FixYa.com
Tags:
Eclipse 5443
Eclipse 5443 Skipping, Is mine Defective?
By pawa - usenet poster
I also am a proud owner of an Eskips 5443. It clips sometimes and over train
tracks and stuff, but usally at a high volume. Seeing as how i am using the
HU's amp 13x4 maybe the volume is the problem, . but when i listen at lower
volumes it still sometimes skips over bumps and stuff, when i never had that
problem with my old alpine. Any ideas?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 11, 2005
Not Rated (0)
paulrmc
paulrmc - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I would say that if your hu is only skipping when you hit bumps it is installed
improperly.  Mine will skip or cut out at low volumes (30-50) while driving
along smooth roads or sitting still.  I have also noticed that if I am playing
it at high volumes (60 +) all sound except the sub will shut down similar to a
thermal protector being tripped in an amp.  I imagine that is exactly what is
happening.  For some reason the internal amp is shutting down.  I don't know if
this is linked to the skipping problem or not.  So, in answer to your question,
I would say that yours is not defective if it does not skip when you are on
smooth roads or parked.  I have never (yet) had mine skip when hitting bumps so
I believe it is mounted properly.
The best advice I have is to take it back to the company that installed it and
let them deal with the problem.  If you installed it yourself I would make sure
that you have it mounted properly.  I have seen a few other posts about it
needing to be mounted a specific way.
John.G.Edwards
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these In Dash Receivers problems?
In Dash Receivers
Owners Manual Pioneer DEH-9
I've searched every site I can... Answer This...
In Dash Receivers
Pioneer Avic F900bt Operation...
I've installed my system but... Answer This...
In Dash Receivers
car cassette radio: Clarion...
The front panel is removable.... Answer This...
Eclipse 5443
NO DISPLAY
every thing works but display. Answer This...
Eclipse 5443
i closed my Eclipse editor...
!ENTRY org.eclipse.osgi... Answer This...
Repair Service
Find In Dash Receiver Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
