My mailmate shredder doesn't shread. The forward button doesn't work either, but the reverse button works.
  • havock80 Jul 26, 2008
    How do I get to the sensor?...I'm not quit sure how to open up the mailmate.
  • Anonymous Apr 26, 2009
    my shredder will go in reverse, but it won't shred or go forward.
  • 30 Answers
Try cleaning up the paper sensors located at the middle of the paper path.
Posted on Jul 24, 2008
We had this exact problem. Looked on another website similar to this one and read the suggestion of turning the switch on the back multiple times (which apparently can trigger the "reset" function). We almost gave up, but it worked! We're up and running!
Posted on Jun 18, 2009
***** Important note on getting the power switch fix in the back to work while toggling it on and off to reset the shredder. Make sure to pull out the paper bin while you toggle the power switch on and off a dozen or so times and then put the basket paper bin back in place. When you power the unit back on the forward button should work again and the shredder should feed paper through properly.
Posted on Jul 15, 2010
  • Cyber83 Jul 15, 2010
My shredder will run in reverse but not auto/forward. It is completely cleared of jams. Any suggestions
There should be a little leaf switch directly in the middle of where you feed in the papers to be shreadded. It could be jammed or simply bad.
Dec 16, 2014 | Shredder Office Equipment & Supplies
My shredder will only work in reverse.
There must be a button on the shredder you need to push so it works forward, this button has 2 options: forward for shredding, and backward to push caught papers out of shredder.
Jul 07, 2014 | Cross Royal 7 HT700X Shredder
Shredder keeps running on auto
Unplug it and check to see if theree is any paper caught in the Start switch. Turn it Off, plug it back in and start in the Reverse mode. Then turn it Off and set the swich for On - shread.
If that doesn't work unplug it and find the start switch trip wire, Toggle it a few times with something thin - don't push too hard. You can also spray the switch the canned air used to clean keyboards. Plug it back n, start it in reverse then move it to shread.
Jun 19, 2014 | Omnitech 18-Sheet Cross-Cut Shredder
Won't shread
Will it reverse ??
Unfortunately, the death of these things is mostly attributed to inserting more than the rated number of sheets, in this case 8, and jamming it or burning the motor out
Mar 08, 2014 | Comet C-80 8 Sheet Cross Cut Paper...
Hello my nane is Tom. The shredder doesn't work. It will run in reverse but when I turn it to forward it run for a second or two than stops. I looked and I can't see anything jamed in it.
I got mine to work by running it on reverse for a moment then sliding it to auto. It stopped. Then I did it again. This time auto ran just for a second then stopped. I did it a third time but I had a sheet of paper ready in the feeder. Ran on reverse. Slid it to auto and it took the paper and shred it. I did it a fourth time. Reverse slide auto and feed shred the paper. Fifth time Auto shred the paper without reverse. :)
Aug 30, 2011 | Aurora Electronics AS662C Shredder
Stopped working while i was using it
Mine does that when it jams, or overheats. Try toggling the switch between forward and reverse to clear any jam. If that doesn't work, you can unplug the unit, turn it over, and remove jammed paper with needle nose pliers.If there is no jam, try letting it cool for a while and then try in the reverse position.
Oct 29, 2010 | Staples ID Armor IDX50B Shredder
Doesn't work going forward only in reverse
sounds like you have a sensor problem. is it automatic reversing on jamb? if so sensor is defective, or there is a bind causing sensor to reverse only, a bent shaft could cause that
Apr 04, 2010 | Aurora Global AS501X-MS Shredder
Reverse shred does not work
either the switch is unplugged or defective, or the main board needs replacing. Also, they come with a 2 year warranty. try calling 1-800-955-0959 for fellows end-user support and have serial # ready (ser.# is found when you open the door).
Oct 29, 2009 | Fellowes C-420C Shredder
Mailmate by staples shredder won't turn on
I took my mailmate out into the driveway. got in my truck and ran over it two or three times. it doesn't work any better but I feel great.
Oct 25, 2008 | Office Equipment & Supplies
1,755 people viewed this question
k24674
