacitor in the horizontal output circuit. I've seen this 100 times. The easiest and cheapest solution is to change out all the larger caps in your horizontal out put circuit. They are cheap and you will know you snagged the right on if you cange them all out. Watch the polarity though as this is important. They are clearly marked +/- so this should be no problem unless you are blind. Bad joke. You should be able to get them all for under twenty bucks, add a little elbow grease and your lines will be gone. The main reason you change them all is because it is hard to isolate the culprit when the problem is intermittant. And the second reason, you know they are all fresh. The capacitors job in the circuit is to filter out ripples in current. Eipples in current cause ripples in screen. Some sets employ a horizontal output IC, in this start by changing out the caps surrounding it. If you still have ripples swap out the IC.
Hope this points you in the right direction.
George
Posted on Jul 24, 2008
Fix horizontal lines
Just buy a new computer monitor. It is not worth the cost to repair it.
Jun 29, 2013 | Sceptre Computers & Internet
Vertical lines showing up after being on for awhile
Eh, I can't be too sure, but it sounds like it's either a heat issue, a signal issue, or a backlight issue. Either way, if it's still under warranty I'd send it in.
May 06, 2013 | Sharp LC60LE835U AQUOS Quattron 60" 3D...
My Samsung LN52A650A LCD TV is displaying green shadows and lines after being turned on for 15 minutes. This has been isolated to the display as I get the same result from DVR or DV player.
May not be a do it yourself repair, could be main board or even a loose connection at a plug inside the display panel (fatal) or outside of it.
Oct 15, 2012 | Samsung LN52A650A LCD TV
Horizontal lines in laptop screen
Brand source customer service
Oct 02, 2017 | Computers & Internet
Powerbook g4 Aluminum 15 LCD
it could be the inverter to the display, or the graphics chipset or the connection between them.
Nov 02, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
WHITE horizontal lines across screen
You need to adjust Screen voltage (decease a bit) to disappear white lines on TV. If you want to do it yourself, let me know to help you further.
Regards,
Aug 13, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Samsung hlp 4663w picture is all horizontal lines
Bad color wheel...have it checked by a quaified tech.....
Must have lamp code number to get color wheel #.............T.
Dec 08, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Horizontal lines obstructing the second half of the ti 83 calculator screen, anyone know repair tips?
I had the same prob with vertical lines on the screen, and getting messed up when there was lots of numbers on the screen.
Solution: Change your batteries. Put some freshies in then adjust your contrast until you see the little black box. If you still have a problem with the lines, darken the screen until it's black (2nd up repeatedly) and let it sit for a couple minutes. Lighten your screen back to normal (2nd down) and turn off then turn her back on.
Jan 17, 2007 | Texas Instruments TI-83 Plus Calculator
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
