Question about Rowenta DZ9080 Iron with Auto Shut-off
Rowenta iron manual needed
Looking for repair/parts breakdown manual for Rowenta DZ9080 1907 1800 watt-was dropped now will not heat up although the warming up ligh blinks till auto shutoff shuts it off-blackshack1@juno.com
  • Bill Black
    Bill Black Dec 29, 2008
    This iron is glued together and sealed with a special glue in all parts. Coils are in tubes in base and are also glued in place-not like any iron in the USA. Must go to authorized repair or factory. Cost is about same as buying a new one. Sorry bout that. Owner went and bought a new one. Try getting a manual-hah good luck! It is well built and tought if ya don't have the grandkids knock it over.
  • 304 Answers
If you dropped it it will probably be an easy fix. Just openup the unit and look for a crack in the cicuit board. This is the case 99 percent of the time in apliance drops. If you find a crack in a board simply epoxy it and on the cicuit side of the board solder jumper wires from point a to point b when you follow the boken trace(s). If more than one trace is broken repeat the process until all the circuits can be repaired. Make sure you use wire of a high enough rating to handle the current the trace handles, and also use wire with heat resistant insulation in this application.
First things first though. Just open it up and have a look. The plug to the heating element may have just been knocked off. With a little trouble shooting skills and a good look you should be able to see your problem. If you get it open and see something I did not tell you how to fix just post any question you have and I will answer them for you.
George
Posted on Jul 24, 2008
Does not heat but indicator light is on.
Rowenta steam Iron Model DE-871
Posted on Dec 26, 2008
Rowenta steam iron fell down and top part is broken can it be replaced
Rowenta Iron Parts - eReplacementParts.com
www.ereplacementparts.com/rowenta-iron-parts-c-180639_180647.html Fix your Rowenta Iron today with parts, diagrams, accessories and repair advice from eReplacement Parts! Worldwide ... DE0554 Rowenta Steam Iron Parts.
Aug 08, 2015 | Rowenta Irons
My rowenta steam iron fell down and top part has broken any chance it can be replaced
Rowenta DW9080 Auto/Off stuck. How do I bypass the Auto/Off feature, or find a replacement switch?
thermostat defective,,,can be do drect by expert professional,,,but it will burn your all clothes due to very hot position,without auto cut
Nov 13, 2014 | Rowenta DW9080 Steamium 1800-Watt Steam...
Rowenta iron dg3050 iron potion broken and will not hold steam can you replace the iron part
More than likely your steam valve is broken or stuck. I had one of these and they are worth having repaired. Google Rowenta Repair Center.
Jun 15, 2014 | Rowenta DG5030 Iron
How do I use the self clean button in the DW5080 Focus 1700 Watt Steam Iron
please read carefully the owner manual and get the information about how to use the steam.
download from www. fitness.manualsonline.com
God bless you
Feb 01, 2013 | Rowenta DW5080 Focus 1700 Watt Steam Iron...
Lights come on but it don't heat up..
Sounds like a defective thermofuse. Rowenta doesn't encourage anyone to repair their product except their authorized service centers. Parts are not made available. Go to rowenta.com to find the nearest service center and call them.
Nov 07, 2010 | Rowenta DZ9080 Iron with Auto Shut-off
Iron No Longer Heats Up
Recommended solution, gently shake, did not work.
Considering the iron was at a minimum two years old, I decided to purchase another Rowenta. I found the recommended solution documented on a FAQ sheet enclosed with the new iron.
I actually own another Rowenta iron (I now have three) that has the same issue. I will send one iron, the one manufactured in Germany, to a Rowenta Service Center to see if can be repaired - it was the first Rowenta iron I purchased and it provided several good years of service.
Sep 18, 2008 | Rowenta Effective DX1700 Iron with Auto...
Rowenta DZ9080 Iron with Auto... Problem
Hello, All High grade silicones are inherently heat resistant. Look for the best silicone you can find in a tube. The higher the cost of the silicone the higher the quality. You might even try automotive gasket sealer if you want to be absolutely sure of heat resistance. This will be off an orange or blue color though.
If You need mare help feel free to contact me.
George
Jul 24, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
Doesn't heat up...
Authorized Appliance And Repair in St. Louis Mo, works on all model Rowenta Irons.
Nov 01, 2007 | Rowenta Professional DX8800 Iron
Rowenta DZ9080 Iron with Auto Shut-off Logo
1,364 people viewed this question
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
