Question about Whirlpool Washing Machines
F32 - Whirlpool Washing Machines
We found out that the F32 code means you have a faulty pressure switch. From my online research this is a common thing with the whirlpool.
We had just bought it and the next day when it was delivered we were excited to try it out and got that bloody F32 code...luckily 2 days later we got it fixed by a repairman.
I have know idea why Whirlpool would make a product with all sorts of codes, but no explanation as to what they mean. That makes no sense.
Posted on Jul 28, 2008
F32 codewhirlpool duet ht frontload washer F 32 code Whirlpool ht frontload washer displays f 32 code
F32 is a pressure switch failure. It controls the water level in the washer. The switch is a round plastic part mounted on the right panel towards the back right corner. Remove the switch by disconnecting the wire harness and the rubber tube connected to it and gently rotate it 90 degrees CCW and you should be able to pull it out easily. Some suggest that blowing on the tube will clean out anything that could be clogging it as a quick fix. If you suspect the switch you test it by checking two things; Blow on the inlet that was connected to the rubber tube you should hear a couple of clicks. The second test is to check if the switch works electrically. If the switch is bad you will need to replace it.
Read more: http://forum.appliancepartspros.com/washer-repair/7456-whirlpool-duet-f32.html#ixzz3S9ubaYUd
Feb 18, 2015 | Whirlpool Washing Machines
What does F32 mean
f32 is usual pressure switch failure
Feb 09, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
WHAT IS THE REASON OR CAUSE POSSIBLE FOR WHICH IS IN CODE F32
I did a "GOOGLE SEARCH" on 'KONICA MINOLTA 1312 ERROR CODE F32" and this was the results. Hope this helps!
F32-01, -02, -03, -04, -05, -06, 07Fan motor problem, AC board or ADU stand drive board
Apr 21, 2013 | Konica Minolta 1312 Black Toner Cartridge
WFW9200SQA12 f32 error
The "F32" error code is indicating that there is no electrical supply to the Pressure Switch from the Central Control Unit (CCU) or if the Pressure Switch contacts are not making, then "F32" is displayed.
Possible Causes/Procedures:
  • Pressure switch failure
  • Check the Pressure Switch wiring harness for continuity.
  • Check the Pressure Switch for correct operation with a Digital volt/ohm meter.
  • To manually check the function of the Pressure Switch, remove hose from switch and apply air to switch. Audible clicks will be heard from the switch.
Jan 15, 2011 | Whirlpool GHW9400 Front Load Washer
F32 error on Duet washer
f32 is pressure switch error. Disconnect the tubing and blow out the moisture and retry.
If no-go... replace the pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Sep 02, 2010 | Whirlpool Washing Machines
Washer is throughing a code
Here's a solution from an old posting of the same problem in a different Kenmore washer:
F32 is the code for a Water Level Switch Failure.
1. Remove the top panel from the washer by removing thethree screws in the top back of the washer.
2.Inside the back rightcorner is a round plastic box, fastened to the side with a plasticsnap. In will have a wire connector and a small, rubber hose connectedto it.
3. Check to make sure all the connector wires areconnected and tight. Unplug washer for 30 seconds to reset it. If the cycle failsstill with the F32 code, you'll need to replace the Water Level Switch.
4. Ifthe Water Level Switch does not eliminate the F32 code, it then the machine controller may have failed.
Aug 09, 2009 | Kenmore Washing Machines
There is an error code comming up it is f32
The F32 error code is a pressure switch failure error code, this error could be caused by several different reasons.
More than likely the pressure switch has malfunctioned. Be sure you are using H.E.(high efficiency)detergent. Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains you will need to call for service. This type of repair will require accessing the inside of the cabinet area to make some checks. This will require a service technician to diagnose & repair.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
F32 error code
remove bottom apnel on right side? is tech sheet with codes think f32 is pressure switch
Jul 15, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore elite HE 3t washer
1. Remove the top panel from the washer by removing the three screws in the top back of the washer.
2. Inside the back right corner is a round plastic box, fastened to the side with a plastic snap. In will have a wire connector and a small, rubber hose connected to it.
3. Check to make sure all the connector wires are connected and tight. Unplug washer for 30 seconds to reset it. If the cycle fails still with the F32 code, you'll need to replace the Water Level Switch.
4. If the Water Level Switch does not eliminate the F32 code, it then the machine controller may have failed.
Jul 04, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
380 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
