Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
How do you clean the cuisinart grind and brew thermal coffemaker?
  • 515 Answers
Go to this site, hope it will help you.
http://www.cuisinart.com/share/man/34_man.pdf
Posted on Jul 27, 2008
How do I clean the Cuisinart Automatic Grind and Brew Thermal coffee maker
I clean mine once a month with 6 cups vinegar and a couple cups of water. also replace the charcoal filter regularly.
Jan 14, 2011 | Cuisinart Grind and Brew 10 Cup Coffee...
We have a Cuisinart DGB-900 BC Grind and Brew Thermal Coffeemaker. Our Problem is that the bean grinder has stopped working. We purchased the coffee maker on 2/25/10. Prior to this happening, we were...
try cleaning the grind chute again. if problem persists:
this is a cronic problem with the DGB900BC even after cleaning. the problem is the gate or trap to the grounds needs to open/remain open during grinding or all backs up and jams. my unit opens the door (correctly) during the rotation but closes just before grinding (over-rotation?). Cuisinart is not aware of this problem (800-726-0190). please call them; i just have.
Aug 30, 2010 | Cuisinart Grind & Brew DGB-500R, 12-Cup...
Cuisinart 12-cup grinder coffemaker all gummed up
It is endemic to this unit - condensation builds up in the grind chute, which makes the grinds stick to the walls of the chute. Decalcifying with vinegar/water helps, but only in an indirect way - by keeping the inside tubing clean, decalcifying generally allows the water to flow through the machine without obstruction. Inside tubing that has calcium, lime deposits built up obstructs water, and makes it flow through the machine slower - when water flows more slowly through the machine, the machine steams off the water at a higher rate, hence more condensation builds up in the grind chute walls.
Generally, i have found all Cuisinart coffee and espresso makers to be high maintenance to a greater or lesser extent, but the Grind-n-Brews have the highest cleaning/maintenance requirement.
Mar 26, 2009 | Cuisinart Coffee Makers & Espresso...
Coffee grinder on brew and grind won't work
Make sure the slot between the grind basket and filter basket is clean and free of grounds - then inspect the area near the grinder motor - use the brush that came supplied with the Cuisinart to clean that area out. Once thoroughly cleaned, try one more time to Grind. Let me know if it works.
-Tha Mp3 Doctor
Jan 06, 2009 | Cuisinart Thermal DGB-600 Grinder
Incomplete brew
Sometimes you have to do the decalcification two or three times. Then, monthly after that.
Cuisinart Coffeemaker Decalcification Process
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Jan 01, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Is a specil tool needed to open a Cusinart grind & brew coffemaker? I have a power problem.
You need to use a Torx T-9 Tamper Proof screwdriver to remove the four screws on the bottom of the coffee maker. It is a star bit with a small hole in the center.
Dec 27, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
What is the best way to clean my cuisinart coffee maker?
-Tha Mp3 Doctor
Dec 24, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee maker shuts off during brew
Unplug for 20 minutes or longer, then:
-Tha Mp3 Doctor
Aug 27, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
I Have a Cuisinart Automatic Grind & Brew Thermal that when you start brews a small amount of coffee and then shuts off. I shut off grind and start. After I do that it brews a full pot. We have cleaned...
I have a cuisinart model dgb-600bc coffee grind & brew, didn't have a manual with it when purchased, plugged in it & hit the on button, lights up when pushing in on it, but let it go & it stops, but doesn't brew nothing. HELP -
Aug 26, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
I have a automatic grind and brew. It will only brew a full pot of coffee if I turn it on four cups. That wasn't to bad but now Ihave to unplug it to get it to come on.
Unplug for 20 minutes to fully reset, then:
-Tha Mp3 Doctor
Aug 25, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
209 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
