Try the steps given below:
1 Remove the memory card, then install the new batteries, when you turn it on it should work.
2 The next thing to try is examining both the battery and flash card door. There's usually a little switch on both doors that activates when the doors are closed. It will be a little piece of plastic on the door that pushes in on a pin switch when the door is closed. Closely examine both doors to try to identify these switches. A lot of times that little plastic nib wears down or breaks off, but can easily be a jury rigged with a small glued-on replacement.
If you still face the problem then there is some internal problem in camera, you need to take to service center to get it repaired.
Hope this helps.
Shane
