Microsoft Windows 7 Home Premium 64BIT Operating System Software  OEM DVD Logo
A
Anonymous Posted on Feb 13, 2011
Howcan i change windows 7 to windows xp? - Microsoft Windows 7 Home Premium 64BIT Operating System Software OEM DVD
carsten kjaer olesen
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 183 Answers
  • Posted on Feb 13, 2011
Expert
Level 2:
Mentor:
Answers
183
Questions
Helped
54312
Points
351
Hi.
There is no easy way of changing Windows 7 into XP.
The only way is to make a new instalation of the operating system - in this case Windows XP.
Regards
On my desktop I would like to change from windows 7 to windows xp
You will have to completely un-install Windows 7 and install Windows XP. I do not understand why you would want to....but, that's your perogative. Windows 7 will run about anything that was put out before it....including XP based programs
tip
How to Change Windows Password on Windows 7/Vista/XP?
Setting a password on Windows 7/Vista/XP can add a level of security to your computer. So you are often advised to set a password on Windows. In addition, it is highly recommended to change Windows password regularly. And it is a good habit to keep your PC security by changing Windows password. Here are some simple methods to change Windows password among Windows7/Vista/XP.
Method 1: Change Windows password by using Control Panel.
The steps to change Windows password have a little different on different Windows systems. The following steps are based on changing Windows 7 password.
1. Click Start, Control Panel and User Accounts in order.
2. Pick the specified Windows account whose password you want to change.
3. Click on change my password.
4. Enter your current password and type a new password, and then click Change Password button.
Note: you may need appropriate privileges to change the password of another user.
Method 2: Change Windows password by pressing Ctrl +Alt +Del.
It is the easiest way to change Windows password for Windows 7, Windows XP and Windows Vista.
1. Press Ctrl + Alt + Del when you log onto your Windows XP/7/Vista PC.
2. Click on Change password.
3. Type your new password, type your new password to confirm it, and then press Enter.
Note:
1. If your press Ctrl+ Alt +Del when you log onto your Windows XP, it will show you the classic security options instead. Click Change Password to change Windows XP password of the logged on user.
2. If the security options does not appear. Task Manager shows up instead of the security options. Just go to Start, Control Panel, User Accounts and Change the way Users Log on or off. And then uncheck Use the Welcome Screen.
Method 3: Use lusrmgr.msc to change Windows 7/Vista/XP password.
The following steps are operated to change Windows Vista password.
1. Click Start button and input lusrmgr.msc into the Search box.
2. In the coming Local Users and Groups screen, double-click Local Users and Groups, and then click Users.
3.Right-click the account that you need to reset the password for, and then click Set Password.
4. Type and confirm the new password.
Method 4: Change Windows password with Windows Password Unlocker
Windows Password Unlocker Standard allows you to change lost or forgotten password on Windows 7/Vista/XP.You can adopt this method to reset Windows password when you are locked out of computer without a password reset disk.
1. Download and install Windows Password Unlocker Standard in any accessible computer.
2. Run the program and insert a bootable CD/DVD or USB flash drive.
3. Burn an ISO image file to the CD/DVD or USB flash drive.
4. Set your locked computer to boot form CD/DVD or USB drive.
5. Change Windows password with the burned CD/DVD or USB drive
These are the simple methods can be applied to change Windows password on Windows 7/Vista/ XP. Of course, there are some other ways for your choice. Please remember your changed password. It is often for one to forget Windows password after changing it. Otherwise, you'll need to bypass lost Windows password with Method 4 if you are locked out of computer.
on Oct 20, 2010 • Computers & Internet
1helpful
How to change the language of my laptop from korean to english,the brand of my laptop is LG.I tried to change from the language from the control panel but it doesn't change.
Hi ccharlescart ,
Welcome to FixYa! How are you doing?
You did not specify the operating system you are using (whether Windows XP, Vista, or Windows 7).
If you are using Windows XP, I suggest you reformat the Hard Drive and install a fresh copy of Windows XP.
But if you are using Windows Vista or Windows 7, you can download a language pack that will allow you to change the language to English. By the way. Windows 7 starter edition does not have an option to change the language.
Hope it helps. Thank you for using FixYa!
2helpful
2answers
Hi.howcan i get the driver of my 3260 travelmate webcam driver for win 7.because acer dont support the win 7.i cant use thedriver of xp and vista.i hope you can help me.thanks
You can use the Vista driver most of the time in Windows 7 for older device. I have had a lot of success.
You can try it if it does not work you always uninstall it.
Here is a link to the Acer website with Vista 32bit driver. Hope this was of some help let me know if you got it to work. thanks for using,FixYa
http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=216
I lostmy facebookandgmail password howcan i bring my password
Friend, When you try to login to any of the sites where password is required, you would notice a small line saying "Forgotten Password?" Click on it and follow the procedure. You will be emailed your passwords.
2answers
Cannot show in intel815eea motherboard
you will need drivers for your chipset HERE is the link for the drivers.
download and install.
Ben.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
