Question about JVC Televison & Video
The repair man said the d-board was bad what is a d-board?
  • JVC Master
  • 8,617 Answers
JVC sets arent usually described as having D boards such as a sony, What is the model number of your JVC and what is the symptom? Please reply to this same post.
Posted on Jul 24, 2008
Have a ge profile refrigerator went completely dead,repair man replaced mother board and control panel still not working, fridge is only 14 months
If there is no power after the repair man replaced the board and panel, the repair job is not complete. Have the repair man finish the job.
May 03, 2016 | GE PFE29PSDSS 29 cu. ft. French Door...
Va703m
This is a common indication that the power supply board has bad filter capacitors. When the capacitors go out the power board can not start up correctly so you get either a white screen, a flashing power light and no display, a flickering display or no power at all. The repair is easy, it just requires replacing the bad capacitors on the power supply board. About 10 minutes and a little soldering and your monitor should be as good as new. Here is a link to a repair kit with the correct parts to do the repair.
http://www.ccl-la.com/catalog/product_info.php?products_id=145
Apr 26, 2013 | ViewSonic VA703mb Monitor
Washer when turned on stops working and shows error e03
It's probably an Electronic Circuit Board that's gone bad. This is for a reputable repair man. Those boards aren't cheap.
Jan 17, 2013 | Washing Machines
I have a vizio vp50 hdtv20a. A while back we turned it on no picture and it started to smoke. After reading a little about it I decided to take off back panel and see if I could locate burnt part. Could...
That board directly connects to the display panel---you may have a bad display panel which if is the case is fatal---panel alone will cost more than the set did when new----seen this before in the shop where I repair sets.
May 03, 2012 | Samsung Televison & Video
The repair man said the lcd is gone bad and will cost $162 to repair and have been waiting for almost a month for the part and still hasn't arrived. What's next?
If you were to think the other way why not try and scrap the set for the value of the mother boards and put in this amount to go in for a new TV with added features.
So take an estimate with your repair man if you can fetch a price while you check out the models and cost of the present models.... many of which are priced lower and comes with warranty.
Jul 26, 2011 | Proscan 26LB30QD 26 in. LCD HDTV
After various boards and repairs, I still have problem with my picture, my TV wont take the convergence adjustments done manually and the auto convergence display an error message. TV man says the...
If you mean it will no longer store the settings, replace the X2402 8 pin EEporm. They are only a few pennies to buy and that will save you a fortune.
Jan 06, 2011 | Toshiba 57H81 57" Rear Projection...
Hotpoint HSS25IFMB WW will not defrost.
I was having the same problem. I replaced my defrost heater (2 screws and 17 dollars) and it works great now
Mar 09, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Tood my D52W20 to Repair man and he said not worth fixing.
The repair man doesnt know RCA 's very well. The 3 x then out power led is the classic sign of the flyback and cp150 needing to be replaced. You need the flyback # 259296 and the CP150 you can get the flyback and cp150 at the following link with free step by step instructions with pictures on how to do the repair. Its very easy. Heres the link.
http://servicemanuals.vstore.ca/
Mar 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture horizontal problems
There is a sevice menu but it is something a repair man has to adjust. Even to get to that menu is a matter of procedure. If the picture is not always squeezed down then adjustment is not the problem. If it is intermitant it could be a bad solder connection on the main board.Sometimes a bad vertical ic and leakey capacitors can be the problem..
Bottom line is there is not much you can do to correct the problem. You are going to need a service man
Nov 14, 2008 | RCA F36650 36" TV
Televison & Video Logo
47 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
