Question about Carrier 38CKC042 Air Conditioner
Won't turn on
Our AC unit will not turn on. The green light on the thermostat is on, the electrical panel is fine, the unit makes a clicking sound but then doesn't kick on.
  • 1 more comment
  • kpodobnik Jul 25, 2008
    It is central air. Not sure what you mean by both halves. The fan runs but just blows room temp air. the unit in our back yard does nothing but an occasional clicking noise. Thanks for any help you can give.
  • sk0685 Mar 28, 2009
    Mine unit makes a humming electrical noise like something will not start up
  • B Carson May 11, 2010
    Is this a central air conditioner? If so, do both halves not start?
  • 143 Answers
The unit in your back yard is the outside half. The one that blows room temp air is the inside half.
The outside half is not working. No compressor, no fan. That is a problem with the power. You will find the bad parts very close to where the power wires go into the outside half. It might be a bad relay that connects both the fan and compressor to the power. It might be a 3 terminal capacitor. It might be burnt wires.
Posted on Jul 25, 2008
My Honeywell Themostat is no longer controlling the systems after a battery change, but otherwise looks fine. Help!
The replacement batteries could be defective or installed incorrectly. Also, if the thermostat has to be removed from its mounting base for installation of replacement batteries, it may have been reinstalled incorrectly.
Nov 07, 2015 | Honeywell Heat/Cool Thermostat
Multiple clicking sounds coming from AC unit before AC unit turns on or before furnace turns on.
the is a 24v wire that feeds from your thermostat to your unit, inside there is a contactor that engages, this makes a click sound as it really is a basic mechanical part the makes metal touch metal to allow current to flow through the system, perfectly normal, your hearing the low voltage engage the highvoltage at the contactor.
Jun 18, 2013 | Dometic Rooftop RV Air Conditioner
GREEN LIGHT ON CORD COMES ON BUT THE AC UNIT WONT TURN ON. IT IS A SAMSUNG AW109CB PLEASE HELP.
you need to verify that power is getting to the control panel, the green light does'nt mean that there is power to the unit, also verify power to the controll swithes/board and verify that the thermostat is closing and trying to turn the unit on
Jul 12, 2009 | Samsung AW1203B Air Conditioner
My duo therm roof top camper air conditioner just shut off and will not come back on. Can hear a click when turning on now but nothing else. Note that heater will not come one either.
The click that you are hearing is the relay control board in the rooftop unit. This means that you are getting 12V to the board. It sounds like you are not getting 120V to the AC unit. Check the breakers in the breaker panel to make sure they are OK. If they are fine, then turn off the AC for 5 to 10 minutes and try again. There is a thermal protection device in the unit that prevents you from turning it right back on after a shut down. Try putting the thermostat to fan only operation. If the fan does not come on in fan only mode, then you have thrown a breaker.
Hope this helps,
Jeff
Jun 27, 2009 | Dometic Rooftop RV Air Conditioner
I have the same problem.
transformer going bad or bad connection check for 24v ac from red to common batteries only for mem storage and if no common used at stat to hold program red to g fan red to y comp
Jun 09, 2009 | Honeywell Programmable Thermostat Heater
My dog chewed up wiring on outside unit and i dont know where they hook up it is a 4 wire set up with red white blue and green large ac unit dog chewed thru little brown wire leading to house and now ac...
That wire is to your thermostat which of course turns the A/C on/off. One thing you can do is to splice the wire back together w/ small wire nuts (available at hardware store or wal-mart, and just hook it up color to color and then tape w/ electrical tape. Make sure you turn your breaker off and turn off the thermostat control.
Feb 11, 2009 | Heating & Cooling
Apex Digital 19" LCD wont turn on green light blinks
you can have a electronics repair done on this unit call 719 687 6997
Jan 14, 2009 | Apex Digital AVL2076 20 in. EDTV-Ready LCD...
Carrier 38CKC042 Air Conditioner Logo
754 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
