posted by table12 on Jul 24, 2008
turns on works wont heat only 6 months old
Comment by table12, posted on Jul 24, 2008
how do i get to the diode or magnetron,capacitor do i have to remove unit from wall or is there a way to get to it from bottom or front?
Best Solution
It doesnt matter how old a system was. components can be failed at any point in time. unplug the unit. carefully disassembly and visually check the diode near magnetron and capacitor, it might be broken.If seems good, check the thermostat continuity,if beeping. changage your magnetron. be careful capacitor store charges that deadly. discharge the capacitor first.
when you change mag. change the diode too.
Comment by Prince P, posted on Jul 24, 2008
If mounted on the wall or cabinet, you need a helper to hold it when unscrew.
Remove the whole screws at the top and the two sides.One lead of the diode is connected to the magnetron the other leg connected to the capacitor.
Rating Locked! (?) table12 has rated this solution as Helpful
Suggest a new solution for this problem
Post a New problem for Goldstar MV-1501 1000 Watts Microwave
Email this problem
Email this problem
Can you Help with these Microwave Ovens problems?
Goldstar MV-1501 1000 Watts Microwave Oven
Microwave turns on all by...
After use -- like 10 minutes of... Answer This...
Buttons don;t work
Buttons don;t work
I have a brand new Goldstar... Answer This...
Repair Service
Find Microwave Oven Repairman Near You:
